Question about Refrigerators
I have an error code on the front panel of my Kenmore 795.7840 refrig that reads ER CO. I just moved into the house this week and the manual doesn't address this error code. My food has frozen and no buttons on the front panel are working. Any ideas? Thanks for your help.
    New Friend:
I have the exact same problem! Did you figure out what was the matter?
Posted on Nov 16, 2010
SOURCE:
The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
What does Kenmore refrigerator error code er co mean?
I just did a google search. It seems that it is a communications error between the computer in the back of the refrigerator and the front panel display,. Some people have replaced the computer only to find that the problem stays. At least two have found that wires have broken in the front door.
The wires get flexed when the door is opened and closed.
Use your model number at the sears parts direct to see user manuals diagrams and parts lists. Link below.
http://www.searspartsdirect.com/
Sep 06, 2014 | Kenmore Elite 29 cu. ft. Grab-N-Go French...
I have a Kenmore Elite Refrigerator Model 795.77563600. The front digital panel has an error code er if. I understand this means that I have a problem with the ice maker fan. Where is the fan located...
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 25, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Code on door says er dH on Kenmore elite refrig
This error code has something to do with a defrost sensor and happened after an extended power outage. I unplugged the refrig and it reset itself!
Jul 17, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Refrigerator Trio display panel read ER IF and everything seems to be melting or thawing. Not making ice and water is running from door where the ice seems to be melting? HELP! My freezer...
Jun 08, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
I have a Kenmore model 795 77563600 refrig side
Apr 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Help....kenmore trio refrigerator, error message "er co"
The Er Co error code signifies a communication error between the display control board on the freezer door and the main power board on the outer back panel of the refrigerator.
Check the wiring and connections between the low voltage interface and the main high voltage board.
If you are able to unplug the refrigerator and remove the cover over the control board on the back of the refrigerator,
you can check the wiring connection on the main control board.
If this wiring connection is okay, check the wire harness connection under the hinge cover on the top of the left hand refrigerator door.
If these connections are okay, then you will need access the wire harness connection in the dispenser.
Mar 19, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore bottom Freezer
Mar 10, 2009 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
I have error code ER dH. Unplug and then replug
Error Code - erdh
Kenmore and LG 795 Series. Model 795.77556600 but most models use the same repair. Controller Part # 6615JB2005H
To Verify correct part. Check part number for your model number at
Don't be intimidated by this repair... The 'erdh' error code indicates - error defrost heater. Replacing the controller is EASY. The difficult part is removing everything in the freezer section to access the evaporator coil but hang in there and stay with it. You will not hurt anything if you use common sense.
The new part (defrost controller) is relatively inexpensive ranging $10 - $14. Here in the SouthWest I used Appliance Parts Depot for a $10 part cost. Don't forget to have 3-4 small wire ties to secure the defrost heater, defrost sensor and wires.
It would help to write down a few notes of some of the particulars during disassembly.
I had the same ERDH error code, and my refrigerator began to warm up. I replaced the defrost thermostat assembly part # 6615JB2005H which is located inside the freezer, on the right side behind the white plastic panel.
(See Diagram Image) I accessed it by removing the freezer door, all components inside the freezer, including the slide rails / tracks mounted on the sides of the freezer. Be careful when removing the rear white panel because an evaporator fan is mounted on the back of it and plugs into the back left side of the freezer compartment. You just saved yourself about $375 or more.
Stay With It & Good Luck!
Feb 17, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite Model 795.7756...
Hello que1995
Welcome to Fixya,
You said, Message on front panel is "ER IF". We do not have manual. Any idea what that means and what we need to do?
While I look it up, you can try to reset the system by plugging the fridge for 5 minutes, or if you can not reach the plug, then throw the breaker for 5 minutes.
Not less than 3 minutes. That is why I sad, 5minutes.
Usually this will do it! let me know as I look up the error codes.
Let me know that it works
Please remember to leave a rating!!!!!
Thank You Huuum
Sep 07, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
278 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
