Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
Our frig ice cube door chute keeps slaming and the lights are going crazy on the push button board. model MFI2568AES SER 10967637JR
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 113 Answers
Your control board is bad. Unplug refrigerator and replace it, follow instructions on board to reprogram and you should be good. It's on the back outside of refrigerator under panel. Or, call a repairman to do it for 400.00 plus. Hope this helps,
Posted on Oct 24, 2010
  • Brian Brooks Oct 24, 2010
    Thank you so much for taking your time for me on a Sunday
6ya staff
SOURCE:
Maytag MFI2568AES- ice maker making ice but cannot harvest
Sounds like the thermostat inside the ice maker that allows the heater to come on during harvest cycle is bad. You will need to replace the ice maker.
Ice Maker Kit For Maytag Refrigerator Model Number MFI2568AES
Sep 24, 2015 | Maytag MFI2568AES Stainless Steel Bottom...
Tried to adjust temp of refrigerator and the panel went crazy, flashing through the various settings. Not sure what to do.
need a model # and ser # off the machine itself to give correct ans and part that has failed .. this is what i think . your machine uses a prosser with sensors and the prosser has failed . this can cause the flashing and how knows what . some models the ice mker will keep opening the ice door and never quit and the flashing controls . . to correct you will need to replace the controls in the frig side .. mm / hope this helps . mm
Nov 25, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Model gd25dfxfw00 Gold side by side; air appears to be leaking around the ice maker ejection door creating a build up of ice inside the freezer at the bottom of the icemaker ejection slot.
I had the same problem, same Whirlpool frig.
There's damper/delay arm/plunger, similar to what you see on doors, that slowly closes the ice door to allow all the ice to escape. This is stuck/broken. You can order the parts on line and replace it. I actually just removed it and the door closes nice and snug again, and no more ice build up in the chute. It occasionally traps ice in the chute, as the door shuts real quick now, before the last cube(s) can come out. I'm use to it now and am quick to open the door without sending more ice out of the maker.
The replacement kit should be : AP3595356
May 21, 2010 | Refrigerators
GE Monogram -- Ice freezes IN THE CHUTE and blocks the chute
My ice cube chute kept freezing, and I realized the Access Door was stuck open. I was able to replace it without taking the door apart.
Sep 26, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
Kenmore frig ice machine doesn't make cube ice
Normally, the ice "cubes" are crescent shaped. The most likely cause for "crushed" ice is that the ice maker isn't getting enough water on its refill cycle after ejecting the tray. Becuase there isn't enough water, the ice looks crushed...it's actually shattered.
Check the water inlet and chute to the ice maker. Sometimes they freeze and have to be manually defrosted. A hair dryer will do the trick. Also check the water chute and be sure it isn't partially frozen.
Start there...if no luck you could also have a failing water filter or sticky water solenoid valve.
Apr 08, 2009 | Kenmore 23.1 cu. ft. Side-By-Side...
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
Ice dispenser in door clogged up or frozen
I would contact Hotpoint direct for this one. It sounds like a design fault to me.
What I think may be going on is that the cubes are melting too much, then refreezing lower down.
Set your freezer to -18, and the fridge to +2 and see if that changes things any.
Check seals in that area. Where is the moisture coming from to generate the frosting? - Is the location high in humidity?
Jun 11, 2008 | KitchenAid KSRS25IL Side by Side...
Ice Jam in Chute - Whirlpool IDI SxS
first check would be to see if the flapper door is closing all the way in the dispenser area. best way is to remove the ice bucket and shine a flashlight from the front up into the disp door area and look for light around the door from inside the chute.
another check would be to make sure the door delay mechanism is connected an not allowing the dispenser door to close to fast trapping a cubes in the door and causing an air leak in the chute..
Keep in mind if you use alot of crushed ice frost build up is faster than with just cubed.
Dec 10, 2007 | Whirlpool ED2FHEXN Side by Side...
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
575 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
