Question about Pentair White/Gray Legend Platinum Automatic Pool Cleaner - Ll105pm
Pentair Platinum Legend gets stuck between my bar stools and the wall
  • 640 Answers
This question is a little vague. You have bar stools in your pool? If so, you should remove them before cleaning. If you are using this pool cleaner outside of the pool, you are using it improperly and probably ruining it.
Posted on May 11, 2011
SOURCE:
Water management system in pentair legend
Check the finger screen in the wall adapter, which is located at the wall, that the hoses are connected to. Inside that is a screen, and it's probably plugged with debris.
May 06, 2014 | Pentair White/Gray Legend Platinum...
Pentair legend pool cleaner gets stuck
make sure back up valve is working if not replace
Feb 07, 2013 | Pentair White/Gray Legend Platinum...
Pentair pool cleaner won't stay locked in
bad in-wall fitting see if tabs ore off if broken replace if cannot get out of wall turn off pump put fitting in wall and then try with channel locks to remove
Apr 02, 2012 | Pentair White/Gray Legend Platinum...
TYPE OF POOL WALL CONNECTOR FROM HOSE TO THE POOL WALL FOR PENTAIR GRAY LEGEND PLATINUM POOL CLEANER?
There are a couple fittings used between the wall and pipe,
Start with these:
Wall Fitting, Gray - Part Number LLW22PM
Wall Fitting, Complete - EW22
Quick Disconnect Adapter, Gray - LL23PM
If these aren't what you need let me know.
Feb 27, 2012 | Pentair White/Gray Legend Inground...
Platinum Legend pool cleaner get stuck behind my bar stools in my pool.
Unfortunately, this is a construction issue and not something that will be easily corrected with the pool cleaner.
Depending on the location of the port for the cleaner, you might consider shortening the hose so that the cleaner cannot make it to the barstools, but if you are like most homeowners, the barstools were built at a point in the pool that if your shorten the hose, the cleaner will not reach the rest of the pool.
To be honest, we run into this a lot and had your builder made a few alterations, this would not have become an issue.
At this point the only "true" solutions are as follows: #1) Find something that can anchor to the floor of the pool that keeps the cleaner from having access behind the table pedastal(s). #2) Discontinue using the cleaner #3) Remove the table
None of these are "great" suggestions and are probably not feasible, so option #4: live with it!
Thank you for submitting your question. Sorry we do not have a better alternative solution!
The Ugly Pool Guy www.WeFixUglyPools.com
Dec 15, 2010 | Pentair White/Gray Legend Platinum...
My Pentair legend isn't picking up debris like it
You will need to take the unit apart and useing a wire clear the jets in the throught then flush with good pressure water. Check your filter to see if it is passing derbs. Also check your finger screen at the wall in the hose connection.
Jul 06, 2010 | Pentair White/Gray Legend Platinum...
Our Pentair Legend moves to a wall and stay there
Yes place the left jet (it rotataes) to the 11:00 position and the right jet to the 5:00 position and it will run correctly.
The Pool Tech
Jun 28, 2010 | Pentair White/Gray Legend Platinum...
Legend pool cleaner wheels not moving
You might want to pull the drive wheels and see if their might be a small pebel stuck in the drive gears on the wheel.
Oct 04, 2009 | Pentair White/Gray Legend Platinum...
Legend 2 pool cleaner auto back-up feature stopped working
Make sure you have a clean filter and clean wall fitting screen. Pull hose out of water and lay it so you can watch the back-up mode go through its mode. The housing might be crack and have a leak which might not give the valve enough power.
Sep 05, 2009 | Pentair White/Gray Legend Platinum...
Pentair White/Gray Legend Platinum Automatic Pool Cleaner - Ll105pm Logo
266 people viewed this question
Top Pentair Pool & Spa Experts
Bill Jordan
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
