Question about Vizio L32 32 in. LCD HDTV
I've had my tv for maybe three years. I turned on the tv this afternoon, and I have picture but no sound. Can this be fixed?
  • 1,662 Answers
Certainly. The only question is how hard it would be to fix it and how much it would cost. First, if you are on a cable service, try another set to make sure it isn't a cable company problem. Next, ask if anybody has tried changing sound options. Maybe somebody set it to run the sound through an external sound system with internal speakers off. Another possibility, if you intentionally set the TV sound to go to an external amplifier, is a pet, small child or person cleaning behind the set has yanked the sound cable, or the external amplifier is not working as intended.
If you've checked all of these, tried an external sound system (a "boom box" with an auxiliary input will do), and you can see the volume indicator bar go up and down without hearing anything, then you have a problem with the sound demodulator inside the set. If it works with an external sound system but not the internal speakers, the problem is in the internal amplifiers. A work-around until you can get it fixed is to use the closed caption system.
Posted on Oct 24, 2010
SOURCE:
Hi, the frame on my quinny buzz 3 seems to become very loose i,ve tried tightened the screws but still appear loose is there any quick fix u would know?? thanks
Good Afternoon
If you've tightened the chassis screws there would be no other "quick fix" that can be recommended.
If the product is under 2 years old please contact your retailer with your proof of purchase for them to send it to the engineers under warranty terms and conditions.
If the product is over 2 years old or you do not have proof of purchase please go to www.quinny.com and select the country you're in then go to "Contact Us" to get in touch with the customer service department in your country.
Jul 11, 2011 | Quinny Buzz Three Wheel Stroller
37" Philips LCD sound but no picture
Check the inverter on the sides of the TV. This sounds like the inverter is going bad and that's the reason why you have sound but not picture.
Jun 16, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
RCA TV, model number 32V550T. No picture but sound is fine.
hiya
this sometimes is quite simple to fix as it cud be a dry joint on the circuit board where the tube motor sits.
or it cud be the tube is on its way out, which wud be cheaper to buy a new tv rather than have it fixed
rik
Feb 24, 2009 | RCA 32V550T 32" TV
I have picture and no sound
Try unplugging it for a minute. You will have to go through setup again (most likely).
Some of these sets have a (software?) issue and the audio drops out maybe once or twice a year-at least that's what I've experienced. No real fix for it.
Aug 01, 2008 | GE 35GT720 35" TV
Picture went out and all the tv does is make a buzzing sound
The horizontal output transistor drives a transformer that gives you the high voltage to light up the picture tube,either the transistor or the transformer have gone bad,sometimes both have to be replaced and sometimes the transistor fails for no reason by itself.Be safe and call for help if you are not familiar with tv service.
Sep 20, 2006 | RCA F32450 32" TV
Audio/video problem
ALWAYS connect and disconect the A / V cables when all units are unplugged from mains!!!!!!!! First: try to use quality cables and second: call the service for further investigations and repairs.
Aug 07, 2006 | JVC AV-27230 27" TV
Initially No Picture when Turned on but sound normal and 5 minutes later Picture is all RED and then Picture becomes NORMAL (all normal colors)
theres a high voltage block that all three of the anode leads attach to and sometimes a small crack happens across this block and will not let some or all of the crt's get the high voltage all at once untill it heats up a bit. now if this is not your problem i would make sure that all three crt sockets are attached to there tubes all the way as maybe justy maybe there loose and will only work after ther expand a bit. Now another problem that could cause this problem to occor origially would be that someone left off a crt ground strap and the crt arched and popped and caused the problem with the High voltage block. And no I cant see a tube being bad then comming on at first UNLESS when you say the red comes on is the picture all red with small retrace lines(small white lines)in the screen with no picture except for red???? No video only a red blank screen is what i mean. If thats what its doing then yes Ive seen heater to cathode shorts on a picture tube that would cause this problem but to be sure your really gonna need to have the set looked at.. Good Luck
May 17, 2006 | Toshiba 40H80 40" Rear Projection...
Vizio L32 32 in. LCD HDTV Logo
175 people viewed this question
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Jerry Greenberg
Jerry Greenberg
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
