Question about Toshiba W403 VHS VCR
Cannot figure out to get VCR to come on at certain time.
    President:
  • 2,047 Answers
This can only be set using the remote control timer. Refer to the user manual for assistance on steps to perform this. If you dont have the manual simply type device make and model on google and add manual to it.
Hpe this solution has been helpful?
Posted on Oct 24, 2010
SOURCE:
VCR stops recording by itself after a couple seconds.
Some VCR's will stop if the signal is not there. Retune the set if it uses Freeview. The broadcasters and those who are in charge of Transmitters like to mess around with the stations from time to time. This will effect the recording if you are using a model with the Guide Plus system. If you are timer recording it make certain that the settings are good. If it is an older model, make certain a thing called PDC is not on.
Dec 16, 2015 | Panasonic PV-7450 VCR
How do I record a show on a vcr
How times have changed :-). On the VCR you need to have it selected to the channel you want to record. It will have a channel display. When you are ready to record press the red record button. There will also be a timer to record at a certain time of day as governed by the clock on the VCR and the channel you have set it to.
To align the tape properly, it is best to fully fast forward and then rewind back to the beginning before you record.
Nov 09, 2015 | Televison & Video
Analog VCR Model SDV394SU on cable will tune stations and record the current station, but will not start for for programmed (on/off timed) recording. In other words, when you program the VCR to start at a...
The answer to your question, "Does this have anything to do with the fact that the VCR and TV are now on cable?" is no.
The outside antenna and the cable are input signal sources only and have no effect on the functions of the VCR.
It sounds like you have an electronic problem with the timer circuitry. In order to locate exactly where the timer circuitry is located, you would need a service manual for your particular VCR. Using the service manual, you may or may not be able to repair it.
My suspicion is that it would be cheaper to just purchase a new VCR if timed recording is important to you.
Aug 07, 2009 | Toshiba Televison & Video
I have separate dvd player and vcr, how do I hook coverter box up
It took some time, but I finally have this figured it out so everything works.
I have the same setup, but I had one additional piece to the puzzle that I had to figure out. I have an older TV and use and antenna, but had to buy an Audio/Video RF Modulator a couple of years ago to use my VCR & DVD player with the old setup.
Get yourself an Audio/Vido RF Modulator (you can pick one up for about $20-30).
Connect the TV to the RF Modulator.
You should have 2 connectors for your antenna. Connect one to the converter "To Ant" and the other to the RF Modulator.
Connect the convertor A/V cable to "IN" on your VCR.
Connect the cable from converter "To TV (RF)" to "UHF/VHF from Ant" on VCR.
Connect the VCR "OUT" cable to the RF Modulator.
Connect DVD A/V cables to A/V input on VCR.
Your TV should be set to Channel 3 (or 4, depending on your setup) and depending on your "input" connections, you should be able to view vidoes from VCR like this and DVD by changing the input (the button should be on your VCR or other remote). For ex. my input changes on my VCR from channels, to L1 & L2. My converter & VCR play on L1 and DVD's play when I change it to L2.
Now, I just have to figure out how to add the converter box to my universal remote. :)
Feb 14, 2009 | Insignia Digital-to-Analog Converter for...
VCR will not record
yes your hook is all correct...but still will not work......unless this is a d-vhs recorder...(and the other way to record hd is dvr)....(note dont throw the standard vcr away) it might and can be use later down road
Jan 15, 2009 | Proscan PSVR73 VHS VCR
Need instruction to program the remote RCA 450
took me awhile but I figured it out
ok
Put your TV/DVD/VCR on
hold in what you want to program TV/DVD/VCR BUTTON
(you dont need codes or anything)
then while holding in what you want to program (TV, DVD, VCR) hold in ON/OFF
both at the same time
when the light comes on and stays on
keep hitting ON/OFF BUTTON
do it slow, when the TV turns off hit the STOP button at the bottom
then hit the button you just programed
then hit the ON/OFF button, the TV/DVD/VCR will turn on
if it doesnt work, repeat. make sure you hit the stop button when the TV/DVD/VCR shuts off, if you hit it an extra time while the TV/DVD/VCR is off it wont work.
took me about 30 mins to figure it out.
I lost my codes too, but I wanted to help all you other people too.. now since I helped you.. check my band out... www.myspace.com/jumpercablenj
Nov 21, 2007 | RCA RCR450 Remote Control
Vcr to tv connection
There are probably a couple of different ways to hook things up. One is you hook the VCR "in between" the indoor antenna & the set. Hook antenna to VCR RF/Ant In, then VCR RF/Ant out to the Antenna input on TV. Your VCR will then be able to record one channel, while you watch another on TV. To play back the VCR, or do any VCR setup, TV channel must be set to either channel 3 or 4. The other way is to use the Video & audio input/outputs on the VCR & TV. You will need the appropriate cable(s). Match the VCR video/audio outs with the set of inputs on TV. Video and audio out on the TV go back to the video/audio inputs on VCR. In order to view VCR playback, menu setup, you will need to select that input (line, aux, video 1 etc.) on the TV. This hookup probably won't allow the recording of a second channel while watching one. As regards the hft channels, I assume you live in an area where such is being broadcast. The TV can probably be put into a programming mode where it will scan for all available channels, and put them into memory, or they can be programmed manually.
Jun 13, 2007 | Goldstar GVR-E435 VHS VCR
How Do I use timed recording?
Is this a problem of the VCR not doing a timed record at all, or of it recording only snow (no signal) or perhaps the wrong channel? If the first, then it would point to incorrect setup of the timed record session or that the clock time & date settings are incorrect... the VCR setup stuff. Also, once the timed recording is setup, there is often one additional button to push to actually ready the VCR. Older VCRs, were put into the timed mode by power off. If VCR isn't recording anything (it is coming on to record, but no signal), then it has to do with hookup of the VCR. Depending on your cable system, the VCR can only record the channel the cable box is tuned to. Again, depending on the system, the VCR needs to be cabled in between the cable box and your TV (cable box RF out to VCR RF in, VCR RF out to TV RF in) RF=ant. Exact cabling will vary.
Apr 26, 2007 | Memorex MVR4052 VHS VCR
DVD/VCR totally not working
your dvd certainly needs to be repaired by a tech.the power is acting up take it to a tech.good luck
Apr 07, 2007 | Audiologic DVCR-251
Toshiba W403 VHS VCR Logo
79 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
