Question about HP Scanjet 4300c Flatbed Scanner
My scanner was worling fine. I scanned a doc then printed it. Went to can another then nothing. I got an error message saying that the pc could not find the scanner. I noticed that there is not elec power to the scanner. I disconnected and went to a different oulet. It seems the scanner is getting electricity. Would a blown bulb cause this? If so, can it be replaced?
  • HP Master
  • 1,606 Answers
On my scanner the pc data cable seems to come loose which makes for intermittent disconnects just like you had. It also does a thing where if you don't use it for even a short period it goes into whats best described as a sleep mode. This almost always requires it be unplugged and plugged back in before it is recognised again. I have a feeling from your description that what you are seeing could be a variation of one of these. The scanner works just fine but it does these annoying things.
As its a scanner there isn't much (almost nothing) we can check or adjust. You can check the data and power cables. Gently give them a wiggle and see if you can get the scanner to nod off again. Usually the problem will be the computer end of the data cable or the scanner power plug or jack. These may be loose or worn and making intermittent contact if moved bumped or vibrated. If you experience more power outages than it seeming to be asleep then the power jack could be loose or the wire inside the power cable may have been damaged. If the wire is damaged you may be able to find where by wiggling the wire. Sometimes you will see a bend where it should be straight. If you don't the problem is usually by the plug end. If you can confirm the problem is the power wire then you can just replace it.
As far as bulb replacement, there shouldn't be any user serviceable parts. The light source inside is a series of leds on the scan bar. These create that light greenish light (most models) as it scans. It should show an error if there is a light problem. You can check by watching the light leakage as it scans. If there is light you are ok, reduced light should just mean darker scan images.
It is possible you have a drive motor issue that is causing excess power use and overheating. If you have used it a lot the guide tracks will wear or get dirty and cause extra friction and the little motor has to work harder and harder until it fails. You could possibly (really doesn't sound like it though) be seeing the early failure of the motor. Unfortunately if there is a serious hardware problem it is almost never worth fixing a scanner. It is much cheaper to replace it. My bet is you are seeing a cable issue.
Posted on Oct 24, 2010
6ya staff
SOURCE:
Scanning from printer can't see any computers. says it needs the software. pc is able to print docs to the printer. when scanning says connection error - been trying for 3 days now uploaded all drivers to...
for normal scanning you can go to control panel and choose the option of scanner and camera wizard and do the scanning but it is good if you install the driver of printer which is contain the scanner software and give you more option of scanning.
have a nice day and dont forget to give rate please...
Feb 12, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Im trying to scan and the canon says: "set the pc to start scan"...? Nothing pops up on the computer, what do i need to do?
I'm using an MG5220 and got this same message. Here's how I fixed it.
On the printer control panel press the soft key to select the scan function. Then hit the soft key to select Save/Forward. Then select Foward scanned data to a PC. On the next screen make sure to select the appropriate PC. In my case I'm connected wireless but the selection was set to USB connection and that's why I was getting the error noted above. When I picked the PC that is connected wirelessly everything worked fine again.
Jul 12, 2009 | Canon PIXMA MX850 Multifunction Printer
Scanner error message. Will print from PC fine
The Scanner has died. If you Know someone else who has the same model but is not printing but scanning fine you can swop over the scanners. This solution don't work 100% of the time but i have fixed a few this way.
Apr 01, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Scanner and copier not working
You have a problem with printer need to contact Lexmark your scanner is probably broken.
Mar 15, 2009 | Lexmark X6650 4-In-One Wireless InkJet...
C4200 - says USB not connected when trying to scan
This is a HP hardware/software error and HP has not fixed it.
The C4250 may report that "USB is not connected" but the printer works just fine and when you use the Microsoft Scanner and Camera Wizard to carry out a scan, it works just fine too. So the error message is wrong.
The Microsost Scanner and Camera Wizard can be found on the Control Panel.
Mar 01, 2009 | HP Photosmart C4280 All-in-One InkJet...
Samsung scx-4100 scanner error - cannot detect device "Samsung.."
I just fixed this problem for my computer. Try installing the scanner driver. You probably have the printer driver installed but the scanner driver is needed for Smarthru
http://www.samsung.com/us/support/download/supportDown.do?group=&type=&subtype=&model_nm=SCX-4100&language=&cate_type=all&dType=D&mType=DR&vType=&prd_ia_cd=06010300&disp_nm=SCX-4100&model_cd=&menu=download
Jan 05, 2009 | Samsung SCX-4100 All-In-One Laser Printer
HPSC1610 all in one
hi i have a same problem regarding to hp 1210 all in one printer .scanner .copier what i will do so that i can scan picture tnnx for answering my question this is my yahoo messenger [email protected] plz send your answer to this yahoo messenger
Jul 20, 2008 | HP PSC 1210 All-In-One InkJet Printer
Scanning
I can use it to print but I cannot scan anything anymore since I updated my internet explorer. My OS is Microsoft XP. I am using a 4-in-one scanner. Thanks a lot.
May 19, 2008 | HP All-in-One Printer
Compaq A3000 scan issue
The cartridges problem my be caused by the two retaining springs located under the cartridge resting area at the right side of the printer. I discovered them when I opened up an attemped to clean my A3000. Both springs were broken, an I can't tell where they were attached.
Oct 11, 2006 | Compaq A3000 All-In-One InkJet Printer
HP Scanjet 4300c Flatbed Scanner Logo
113 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
