Question about Dryers
What's the easiest way to install a new dryer drum belt in a GE Profile model #DPSB613ED2WW electric clothes dryer?
  • Dryers Master
  • 8,220 Answers
You unplug it What's the easiest way to - b7faded.jpgfe957db.jpg203e9dWhat's the easiest way to - f5fa58b.jpgs=f5fa58b.jpg More here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Oct 24, 2010
6ya staff
SOURCE:
Our GE Profile DPSB613ED2WW dryer has been losing drying efficiency for the past few months. It now takes three cycles to completely dry a load. The dryer is heating (although we assume not correctly) and...
How is the vent discharge air flow out the back of dryer? If not very strong check out lint trap cavity for blockage or obstuction causing lint to build up, blocking air flow from drum cavity. Once found a pocket comb that had got into lint trap housing and created a lint dam blocking air flow.
Feb 14, 2011 | GE Dryers
Drum won't rotate. it heats up but will no tumble clothes. how do we acess the belt
the belt cant be access by us its a very tecnical work so sorry you have to give to a reputed servic centre
Sep 14, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer belt replacement
put belt around drum then around motor pulley, then pull or push idler pulley so as to put belt over this pulley and release,this will tighten the belt,then manually hand rotate drum to self-align belt on pulleys and drum and put covers back on
Sep 04, 2009 | GE Profile Wizard DPSE592EAWW Electric...
I turn the dryer on and the drum will not turn.
It sounds like the belt that turns the drum is loose or worn out and needs to be replaced. Another problem is that the motor is on the way out. Check the belt first.
Aug 02, 2009 | GE Profile Harmony DPGT750EC Electric...
New GE Profile Dryer makes intermittent loud squeeking or rubbing
Your drum may be out of round. The drum belt on the outside of the drum may be rubbing against the cabinet. When the cabinet heats up, the side walls of the cabinet may be bowing inward, thus making contact with the belt on the drum. This would explain why it is intermittant. When the heater turns off, the cabinet cools and the sides bow back out.
Jul 11, 2009 | GE Profile Harmony DPGT750EC Electric...
GE profile dryer is making squeaking noise.
please replace felt around drum thank you for useing fixya RATE ME
May 17, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Profile Dryer (Not a Harmony)
Procedure is much the same, just easier. Don't take belt off. Pull drum straight forward six inches or so and replace the hat shaped teflon drum bearing.
Sep 28, 2008 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
154 people viewed this question
Top Dryers Experts
Marvin
Marvin
jimorris77
