Question about Wolfgang Puck BDRC0010 10-Cup Rice Cooker
I put in 10 cups of rice and filled the water to the 10 cup line after the rice was put in. After it started cooking water started coming out of the steam vent and got all over the counter, i unplugged the machine and drained alot of the water out, then plugged it back in and it cooked for a minute and then it clicked on to "keep warm". The rice was a bit mushy, I know it should have been fluffier. What did I do wrong??
    Genius:
  • 1,672 Answers
you miscalculated the water level for your rice!
Posted on Nov 07, 2010
SOURCE:
User instructions for 3 cup rice cooker 91914
All rice cookers are very easy to operate without the manual.
First just measure the amount of rice you want to cook. 1, 2 or 3 cup then wash couple time and rinse very good . Put in then fill with cold water to the mark line indicate cup. (Equal the amount of rice)
Then just press cook. After it pop up that mean it's cooked. Then open and turn the rice thoroughly, let it open for 6-10 minutes then closed it. It's ready to serve.
If the rice is too soft, that mean too much water. Use less water next time.
If the rice is too hard or not fully cook, that mean too less water. Use more water next time.
Any left over, just leave it in and on to keep warm.
Good luck and enjoy
Mai Lor
Aug 06, 2018 | Kitchen Appliances - Others
Tip
How much Rice and Water go in the Cooker
So you lost the instructions to your rice cooker and now you want to know how much rice and water you need in there…
He is what I have found out with using my cooker to prepare rice.
There is a cup that comes with your rice cooker that equals about 2/3 of a regular measuring cup...one of these or 2/3 cup for every cooked cup of rice that you want to end up with... Add as many 2/3 cup fulls of rice as the number of full cups or servings that you want to end up with. See my notes about washing the rice further down in this tip.
The water...
There are lines on most of the cookers with numbers that represent the number of cups you are cooking...fill with water to that line....
If you are not sure, just fill with water a bit over the top of the rice...the amount is not that critical as the cooker senses when the water is cooked off and then shuts down...so a bit more will only make the cooking time a bit longer... no biggee...
Also it is best to rinse your rice before you actually leave the water in the pot that you are going to cook with...
Remeber also, if you have a brown or wild rice setting that the cooking times are MUCH longer...like up to 90 minutes, so get it started in plenty of time or you will be eating rice for a snack before bed...
The best feature is that you just have to place the rice and water in the unit, press the button for the type of rice you are using and forget about it itll it goes through the cycle and shuts down, going into the hold warm mode....it is so easy!!
These things are really goof proof, and make great rice very easily...a little bit of experimentation and you will enjoy very much using your rice cooker.
on Jul 27, 2010 | Black & Decker RC400 7-Cup Rice Cooker
Chefmate rice cooker instructions 10 cup
if you put a 10 cups of a rice rinse it first before you add a water , the measure of the water is equivalent of the cup of the rice.now,put 10 cups of water. then put it on the rice cooker, then press rice cooking, it is automatically turn to "keep warm" after it's getting boiled. wait for about 45mins of cooking.thanks.
May 07, 2011 | Microwave Ovens
I seem to have lost my manual. Can you tell the rice to water ratio. How much rice and how much water? I have been guessing and it just doesn't come out well. [email protected]
Hi, you lost the instructions to your rice cooker and now you want to know how much rice and water you need in there? He is what I have found out with using my cooker to prepare rice.
The water...
There are lines on most of the cookers with numbers that represent the number of cups you are cooking...fill with water to that line.... If you are not sure, just fill with water a bit over the top of the rice...the amount is not that critical as the cooker senses when the water is cooked off and then shuts down...so a bit more will only make the cooking time a bit longer... no biggee...
Mar 11, 2011 | Panasonic SR-106N 5-Cup Rice Cooker
How many cups or raw rice and how many cups of water can you put in a 10-cup rice cooker?
Asians dont need the ratio of water to rice, ....
Try this, put water on the rice, level the top of the rice, dip ur mid finger until it touches the top of the rice, look at the level of the water and it should be in the level of ur FiRST LiNE of ur finger!
Ur ready to cook!
Nov 28, 2010 | Rival RC100 10-Cup Rice Cooker
Need basic directions
There is a cup that comes with it that equals about 2/3 of a regular measuring cup...one of these or 2/3 cup for every cooked cup that you want to end up with...
The water...
remeber also if you have a brown rice setting that the cooking times are MUCH longer...like up to 90 minutes, so get it started in plenty of time or you will be eating rice for a snack before bed...
These things are really goof proof and make great rice very easily...
heatman101
Jul 26, 2010 | Aroma ARC-914S 8-Cup Rice Cooker
Need directions for Comet stove top rice cooker
Fill the bottom to the line with water. Put two cups of rice in the top and two cups of water. Put on stove top on high until lower water is boiling, turn to medium heat. For white rice check after about 20 minutes, if water is assorbed and rice is tender, fluff with a fork...eat. If it needs a few more minutes of cooking, no problem.
Brown rice will take about 45 minutes.
I have used my stove top cooker for at least 35 years...ordered it with box top and some money from Comet Rice.
Pat
Mar 09, 2009 | Kitchen Appliances - Others
Hitachi RD6106 10-Cup Rice Cooker
The Hitachi has notches on the inside of the pot. You put your rice in the pot and than start adding water until your water level reaches the notch labeled 7. Remember that the rice has to be inside the pot when you start adding water so that you will have the correct amount of water for the rice you're cooking. It doesn't work the other way around. Rice in pot than add water. But usually the average cup that comes with these rice cookers only holds 3/4 of a cup when you fill them to the top.
Jul 09, 2008 | Hitachi RD6106 10-Cup Rice Cooker
Lost Cup
The measuring cup for my Rival RC100 holds 6 oz (volume of water to the top rim). The markings on the inside of the pot (1 through 5) seem to hold about 12 oz each.
(that is: the 1 line holds 12.2 oz, the 5 line held 57 ounces of water)
close enough to the standard 2 to 1 water to rice ratio.
I put in about 1.7X as much water (by volume) as brown rice, and it comes out very good for me. (1 cup rice to 1 3/4cup water).
Jan 23, 2008 | Rival RC100 10-Cup Rice Cooker
Cooking rice
I have a Sunbean Instant Streamer model 4710... I just wash the rice, add it to the bowl and add 1 cup of rice to 2 cups water. I fill the the bottom of the streamer to the max line and turn the steamer to 50 minutes.. The rice comes out great in my streamer this way
Sep 08, 2007 | Sunbeam SUN-4710 5-Cup Rice Cooker
Wolfgang Puck BDRC0010 10-Cup Rice Cooker Logo
91 people viewed this question
Top Wolfgang Puck Kitchen Appliances - Others Experts
Irene Tulloch
eyecam
Are you a Wolfgang Puck Kitchen Appliances - Other Expert? Answer questions, earn points and help others
