Question about Hardware & Accessories
GE 15119 instructions please. The dial just says "time now." How do you know when light go on and off? Need directions. Can't believe there are none!
Here the help you need to set timer.
Rotate dial until current time lines up with black triangle located in center of dial
The black pointer remains stationary when you rotate outer dial
Now the outer edge of dial has 48 plastic segments that lift up
GE 15119 instructions please. - 776e6ad.jpgHere are some segments lifted up on GE15207 timer
As I recall, segments-up timer OFF, segments-down timer ON
If you need more assistance, answer back and I will help
Posted on Oct 25, 2010
  • geoffdef02 Dec 02, 2010
    Pull ALL segments up. Then push one down to come ON say at 9:00. Then push the 11:00 one down to make it go OFF at that time. Hence only 2 will be pushed down for a given on/off event.
SOURCE:
I cannot set my GE timer--15119----I have no instructions and have tried many times---I can't believe how difficult this timer is to set----
Here's what I found.
Pull up all of the little pins around the dial.
Push down all pins for the time that you want the light to stay on.
Leave pins up for all time that you want the light to stay off.
Rotate the dial to the current time of day.
Plug timer into wall.
Plug light into timer.
Ensure light is ON.
Gary
Feb 16, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
I've lost the directions for setting the GE Timer Model 15119
You posted under GE 15119 timer.
Open page to identify timer and download manual:
Manual has pictures that clearly illustrate how to set timer.
http://waterheatertimer.org/GE-timers-and-manuals.html#15119
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 28, 2011 | Garden
Setting the GE timer 15119
the GE timer 15119 is a push pin design. The easiest way to start is to ensure all pins are up, then push down the pins that represent the time period you want the appliance ON. For example, if you want a lamp on from 7pm to 10pm, push down the pins between the 7 and 10 on the black portion of the dial. then rotate the dial clockwise until the arrow points to the current time of day. Turn switch to the "timer on" position. Plug the timer into the wall outlet, then plug the lamp or appliance cord into the timer and you're done.
Hope this helps.
Dec 29, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
How do you program the 15119 timer? I have the tabs "up" for the times that I want the timer off and it is not working. The switch is set to "timer on". It does work when in the...
I was looking at GE timers at Home Depot tonight.
Timer ON is correct setting.
Segments up should be lights off.
You lights turn ON with outlet on, so lamp, bulb and electricity are good.
Troubleshoot your timer:
What happens when you manually rotate the dial clockwise?
Do lights turn on and off at scheduled times?
Move override switch both directions and rotate dial manually with switch in each position.
Are the segments pulled all the way up?
If lights do not respond when dial is rotated manually, and segments are all the way up, then timer is broken.
If lights turn on-off with manual rotation, then check if clock motor is rotating dial.
If dial is not rotating, then timer is broken.
The way these timers work is this:
Timer clock with plastic gears rotates dial.
Dial rotates as time passes.
Plastic arm rides along outside edge of segments. See photo below.
When segment is pulled up, plastic arm clicks inward via spring action.
The moving arm opens electrical contacts that turn lights OFF.
If dial is not rotating, or the spring is worn out, or the plastic arm broken off, or the contacts fused together, or override wire is disconnected, then timer is broken.
I test these timers.
4-6% arrive defective, and most last 1 or 2 seasons and then they break.
But they are priced low and easily replaced.
geno_3245_190.jpg Plastic arm rides along segments
geno_3245_191.jpg Segments pulled up on GE 15207
Dec 16, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
I have a ge model No. 15119 timer and I don't know how to set it
Open following link to identify timer
Page has manual that comes with pictures and clear instructions
Dec 11, 2010 | Hardware & Accessories
I have ge model 15119 24 her timer and need help on how to set
GE 15119 timer is a 24-hour plug-in dial-type timer.
Plastic segments located around outer edge of dial control on-off operations.
Each segment represents 30 minutes of 24-hour day.
Timer comes with segments down.
Each segment can be lifted up using small screwdriver under edge of segment.
Segments down, timer is ON.
Segments up, timer is OFF.
So if you want timer to turn on at 7pm and turn off at 11pm, then lift all segments around dial except segments between 7 and 11.
Dial is divided into two parts > day and night.
Nighttime hours are shown by numbers with dark background >> notice small crescent moon where 12 midnight is located.
Daylight hours are shown by numbers with light background, and sun symbol shows at 12 noon
To set current time, so timer knows what time it is right now:
Rotate dial clockwise until current time lines up with arrowhead located on inner dial.
There is override switch located on one side of timer.
Move switch to Timer ON position and timer program will function.
If you want to turn lights ON using override switch, move switch to OUTLET ON.
Last steps:
Turn lamp on.
Plug lamp into timer.
Dec 01, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
I have basic timer # 15417. No instructions came with it and I don't know how to set it..
GE 15417 is electro-mechanical plug-in timer
GE 15417 GE15119 GE15131 are combined in one instruction sheet:
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/15119-Manual-eng.pdf
1) Rotate dial until current time lines up with stationary black triangle located in center.
2) Segments around outer dial divide 24-hour day into 48 half-hours. Lift segments for times you want lights to be OFF. Segments down for times you want lights ON.
3) Slide-switch on side of timer is manual override. To use timer function, set switch to 'Timer ON'
4) Plug light into timer, plug timer into wall.
5) Maximum load is usually around 500Watts >> check markings on timer for exact load capability.
Nov 18, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
How do I set the ge timer model #15119. husband
I tried to pull the whole dial and doing that I discovered that the border of the dial is composed by pins that you can pull it up each independently, with your nail or with any pointing device. The rest is easy: get sure the switch is set at "timer on", turn the dial to the current time using the black triangle mark and pull the pin up in the time you want your device to disconnect.
Dec 08, 2009 | General Electric GE 24-Hour Timer, 2-Pin...
Hardware & Accessories Logo
551 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Thomas F. Schneider
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
