Question about Linksys Wireless-G WRT54G Router
Hardware config should i wire the cable from the back of the modem into the back of the router
  • Anonymous Jun 08, 2008
    I where to hook all the cables and wires
  • chupie Jun 08, 2008
    How to hook up
    Problem Solver:
  • 9 Answers
From the back of the modem into the WAN port of the router
Posted on Jun 09, 2008
I have a dell 2400 desktop computer. I recently got FIOS and they hooked my wife's computer to their router with an ethernet cable. Can I also hook my dell up the same way?
Depends on the hardware. Is it a router or modem? Does is have extra ports in the back,
Router with extra ports, just connect new device with wire or even wireless if it has wireless.
Modem, most likey you have to buy a router.
Dec 28, 2012 | Dell Dimension 2400 PC Desktop
I need to reconfigure my netgear adsl2+modem dm111p v2
first get a wired connection with router//
get into config page 192.168.1.1
username:admin
password: changeme or password
from there you can get into config page and change the settings of the router
Sep 17, 2012 | NetGear DM111P DSL Modem (DM111P100FSS)
If I reset my dynex G router using the reset button; 1) What will be my default password? 2) Will resetting the router affect the hard wired connection?
the default ip is 192.168.1.1  username admin password admin or leave the password blank.
hardwired you mean is utp cat 5e cable? known as internet cable, which using switch hub.
well, it will affect if the wire/cable you mean is came from the router you reset.
the wire and the access point  came from the modem is still active.
 do not reset your hardware if it is also your modem. Because when you reset it, all configuration of  your modem will be lost, including your user name and password provided by your ISP.
Feb 04, 2011 | Dynex Wireless-G Broadband Router
Cant get configuration to complete on befsr41 router
Press the reset button on the router for at least 30 seconds. release it. Unplug the power to the router . wait for 10 seconds and plug it back in. Wait for 1 minute and try to set up your router.
If you are having trouble setting up your router with the CD, then you can set up your router without CD also. You can do it manually.
First make sure that your computer is online directly through the modem without the router.
If that is working then you can connect the computer and the modem to the router. Open the set up page of the router and change the settings of the router according to the settings of the Internet service provider
Click here for more information about router set up
Feb 16, 2010 | Linksys EtherFast Cable/DSL Router
EMule TCP Port 11522 not reachable
Does you norton program have a firewall included with the software? If so, your windows firewall was probably turned off automatically because having two firewalls running simultaniosly can cause a conflict between the two firewalls and therefore will not work correctly.If you have a firewall included with your norton software make sure it is turned on and leave your windows firewall off, other wise turn your windows firewall back on.
As far as your situation with the broadband modem, I have to ask: Is your Thomson hardware a broadband router (wireless/wired), or are you using an access point? (wireless/wired) If you are using a "router" there is no way to set it up to work with the modem the cable company provided you. However, if the Thomson modem hardware is an "access point" the only thing I can suggest is to follow these steps:
1) Pull the power cord out of the back of the modem that the cable company provided to you.
2) Next, plug in your Thomson router in to the ethernet port of the computer.
3) You are then going to configure that device. Start by going to the "network and Internet" section in your control panel. There should be a section in there where you can click that says "setup a new network connection" There should be an option to set up and "access point" and it will search for your hardware. If your hardware is found you will probablybe promped to input information about your router and once that's done it should set up successfully. If it isn't successful by some chance don't give up just yet! Go to step 4-
4) Shut down your computer.
5) next, switch the ethernet cable going from your Thomson hardware to the modem from the cable company.
6) You will then need a second ethernet cable to go from a second port of the Thompson hardware in to the ethernet port on your computer.
7) next, plug the power cord back in to the modem from the cable company and your Thompson hardware and start up your computer.
You should be able to get a wired internet connection if all goes well. If you have a wireless access point go ahead and set up a separate internet connection only this time choose "wireless" and choose your settings. I hope this helps. Feel free to contact me anytime if you have more questions. Happy Holidays!
Rachel
Dec 04, 2009 | Computers & Internet
Netgear MR814 won;t connect
wireless problem is there re-configure the wireless router go to the wireless option then cilk right information then you get it
Mar 04, 2009 | NetGear MR814 Wireless Router
Trying to set up wireless router to satellite phone/internet
i've never worked with a 7740, but i've installed hundreds of hn7000's and hn9000's. the issue is usually that the router and modem are defaulting to the same ip address. if your router supports has a web-based config utility (as most do) try cat-5'ing to the router with your computer while the router is NOT connected to the modem. log into the router and set it's ip address to something OTHER THAN 192.168.0.1 (i use 192.168.1.1 for my customers) reboot the router and reconnect it to the modem. the ip conflict should now be resolved.
Feb 07, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Can Connect to internet via cable modem, but cannot connect from Cable Modem to LinkSys WRT54G router to PC to Internet ?
1. Make sure your cable modem is connected to the Internet port of the router.
2. Your computer should connected to one of the 4 ports at the back of the router.
3. Check the lights that are lit. Make sure the you have power(steady green), Internet, WLAN and Ethernet port light.
4. Press and hold the reset button on the router for 15 seconds.
5. After 15 seconds, release the reset on the router and turn it off.
6. Turn the cable modem off, too.
7. Wait for a minute. Turn the modem ON first. Wait for the lights on the modem to be ready.
8. Turn on the router. Make sure you have good lights on the router.
9. Check for Internet connectivity.
Nov 08, 2008 | Computers & Internet
Vista/router/wireless connection
Make sure that all the wireless cards are set in the properties to obtain an ip address automatically, dissable the wired lan adpter connections as this can confuse the router. Restart all the pc's and then right click on the wireless pc icon in your task bar and then click view wireless networks and make sure that you are connected to your network and that the internet is available, known as local & internet in Vista. open up internet explorer, go to tools, internet options and delete browsing history cookies and temp files and then refresh the page as the proxy server will need to refresh.
Sep 24, 2007 | Computers & Internet
Linksys Wireless-G WRT54G Router Logo
14 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
