Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
We had a leak and unhooked the hose to the refrigerator. After fixing the leak, we rehooked the hose but we are not getting any ice cubes. The water is getting to the refrigerator because we get water to the door.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 113 Answers
You probably have a frozen water tube - the tube where the water comes out into the icemaker, on the inside. If you had water trickling down that tube due to air in the line then it could have frozen. I've seen this before. Check it out and defrost with a hair dryer if this is the case.
Posted on Oct 24, 2010
SOURCE:
Water is leaking into the ice tray freezing all the ice cubes together
That maybe it or it may be your preception, If the heater in defrost is over heating during the defrost cycle you can get the same results
Dec 17, 2017 | KitchenAid Superba KSRG25FK Side by Side...
Ice cube tray does not fill up water feeding tube is frozen.
The problem you are having is caused by water leaking past the=> MJX42111401 Water Inlet Valve Change the MJX42111401 Water Inlet Valve and this will solve the water freezing between ice harvest. On most refrigerators this part can be found on the back of refrigerator and near floor, Let me know if you have other questions, Thanks Sea Breeze
May 24, 2012 | LG LSC27910 (265 cu ft) Side by Side...
I have a Maytag frid m#PBF2255HEW (bottom freeze w/ice maker. My ice marker currently works but after dumping a tray of ice it "leaks" water into the tray causing all of the ice in tray to be one...
Sounds like the water inlet solenoid is getting stuck open, this is assuming you ice cubes are normal to large in size, Small would indicate the ice maker is leaking, You can try just replacing this valve , It's the valve that connects to the water hose behind your refrigerator and is fastened to the lower corner of refrigerator. Otherwise you can purchase the entire ice maker and solenoid kit for around 65.00 Hope this helps
May 18, 2011 | Refrigerators
Ice maker or supply line leaking water at icemaker
Hello Carltomoree,
Interesting question(s)...
Problems COULD be a lot of things... but since you have gone to all the trouble to locatize A PROBLEM... I would LOOK
right there first... and fix that...
PLASTIC FITTINGS do often split and fail... or simply need to be reseated and firmly tightened... (do not overtighten).
Water valve... too strong... (probably not)...
BECAUSE a leaky water delivery can have
a profound effect on the fill of the ice cube tray...
Allow the refrigerator to stabilize... SEVERAL DAYS
and then start worrying about the fill level...
Ice makers are TYPICALLY adjustable for different water flows.
so the amount of water delivered per cycle... or delivery of small cubes ... even the frequency of delivery can usually be adjusted
Worry about that LEAK first.
Check out the link below...
A whole new head is still available for your refrigerator
but wouldn't it be nice if it were only an inexpensive
PLASTIC coupling or a split PLASTIC feeder tube...??
Partselect
http://www.partselect.com/AdvancedModelSymptoms.aspx?ModelNum=ZFSB27DAGSS&mfgModelNum=&fkMfgID=2&Source=msac&term=ZFSB27DAGSS&utm_source=adcenter&utm_medium=cpc&utm_term=ZFSB27DAGSS&match=p&utm_content=m830071057&sw=zfsb27dagss+parts&ModelMasterID=110865&PID=13
appliancepartspros repair-help
http://www.appliancepartspros.com/repair-help/general-electric-refrigerator-zfsb27dagss-repair/zfsb27dagss-leaking.html
repairclinic: whole head kit
GE Refrigerator Ice Maker Assembly WR30X10093
Carnac the Magnificent
Jun 23, 2017 | GE Refrigerators
LG ICE MAKER
Be sure that the fill tube is getting into the ice maker and that the ice maker is not blocked with ice.  If everything seems ok, you may have a leaking water valve which causes it to constantly drip water into the ice maker causing the block of ice.
May 16, 2008 | LG LFC25760 French Door Refrigerator
Hollow Ice- Slow Ice!!
Hollow ice is a dead give away that there is not enough water filling the trays. Check that the line isn't pinched from pushing the unit back in place, etc. Also check any filters or filter screens in the water line to the ice maker.
Jan 13, 2007 | Kenmore 55692 / 55694 Side by Side...
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
69 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
