Question about GE Profile PTS22LHSCC 33" 21.7 Cu. Ft. Top-Freezer Refrigerator w/ Internal Water Dispenser, Climate...
Refrigerator is on; fan is working. I took off the rear panel and cleaned dust and noticed the compressor was very hot.
  • GE Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 25, 2010
SOURCE:
Maytag Refrigerator fan came loose, not cooling now
Yes, the compressor can burn up. I would replace the whole fan/motor assembly.
May 14, 2012 | Maytag MSD2542VE Side by Side Refrigerator
Maytag MTF1895AEW Not Cooling
Sounds to me the compressor start relay=> 63001003 Overload=> 63001004 and Run Capacitor=> 63001005
needs replaced, the clicking noise indicates that that is the problem, Sea Breeze
Feb 16, 2012 | Maytag Refrigerators
The center of the fridge where the doors seal is very hot. Took of back cover, coolant lines are extremly hot compressor making buzzing sound.
When you were at the back behind the compressor did ya notice that the fan thier by the compressor was running, what will make that center divider bar very hot (it's normal to be warm) is due to the fan by the compressor not running or the coil also near the compressor being clogged with dust. So check that fan and replace if not running and also be sure to clean that coil free of all the dust ( the coil should be cleaned every 6 months as normal maintiance)
GENE
Oct 04, 2011 | Whirlpool GD5SHAX Side by Side...
Panel between refrigerator and freezer stays extremely hot. Continously running. Thinking it may stuck in defrost cycle.
I believe the problem is going to the coil on the bottom behind the grill below the door OR on the back behind the rear plate by the compressor is clogged with dust and needs to be cleaned of all that dust/pet hair. Also on the rear check that the fan by the compressor is running
when the defrost is on the compressor&both the freezer and rear fan is OFF so its not stuck in defrost.
Gene
Aug 24, 2011 | KitchenAid Refrigerators
My whirlpool fridge is hot, took the cover off of the coils inside freezer, look ok. Took back cover off of the back and the compressor is hot
Hi jason;
Shall take it that you have a Side by Side setup? If so with rear cover off, when you start it does the cooling fan come on beside compressor? Also remove front grille and clean front condensor coils, full dust and hair all problems can happen. (like blocking of car radiator). Try these if fan doesn't work, replace.
Mar 28, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
The wall between the refrigerator and freezer is extreemly hot!! The rubber seal is so hot that it is becoming flat.
Pull the refrig out and remove the rear panel . Check the fan motor which cools the compressor , for any obstruction . If not running , and no obstruction , replace . Also check the coils in front , to make sure they are clean from dust , pet hair , etc .
Oct 01, 2009 | Whirlpool Refrigerators
The panel between the freezer and refrigerator heats up - too hot to touch for a while then cools off again. GD5SHAXLT01
You need to clean the coils under the front of the refrig of dust , lint , pet hair , etc . Pull the refrig out and remove the back panel covering the compressor . Make sure the fan there , next to the compressor is working . Usually , if this fan is not working , the center strip gets very hot , and the compressor may cut off , from getting too hot . The compressor can burn out , if the fan doesn't work for a while .
Sep 13, 2009 | Whirlpool ES5FHAXS Side by Side...
Maytag refrigerator MSD2758GEW divider panel hot to touch
What you could check is that the fan at the back of the unit, where the compressor is located, is working, as this could also cause a heat build up. The partition between the two sides does generally tend to get hot due to the door circuit, to prevent ice buildup around the door. But people tend to notice when something is different. You are also right to check for dust underneath the cabinet as the condenser tends to be layered. If you have already cleaned it all out then you have probably done as much as you can. If you are still concerned contact a fridge guy. Hope this is of some help.
Sep 12, 2007 | Maytag MSD2758GEW
Kenmore Side by Side Refrigerator 1999
It is normal for that to be warm but not hot. you need to make sure that the condensor coils under the refrigerator is free of dust. You can get to it by removing the back cover and clean it with a vacume. Also make sure the fan at the compressor is operating. and also clean the fan blades while your there. Doing this and making sure the fan is working should solve your problem. Also in the summer time when its hot and humid the refrigerator has to work longer and harder to keep it cold. so you may notice the front just a little warmer then usual, but it should not be hot that you cant touch it. God luck
Jul 09, 2007 | Kenmore 44109 / 44102 Side by Side...
Compressor and water are hot!
re-charge the freon. this will cool it down.
May 31, 2007 | Hotpoint HSS25GFP Side by Side...
GE Profile PTS22LHSCC 33" 21.7 Cu. Ft. Top-Freezer Refrigerator w/ Internal Water Dispenser, Climate... Logo
59 people viewed this question
Top Refrigerators Experts
Brad Goodale
Matt Sicignano
Level 1 Expert
JP Meneide
JP Meneide
