Question about Karcher PSI Electric Pressure Washer
Hello I just borrowed a k archer k 2.87 water blaster from a friend and forgot to turn water on before starting motor. Motor stopped after a few seconds and now won't start. Online guide says to change fuse but nz version doesnt have fuse in plug. Do i have to take machine apart?HELP Please!
    Scholar:
  • 100 Answers
Most of the time it is the GFCI on the end of the plug that goes bad. If it were me I would cut off the GFCI and wire in a standard 120v plug. If it still doesn't work after that then there is a good chance that something electric internally has gone wrong which isn't going to be worth repairing.
Posted on Oct 25, 2010
SOURCE:
Window will not roll up on 2003 GMC Yukon Denali AWD
there are cables inside of the window assembly that are connected to a pully on the window motor. it could be that the wires are tangled. it might need a new regulator, i think the motor would be fine.
Jan 14, 2014 | 2003 GMC Sierra 1500
Shallow water pump keeps stopping
new pump --not big enough for the job
old pump --motor windings problem, faulty start run capacitor
I suspect that as the motor is 1/2 hp if will run good when there is a need for water but under pressure the pressure switch is set to high so the motor overloads and gets hot
Mar 24, 2017 | RTO Wayne 1/2 Hp Shallow Well Jet Pump
You asked: My car was running find, a little rough. Took it to a friend to have the spark plug changed and wires. Degreaser was sprayed on motor then rinsed with water when done driving home about 1 mile,...
Try cleaning the throttle valve and idle speed control motor with throttle valve cleaner and then diconnect the battery for 5 minutes and drive it for a few days.
Apr 21, 2013 | Ford Escort Cars & Trucks
.1650w water blaster's electric motor cuts out as soon as the water is turned on on
I'm sorry but I believe you have this posted in the wrong product category? Please re-post the question in the proper category if this is the case, otherwise you have my apologies. This is the car and truck problem category
Aug 08, 2012 | Cars & Trucks
My 1987 ford f150 will not start motor will turn but not start i have changed fuel pump fuel relay fuel filter.
Hello joey227, I had a very simular problem a few years ago with an 89. I had to get a new distributor.
Good luck my friend!
Jan 13, 2011 | 1987 Ford F 150
The Pump overheated
IS IT'S A STA RITE CHANCES ARE THE PUMP CAN BE SAVED. IT WILL NEED A NEW IMPELLER,SHAFT SEAL AND DIFFUSER. THESE ARE TUFF PUMPS. BRING IT TO YOUR LOCAL POOL PUMP MOTOR REPAIR GUY .. USE YOUR ZIP-CODE IN YOUR SEARCH ..PUMP REPAIR IS THE GREEN THING TO DO AND IT SAVES YOU MONEY ! . PLEASE VOTE GUYS-N-GALS
May 05, 2010 | A.O. Smith SQ1102 Pool Pump Motor
Was using the SteamVac and it just stopped doing
Bad news! The humming is the pump so it is still good, but that means either the ac to dc converter is bad or the motor went up. The good news, neither would be your fault.
Apr 16, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Dishwasher starts to fill then just hums
Sounds like a motor problem. Behind the chopper is an access to the impeller, try turning the impeller or the chopper blade and see if the motor will rotate. If it doesn't, then something is stuck preventing the motor from running.
Mar 07, 2009 | Dishwashers
New timer on my washer still won't cycle properly.
SOUNDS LIKE THE MOTOR THAT ADVANCES THE TIMER IS NOT WORKING OR NOT GETTING VOTAGE TO IT. CHECK VOTAGE TO TIMER MOTOR
Jun 01, 2008 | Frigidaire Washing Machines
Karcher PSI Electric Pressure Washer Logo
561 people viewed this question
Top Karcher Garden Experts
Martin Grech
John Trevino
JOHN LAPIER
Are you a Karcher Garden Expert? Answer questions, earn points and help others
