Question about Homelite Consumer Products Backpack Blower/Vac, Carb
Homelite backpack blower ut08083 or ut08111 engine surges up and down after warm up.lplug and airfilter fine
  • 22,484 Answers
Could be two things from description the first is the carb needs a clean out and the second is the metal flap behind the engine cowl has corroded awy reducing its size ,most likely is the carb though as its one of them funny ones designed to work at any angle like a chain saw.So firstly try cleaning the carb out and see what happens ,these always get choked up when not used regular as when put away teh carb isnt drained so petrol evaporates leaving a fine white coating which can and does block the jets up
Posted on Oct 24, 2010
SOURCE:
Backpack II. How do I replace the primer bulb?
  1. Homelite Blower UT08072 User's Guide ' ManualsOnline.com
    lawnandgarden.manualsonline.com > ... > Homelite Blower OPERATOR'S MANUAL. BACKPACKER II. UT08072 and UT08572. SAVE THISMANUAL FOR FUTURE REFERENCE. Your blower has been engineered and ...
Jul 20, 2015 | Homelite Garden
I need a gastank for my homelite-backpack leafblower, model#uto8580a.It leakes around the screw that holds it own. This is the second time i've had to replace it. There must be a defect in these.
There is a recall for leaking fuel tanks on your unit.
The Homelite #UT08580/UT08580A Backpack blower service recall and all related questions and issues, are being handled through the Homelite customer service phone staff at 1-800-242-4672, for records purposes.
Aug 22, 2011 | Homelite Consumer Products Backpack...
Bogs down at full thouldel tryed to adjust carberator
Hi
This is either a clogged muffler or carb. Take the off and see if it will rev. If not you need to clean carb and install a carb repair kit. Do not run long with muffler off.
Sam
Jan 06, 2010 | Homelite Consumer Products Backpack...
How do I adjust needle valves on a 25cc Homelite UT08111A Backpack leaf blower?
Set the lowend & highend needles to about 1 3/4 to 2 turns each. Choke the carb or prime it, until the carb is wet. Fire up the engine and let it warm up. Let's set the topend first since it's the easier of the two. Go to full throttle. Adjust the topend needle for peak RPM. Leave it wide open for about a minute to see if it changes any. Should the engine go lean, open the lowend needle slightly, if this dosen't work... you will have to adjust the needle valve inside the carb.( I will explain this later) If the topend runs OK, then slowly pull the throttle down until the engine begins to "four cycle" hold the throttle there. Adjust the lowend needle until the "four cycling" barely stops. Now lower the throttle more until it "four cycles" again, and adjust the lowend again. Keep doing this until you reach full idle. Now, from full idle begin to throttle up until the engine starts to bog or hesitate. Open up the lowend needle just enough to eliminate the bog or hesitation.
http://tech.flygsw.org/walbro_tuneup.htm
hope this helps :)
if it does please vote
Oct 23, 2009 | Homelite Consumer Products Backpack...
THE ENGINE RUNS FINE FOR 10 SECONDS THEN KIND OF DIES OUT BUT WILL THEN RUN FINE FOR 10 SECONDS AND THEN DIE OUT
Try replacing the in-line fuel filter, the Air Filter and Spark Plugs. Also make sure that you are using the proper start up procedure. In many cases that means using the highest choke setting until the engine tries to start, then going to the next choke setting and so forth until you get to no choke. It is imperative that you let engine run for at least 5 minutes before use to warm up. This will ensure a longer life and consistent running.
Oct 06, 2009 | Homelite Consumer Products Backpack...
Homelite blower UT08111 the bubble for the primer will not push
Remove and disassemble carberator clean with gumout solvent (wear safety glasses when spraying) blow out all small holes and passages in carb then reassemble check primer bulb function.
Sep 11, 2009 | Garden
Homelite 26bp backpack won't run up to full throttle
I have let my leaf blower run and warm up before throttling up and still it bogs down and shuts down. There is no air cleaner to clean should I just blow out the carb. and fuel lines?
It runs and idles just no high speed to blow.
Nov 16, 2008 | Homelite Consumer Products Backpack...
Blower runs fine for 30 or 45 mins, then will not come up to speed.
there is a fuel filter in the fuel tank that some times gets cloged try that and fresh gas -oil mix
Nov 01, 2008 | Homelite Consumer Products Backpack...
Homelite Consumer Products Backpack Blower/Vac, Carb Logo
1,213 people viewed this question
Top Homelite Garden Experts
roeb
Randy Schumann
Randy Schumann
lnbn1975
Are you a Homelite Garden Expert? Answer questions, earn points and help others
