Question about Zenith Watches
Zenith port royal 12/59.3150.226 i have inherited can you tell me the value
2 Suggested Answers
SOURCE:
SOURCE: i need manual, information for zenith el primo
i need manual, information for auriol 1-LD2550
Posted on Jun 24, 2010
I inherited a Tommy Bahams RLX 1122 A126 watch with expansion bracelet. Does it have any value?
Most of the TB1126 are selling for between 30 and 60 dollars.
Aug 25, 2018 | Watches
How much is this Nautica watch the dial turns and the face is dark royal blue
Dale, Google search your make and model # to find watch value.
I found no nautica watches with that exact outside dial. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Amazon ca watch nautica men Watches
http://nauticawatches.com/
Metal Bracelet
https://www.google.ca/search?q=Nautica+watch&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwi_8NiisIjOAhUlyoMKHVh0CeIQsAQIZA&biw=1024&bih=681
Jul 23, 2016 | Nautica Watches
Need to find the value of an old Piaget watch that I inherited. The numbers on the back are stamped as follows: 6801 E 10 228916 the band says Piaget 750 thanks Rani
mcdevito75 Here, Hello Rani, Piaget, a FINE watch, even without seeing your Piaget watch were speaking $250.00 and above. Shop a couple of jewelery shops in your area, they will be glad to help. NOTE-- unless you relly know, DO NOT CLEAN THAT PIAGET YOURSELF as any Damage could and would leesen it"s value. By cleaning I mean even polishing the band, have a small watch repair shop in your area care for your Piaget watch.
Jul 07, 2010 | Watches
I need manual, information for zenith el primo port royal
Jun 24, 2010 | Watches
I'm trying to find out what is the current value for a Gucci 3800L ladies watch
mcdevito75 here, Without seeing the watch itself, very hard to tell, the age and condition and of course how well it"s working all count towards it"s value, although GUCCI is a powerfull name in watches all the mentioned factors count toward any watches value. I would figure your Ladies GUCCI watch is valued any where between the $250.00 $350.00 range. Check with a local Jeweler in your area also, for your watches value.
Jun 22, 2010 | Watches
Tag heuer automatic series, how do you start the watch after purchasing?
push the crown in if it is in the adjust position .then shake the watch around the auto mechanism sould start the watch
Aug 23, 2009 | Tag Heuer Automatic Chronograph Series...
American Waltham pocket watch
Ebay often has these for sale; one I also inherited in an 18K gold 'hunters case' (closes from and back) even though perfectly working after a retired jeweler brought it back to life, turned out to be more valuable for its case than anything else. I've seen similar at swap meets/flea markets in plated cases for as little as $70 and still ticking.
Jul 25, 2009 | Watches
Stopped running
Unfortunately watch service is often calculated based on the value of the watch, as insurance, and quality/cost of materials and spares and tools are factors. With the correct lubricant there should be no reason why a quality watch should need that particular job done so regularly, but a 4/5-yearly service is not a bad idea at all, as most problems with this sort of watch can be avoided with regular maintenance. Hope this helps :)
Jan 10, 2007 | Ebel 1911 9080241 wristwatch
Watches Logo
203 people viewed this question
Top Zenith Watches Experts
Janelle Schoonover
Janelle Schoonover
Marvin
Marvin
Are you a Zenith Watch Expert? Answer questions, earn points and help others
