Question about Canon PIXMA MP460 All-In-One InkJet Printer
Can't scan I bought all in one Pixma MP460, do I need to install MP Navigator ? How to use it with my PC.
Yes u do need to install it!!
Posted on Jul 05, 2008
How does scanning work? I can't get past the bit that says 'set the pc to start scanning'. On my old printer you just had to press the 'scan' button, why does it need to be more complicated? Why...
I have found these and hope they might help you.
Here is the User Manual Link:
https://www.canon.co.uk/support/consumer_products/products/fax__multifunctionals/inkjet/pixma_mg_series/pixma_mg5350.aspx?type=manuals&language=
OR maybe this may help:
How do I get my Canon Pixma to scan?
Just follow these instructions.
Install the MP Navigator EX software located on the disc that came with the printer. ...
Select "Start" > "Programs" > "Canon Utilities" > "MP Navigator EX" > "MP Navigator EX".
Select "Photos/Documents".
Open the top of the scanner and place the document you wish to scan on the glass.
Dec 21, 2017 | Canon PIXMA Office Equipment & Supplies
I'm trying to scan a document into Adobe PDF. I have Adobe on my operating system but it's not coming up as option to select when scanning the document. Any suggestions?
All you need to do is use the MP Navigator. With that up and running you simply scan all the images then choose the save as PDF option. You only need the Adobe on your system to read the file, not to create it.
The Navigator will allow you to create and correct the images into a multi page PDF. It should be on the instalation CD if you have not loaded up Navigator.
Apr 23, 2011 | Canon PIXMA MP460 All-In-One InkJet...
How do I access mp navigator 3.0
When you installed your printer software, a folder called "Canon" should have been created; probably under "Programs" . Inside the Canon folder is a file cal;led MP Navigator EX3.0 (actually mine is MP Navigator EX2.1). Inside that file is a program called MPNEX30 (again, mine says MPNEX21). Double click on it and you should be in business. If you don't have the file, download it from the Canon website http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp460#DriversAndSoftware
Nov 15, 2010 | Canon PIXMA MP460 All-In-One InkJet...
I want to scan a document with my MP 180, need the steps to do it with the controlls that are ON the printer please...
For the MP 180, assuming the all-in-one is connected with a good USB cable (and port) that gives full bi-directional data transfer and that the computer has the full software installed, press the Scan button (third button from the left) then Press Black or Color (depending on your document). Then the MP Navigator should open on the computer and then scan into the software.
I hope this helps.
Mar 23, 2010 | Canon PIXMA MP460 All-In-One InkJet...
How do you get the Canon Pixma mp500 to scan?
Scanning images,
About Scanning images
You can scan images from the machine to a computer without printing them and save them in popular formats. Scanned data saved on your computer can be processed using image processing software. Furthermore, you can use the OCR (Optical Character Recognition) software to convert scanned paper documents to text data.
* Before scanning
Before scanning images, confirm the following :
- Are the necessary software (MP Drivers and MP Navigator) installed ?
If the software is not installed, install it.
- Does the document to be scanned meet the requirements for an original to be set on the Platen Glass ?
- Is the machine connected to a computer correclty.
Confirm that the connection between the machine and the computer is physically secure.
Scanning Methods.
A) Scanning Using the MP Navigator
MP Navigator enables you to scan in documents loaded on the Platen Glass and view images saved on your computer or on a memory card. Scanned documents can be previewed and easily printed and edited according to your needs.
You can use the supplied application softwares to edit or print the document you have scanned.
Windows : Double-click the [MP Navigator 2.0] icon on your desktop to launch MP Navigator.
Mac : Select [Applications] from the [Go] menu, then double-click the [MP Navigator 2.0] icon to launch MP Navigator.
You can launch the following application software from the MP Navigator.
* Easy-PhotoPrint (Photo Printing)
* ArcSoft PhotoStudio (Photo image editing)
* ScanSoft OmniPage SE ( Converting scanned document to text)
- This application software may not be supplied with teis machine in some country.
Note : If you did a [Custom Install] and only installed the MP Driver and MP Navigator, these application software were not installed and thus cannot be launched. To launch any of the above application softwares from MP Navigator, do a [Custom Install] once again to install them.
For detailed operations of the MP Navigator, refer to the Scan Guide.
B) Scanning Using the Operation Panel of the Machine
You can scan documents to your computer by using the Operation Panel.
Important : Do not insert or remove USB cables when scanning images with the machine connected to a computer, or when the computer is at sleep or standby mode.
*If you are using Windows XP
The program selection screen is displyed the first time you press [Color] or [Black] on the machine.. Specify the [MP Navigator 2.0] as the application software to use, check [Always use this program for this action], then click [OK]. From the next time, MP Navigator is automatically started.
*When using Mac OS X
For the machine to start scanning when [Color] or [Black] is pressed, you need to set MP Navigator as the starting application software in Image Capture under [Applications] of Mac OS X.
1) Press [ON/OFF] to turn on the machine.
2) Load the documents on the Platen Glass.
3) Select the scan option.
a) Press [Scan].
The scan operation selection screen is displayed.
b) Use Up or Down arrows to select the scan operation, then press [OK].
Scan standby screen is displayed.
Save to PC : The document is scanned and saved.
Save as PDF file : The document is scanned and stored as a PDF file.
Attach to E-Mail : The document is scanned, and the image is attached to an e-mai using the e-mail application software.
OPen with application : The document is scanned and displayed on the registered application software.
4) Press [Color] or [Black].
The document is scanned. The settings configured from MP Navigator apply when scanning.
Important : If with some types of original the position and size of the image is not scanned in correctly, please refer to the "Selecting the Behaviour of the Operation Panel with Mp Navigator " in the Scan Guide (on-screen manual). and change the MP Navigator [Document Type] and [Document Size]] to match those of the original being scanned.
Note : The operation to be performed after scanning the document depends on the scan operation setting you have selected in step 3. For details on how to modify the operation settings, refer tp the Scan Guide on-screen menual.
C) Scanning from an Application Software
You can scan an image from TWAIN-or- WIA (Windows XP only) complaint application software and handle the scanned image in the application software. For detailed operations, refer to the Scan Guide (on-screen manual).
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Dec 07, 2009 | Canon Pixma MP500 All-In-One InkJet...
I can't scan anything from my MP 460
had probs with scanning at first
1.put doc in scanner
2.push scan
3.choose color or black
4.press scan again
thats what i did works ok
Nov 15, 2007 | Canon PIXMA MP460 All-In-One InkJet...
Scanner
are you pressing ok on the printer? all of your scanning should be done via the MP460 navigator. check your applications under the Canon Utlitiy and click on the MP460 Navigator button. scanning needs to be done via that - not the actual printer. refer to the dialogue box when you are on the MP460 navigator. lower left area has a Save bar, when you click on it tow options: save to PC or save as PDF.
Sep 06, 2007 | Canon PIXMA MP460 All-In-One InkJet...
Canon PIXMA  MP460 All-In-One InkJet Printer Logo
59 people viewed this question
old marine
old marine
