Question about Hoover Washing Machines
I have a hoover classica 1100 the program dial is lose so not filling up
Http://service.hoover.co.uk/content/manuals/AC158.pdf
Posted on Nov 20, 2012
SOURCE:
Why won't my machine stop filling?
replace water level sensor
if less than 5 years old
should be able to get the part from a washing machine repairer
or hoover washing machine parts supplier
Apr 16, 2017 | Hoover Washing Machines
Cycle stopping after filling with water on hoover oph 148
the heater may not be working or you have a broken wire
Dec 31, 2013 | Hoover Washing Machines
Hoover 5oom overflows when filling
Check to make sure the the tube that runs from the top panel down to the pressure weir on the side of the outer drum is in place, These can come off with vibrations, if this is ok your pressure/level dial needs to be replaced.
Mar 05, 2012 | Hoover Washing Machines
My washer will not fill with water or do any functions when i turn the dial
My Hoover 7700l ...on "fill" cycle, the water dribbles in. Takes hours to fill so we use buckets to reach the required level.
Tried: Swapping cold and hot water inlet hoses, making sure that dial is in "hot". This solved the problem for filling, BUT when "rinse cycle appoars, it's back to the dribble again.
any ideas?
Jan 23, 2011 | Maytag LSE7806A Top Load Stacked...
Hoover performa 1100 ac110 not emptying
After syphoning water out of drum, remove and clean filter located at bottom front left of washer, if there is a screw in the filter cover, unscrew this first.
Remove filter by unscrewing anti-clockwise.
Feb 06, 2010 | Hoover Washing Machines
Hoover classica washer won't spin
If it doesnt spin when manually turned to that position you have a component failure. You obviously do not understand enough about the problem to assess the fault so for your own safety and security and peace of mind get a Tech in who does.
Oct 19, 2009 | Washing Machines
Washine machine fills but drum does not turn
hoover hd 1400 aaa motor turns and so does drive belt but the drum doesn't? what is the problem?
Sep 25, 2009 | Hoover Washing Machines
Washing machine wont fill with water-hoover performance 1100
check that the water inlet pipe is not blocked. it does have a filtewhich can get blocked with lime scale.
Dec 27, 2008 | Washing Machines
Hoover quattro system 1100 ab power jet as 110
I had the same problem when i got my machine, if you slide out the powder and softener tray just behind the face of it on the right hand side you will see a white plastic tab about 2 inchs wide! That plastic tab slides out and has all the programme settings on it!
Aug 08, 2008 | Hoover HC6 110M Front Load Washer
Washing machine problem
I have a performa 1100. No 4 is the 40 degree is the normal cottons cycle which is the one I use. Tip- only fill the drum 3/4 full otherwise it struggles to drain and spin- I know!
Jan 21, 2008 | Hoover PE235 Front Load Washer
Washing Machines Logo
64 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
Poppa Maddo
Poppa Maddo
jimorris77
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
