Question about GE Refrigerators
I have a old ge refrigerator tbx22zIbbrww is there a drain plug an where located water draining inside
    Guru:
  • 1,524 Answers
Usually at the bottom of the freezer. You may need a drain line heater.
Posted on Oct 24, 2010
Testimonial: "thanks for the info"
SOURCE:
Where is the draining hole in a ge profile model tbx25pa refrigerator with top freezer
Underneath the cooling coil (evaporator) located in the freezer, there is a drain pan with a heater to warm it during the defrost cycle. The drain opening is probably blocked by ice or debris.
Sep 26, 2014 | GE Refrigerators
Have 20 yr old GR refrigerator and the drain tube may be plugged. We tried cleaning it but water is still dripping to bottom of frig. What should we do?
Sometimes there is a grommet between the inside and outside of the refrigerator especially on older GE refrigerators. If you look at the back of the refrigerator and there is a grommet on the back with a tube coming from it then that is what you have. GE put a trap in the grommet and you will more than likely have to pull this off and flush it out. It should be fairly easy to pull it out and push it back in.
Other than that you will have to pour hot water in the drain until it thaws out.
Aug 16, 2014 | GE Refrigerators
Ge profile bottom freezer
i used a turkey baster to blast hot water through the drain to the pan took a few tries but it worked. sucked up all the old water first then gave it a good hard shot.
May 16, 2013 | Refrigerators
Oo.comI am getting water in the bottom of the refrigerator enough for it to leak out the front and spill onto the floor. I believe it is coming down the back wall. How can I fix it?
the drain hole for the evaporator drain pan is plugged,you need to remove rear panel in freezer inside wall,thaw out any ice in the drain hole located under the evaporator coil,then take a small wire and rod-out this drain hole till you get water coming out the end of this tube at the pan located near the bottom of the machine near the compressor
Apr 10, 2011 | GE Refrigerators
I have an 8 year old GE Profile Side by Side TPX24PB Refrig that is leaking water in the freezer, but not the refrigerator. There is a slab of ice on the freezer floor, eventually water runs onto the...
The drain is clogged. Remove the bottom bin out of the freezer. Once done you should see a trough at the back. This trough will be filled with ice, remvoe the ice. Then you have to clear the drain. The best way I know of to do this is to force hot water down the drain with a turkey baser untill water flows freely. Then mix baken soda with water and pour it down the drain. http://www.appliance-repair-it.com/refrigerator-leaking.html
Sep 24, 2010 | GE Profile TPX24PBDCC Side by Side...
Ice maker leak in GE refrig.
when the refrig.goes through a defrost cycle the water from the melted ice is supposed to go out a drainline to a pan inthe back.most likely the drain has plugged up and needs cleaning.remoe shelving andtake back panel off drain hole is located below coils,be carefull of coils ,delicate
Jan 22, 2010 | Kenmore 53642 / 53644 Side by Side...
My side by side for some reason has water coming out from under it..i check the water feed line and its good!I then checked the drain plug in the frezzer and noticed the whole bottom of the frezzer had...
What is a "drain plug"??? Never seen one on a fridge ;)
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. Make sure water drains when you pour it in.
Good luck! :)
Vlad
First Choice Appliance
Dec 21, 2009 | GE GSS20IEP Side by Side Refrigerator
Water from GE Profile Refrig/freezer drips down back inside freezer wall and fills up, bypasses drain and fills up and leaks into floor.
Hi, Is it bypassing the drain or is the drain plugged? The most common is that the drain hole gets iced up and them overflows onto the floor.
Just wanting clarifcation.
Jul 12, 2009 | GE Profile PSW26P Stainless Steel Side by...
10 yr old GE side by side: freezer is leaking
Your drain is frozen up and so every time unit goes into defrost the water refreezes in the freezer's bottom. You either have to shut fridge off completely and let it dethaw or use hot water and an ice pick to hurry up the process. The drain is located in the very back of freezer. You will have to pull out the bottom drawer to see it. Good luck
Jun 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
REFRIGERATOR dRAIN stopped up
LOOK INSIDE THE BACK TOP OF THE REFRIG. SEE IF THE DRAIN CHUTE IS THERE,IF YES YOU CAN USE A HANGER TO UNCLOGG IT.OR PULL OUT FROM WALL AND LOCATE DRAIN HOSE AND **** IT OUT WITH A SHOP VAC.,OR IF DRAIN IS NOT IN FRIG.REMOVE PANEL IN FREEZER AND THE DRAIN SHOULD BE IN THE MIDDLE BACK BOTTOM,IF FROZEN THAW IT OUT WITH HAIR DRYER,THANKS-MIKE
Mar 30, 2008 | GE Profile Arctica Stainless Steel Top...
Refrigerators Logo
208 people viewed this question
Top Refrigerators Experts
Brad Goodale
Matt Sicignano
Level 1 Expert
JP Meneide
JP Meneide
