Question about Microsoft Xbox 360 Console
I have started a local (small) xbox 360 repair shop. The new problem I have run Into is this. I get the green rings and audio, but no video. What do I need to check?
  • 1,139 Answers
Have you tried resetting the display by turning the console on by holding the home button on the controller. As it starts up press and hold Y and the right trigger until the display inisitalizes.
Posted on Oct 24, 2010
SOURCE:
I was playing splinter cell blacklist on my XBOX 360 S. I saw the four red lights (full ring) on the console's power button. The screen turned blue! I took out the chords and all. Then after about an hour...
What you saw is what is called the Red Ring of Death. Microsoft charges for support in such cases however, most people will just replace the xbox as it is cheaper. You can find out more information on the 4 red rings on the Microsoft website. For the most part, the 4 red rings are based on overheating of your processor. Which means you might need to go and purchase yourself a new xbox. I found this site that might help somewhat, it gives a list of error codes and more information. Hope this will help.
http://www.llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Sep 03, 2013 | Microsoft Xbox 360 Console
I was playing Oblivion on my Xbox 360 and after a few minutes the screen went gray and the sound stopped. I didn't have any rings of death so I turned off my console and tried again. The console turned...
Your graphic card is failing on you, only option is repair your system through either microsoft or a local repair shop. Repairing the graphic card is not a simple repair as its not replaceable.
thanks
www.1RepairStop.com
We Fix Everything
Sep 01, 2011 | Microsoft Xbox 360 Console
My xbox 360 will not show video. only audio. I'm using composite cables. It wont work directly to the tv, or through an RF modulator. I've even tried a new cable from the xbox to the tv. ps2 is working...
The problem is you have a broken video
line feed under the G.P.U.
The solution is to have the G.P.U. reflowed
(resoldered) .Many shop preform this type of
repair .Cost will very 50.00-80.00 . This
will produce the most durable repair.
Shop around for someone local and except
nothing less then a 90 day warranty
if you have any questions feel free to ask.
Rob
Aug 23, 2010 | Microsoft Xbox 360 Console
Controller wont hook up with console ?
Is this a new controller?
Are the batteries new/recharged?
This is the sequence summary on where you are going to focus:
Step 1 - Controller
Step 2 - Console
Step 3 - Console
Step 4 - Controller
Step 5 - Both
Assuming your controller is a wireless version, Lets start!
Step 1 | Press and hold the Xbox Guide button until the controller turns on. The Xbox Guide button is the round button with the green "X" near the center of the controller.
Step 2 | Make sure that your Xbox 360 console is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console.
Step 3 | On the Xbox 360 console, press and release the Connect button. The Connect button is the small round button on the Xbox 360 console.
Step 4 | On the controller, press and release the Connect button. The Connect button is the small button on the front edge of the controller, between the left bumper button and the charging port.
Step 5 | After the Ring of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
Light indicator on console
Green light in the center- power is on
Green light on one quadrant - controller is connected
Four green lights rotating on four quadrants - ready to connect with controller
Light indicator on wireless controllers
No lights - no batteries
Green steady light on one quadrant - connected
Blinking green lights - its either its ready to connect or the batteries are dying
*Make sure that you have a fully recharged rechargeable batteries
*Make sure that you have a functioning/new non-rechargeable batteries
*If the steps above aren't working use another Xbox360 controller and follow the same steps.
If the new/working controller is connecting with the console this means that the previous controller is faulty - needs replacement.
If the new/working controller is not connecting with the console this may mean that the console is faulty - needs repair.
*NEVER TAMPER WITH ANY OF THE TWO AS TAMPERING WILL VOID EXISTING WARRANTY.
Nov 23, 2009 | Microsoft Xbox 360 Console
XBOX360 No Audio, No VIdeo, Solid Green Light
the G.P.U has more than likely detached from the main board.
the x clamp mod is more of a diagnostic procedures than an
actual repair function. The G.P.U will need to be re-flowed to
the main board then lightly but firmly clamp to the board
then stress tested (force it to run hot for 15 min shut off and
repeat 3 times)
that's it
Aug 23, 2009 | Microsoft Xbox 360 Console
My xbox 360 no picture or sound
on your AV cable there is a small switch make sure that the switch is positioned to the correct tab such as if your using component (ypbpr green blue red) then have the switch set for that and if you are using composit (rca yellow) then have it set for that one. this sounds more likely like its positioned wrong.
Jan 22, 2009 | Microsoft Xbox 360 Console
How long does a xbox 360 warranty last?
The Red ring warranty was extended to 3 years and the rest of the errors are covered for 1 year. You are better off finding a local repair shop. Microsoft charges between $100 and $150 for most repairs now, and most local repair shops will fix it for less than $100. I have seen repairs offered for as little as $45 for the RROD. You could buy a new XBOX 360 Arcade and transfer your hard drive, you would get a new machine with the new processor and quieter DVD drive.
Jan 14, 2009 | Microsoft Xbox 360 Console
Have sound no picture and 2 green rings around power button
They are green?!? usualy when people have problems with  the xbox 360 hardware, the lights turn red. This xbox 360 may have a birth defect... Best thing to do is call 1800-4my-xbox. Talk to a representative about sending your xbox in, ONLY if you have not voided the warranty. If so, you will most likely have to buy a new xbox or new motherboard for it.
Also try changing your video settings to tv instead of hd, or hd if it is plugged into a hd tv. You might have toggled the HD switch on the video/audio chords.
Dec 31, 2008 | Microsoft Xbox 360 Console
No Sound on Xbox 360
Very often on HDTVs there may be more than one YPbPr connection... That is the Red Green and Blue. Under each one, or next to, or above, there should be separate red and white audio hookups for each set of YPbPr hookups.
Make sure they are hooked into the corresponding plugs.
Hope that helps.
Jul 15, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
26 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
