Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Why does my garbage disposal keeping locking up? I've checked inside to see if anything is lodging the blades but can't find anything.
Next time it sticks. Vacuum out everything.
See if the cutter wheel is still lodged.
Or if cutter wheel rolls free.
If cutter wheel rolls free after a simple vacuum, then I would suspect the motor is old and weak.
If cutter wheel is still lodged, then check around the edge and see what is stuck.
If there are pieces of metal, then the cutter wheel is probably falling apart bit by bit.
Posted on Oct 25, 2010
SOURCE:
I have a brand new garbage disposer and was surprised that it was so quiet. I've been in homes with a disposer and they are noisy and the water and scraps get sucked down the drain quickly, but m
You're complaining that the garbage disposal is working quietly?
Most folks complain the opposite.
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Look down opening and see if blade is spinning rapidly.
Check that disposal eats lettuce leaves and carrots.
Otherwise you have good disposal.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 21, 2012 | Badger 5 All Insinkerator 76037h 1/2 Hp...
It just buzzes
grinder blade is probably stuck or in a bind. Take a socket wrench with extension and from the top (sink), turn the nut and blade inside the disposal by hand to free it up. Can also unplug it and reach inside to see what may be lodged in the disposal (rag, bone etc).
Oct 22, 2012 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Badger 5 just clicks when I try to turn it on. It is only 4 years old. We tried reset button, checked blades for something lodged in it, and unplugged and re plugged.
Use broom handle and see if blades turn freely.
If blades turn freely, and disposal makes clicking sound to indicate that you have power, and reset button is not tripped out, then disposal has gone bad.
If unit still looks new, then buy identical disposal from store, replace just the disposal body, and return defect in new box.
I wrote ez disposal replacement steps from when I worked apartment maintenance.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Jun 18, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Garbage Disposal Ace 2000 model 47982.... The water won't drain out of it and the sink is backed up and hasn't gone down for a whole day now. It seems like the blades are turning. I've been...
Hi David,
Are the blades actually turning or is just the motor running?
First, turn off the power to the disposal at the circuit breaker. Do not put your hand in until you do this.
If you hear the motor running, but not the blades, then the blades are jammed. On most disposers you can put an allen wrench in an opening under the unit and move the blades. If the blades move freely, then your drain line is probably plugged.
If the motor runs, but the blades don't and they will move freely by hand, then the disposal needs repair.
If the blades are jammed with food, you can clear the jam with your hand and the allen wrench trick from underneath.
Once the disposer is freed up, run cold water down the drain for a few minutes to harden any grease build up inside. Then running the disposer should get rid of the hardened grease.
By the way, most disposers have a reset button on the bottom of the motor should your disposer jam and turn off or trip your breaker.
Orange peels, etc. will not harm your disposer. A good way to keep it clear is to put egg shells down it periodically. The shell action will scrape junk off the inside of the disposer.
You can also keep the disposer clean of grease buildup by pouring some baking soda in the disposer followed by a mix of hot water and vinegar.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
May 06, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have a Badger 5 (5-81A). The motor is humming when it's turned on, however, the blade does not turn. The blade does seem to move freely. Tried reset and hex key but still nothing.
you have something stuck in it more than likely,, use the key ( unplug it first) and turn it backwards,, keep looking inside with a flashlight for the lodged object once you see it,, remove it,, sometimes the key won't work if its something caught in the blades themselves, so use the handle end of a broom or plunger with a wooden handle to push on the blade itself to turn the unit over
May 02, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I recently installed a new Badger 5 garbage disposal in the kitchen sink. I has worked great, but a few days ago it started making a horrible sound when it is turned on. I sounds like there is a spoon or...
Likelyhood of loose blade is very low, but not impossible.
Get a good light and a small mirror, something is jammed inside, I bet. Often a piece of somthing gets lodged in a dischaged port and the blade hits it evey rotation.
Oct 11, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Insinkerator running but water is not franing?
try stuffing ice in disposal and then turning on this clears lodged food and sharpens blades
Oct 07, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Disposal blade locked up after finding bone piece
You need to purchase a garbage disposal wrench. It has a Tee at the top and extends down to a pivot with a large forked head. Drop this down and turn the blades until they start to move. Remove the wrench, run hot water and turn on your disposal. Both blades should now be free. There also might be a red reset button on the bottom.
Jul 04, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
313 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Steve Allison
Steve Allison
Mike
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
