Question about Sharp 32C-240 32" TV
Sharp 36 inch television-PAL to NTSC conversion
Does the sharp televisions support the NTSC50, V-hold, or auto-syn functions.
Do you know the code to the comcast remote to program to this tv sharp 32 inch
Posted on Dec 16, 2008
    Champion:
  • 252 Answers
To convert your tv from pal to ntsc ,find the ceramic filter value 5.0 , 5.5 or 6.0 and change it with 4.5 and . Take note that the ceramic filter of sound and video are defferent ever if it is the same value
Posted on Oct 08, 2008
I need change the color sistem ntsc for pal n
for me use your remote look if have ah pal then change it, if there is know loook your ptt buttons in the t.v and if have a menu you use it to change.
Jul 15, 2011 | Sharp 32F641 TV
NTSC to PAL question
yes system conversion is you need just change the crystals! buy a palsecam crystal then replace the old crystal.
Dec 24, 2007 | Hitachi M2 Digital Camera
Color on tv is like a negitive picture. tried to adjust but no luck
Try to check if the movie format is PAL or NTSC do the same thing with your tv if the setting is PAL or NTSC. If wrong setting is applied that will be the cause. Good day hope that tis may help.
Jul 13, 2011 | Sharp Televison & Video
Does Sharp LC-42SB48UT TV support PAL ? if anyone has this TV you can search under the Option Menu to "Select the video signal system compatible with your equipment from the list...
PAL-M is 525 line 29.97 frames per sec, PAL-N is 625 line 50 frames per sec. Most countries (e.g. UK) use PAL B/G/D/K/I which is 625 line 25 frames per sec. PAl-M is used in Brazil, PAL-N is used in Uraguay and Paraguay. Most modern TVs will handle both PAL and NTSC as long as the RGB input is used (via scart or HDMI).
Mar 08, 2011 | Sharp LC32SB28UT 32 in. HDTV LCD
Is the Sharp LC32D47UT 32-Inch LCD HDTV suitable for use in Australia
Quite possibly as it can cope with NTSC and PAL
The elegant AQUOS® LC-32D47UT easily enhances the decor of any family room, living room or den. With a 16:9 aspect ratio, HDTV resolution of 1366 x 768 and breathtaking color purity, it is a next-generation TV to carry you into the high-definition future. The LC-32D47UT features a high contrast ratio, 6ms response time and wide viewing angles. The LC-32D47UT includes built-in ATSC/QAM/NTSC tuners, 3 HDMI™ and 2 HD Component Video inputs as well as a D-sub, 15-pin input for PC compatibility. The LC-32D47UT features a black cabinet, and the included table stand easily removes for wall mounting applications.
Features
  • True 16:9 - widescreen aspect ratio with 1366 x 768 HDTV resolution.
  • Built-in ATSC/QAM/NTSC Tuners - provide access to DTV and available analog TV channels.
  • High Brightness - Sharp LCD TVs are very bright, so you can put them virtually anywhere - even near windows, doors or other light sources - and the picture is still vivid.
Jan 08, 2011 | Sharp 19 in. LCD HDTV
36 inch sharp tv does not work completely dead. how to fix it Model # 32R5400.
Our Sharp 36" tv will sometimes work. What kind of problems is this and is it worth repairing?
Dec 05, 2009 | Sharp Televison & Video
Rf signal pal to ntsc
there should be an option in your picture settings menu
Jul 23, 2009 | Polaroid FLM-1514B LCD TV
How can i use my tv as a monitor i have connected laptop to ex 4 but no luck
Many Sharp units lack the format capability to display computer video as it Is different from NTSC, PAL and SEcam.
Nov 20, 2008 | Sharp Televison & Video
Conversion of PAL (B) into NTSC
you will need a pal/ntsc digital video converter
Dec 01, 2007 | Sony KP-53S65 53" Rear Projection...
Sharp 32C-240 32" TV Logo
292 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
