Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
How to Remove Bezel Cover from Kenmore Refrigerator 106.57572791
  • Val Shires
    Val Shires Oct 24, 2010
    I did not mean the Base Grill I meant the Bezel around the Ice and Water dispenser.....thanks
    Brigadier General:
  • 3,513 Answers
Please check the link if it helps:-
http://www.ehow.com/how_5772344_remove-ice-maker-water-dispenser.html
However it snaps off. Start on one side and pry carefully with a putty knife.
Please get back to us if you have any further query or else accept the solution.
Thanks for contacting fixya.com
Posted on Oct 25, 2010
  • 8,197 Answers
To remove the base grille:
1. Open both refrigerator doors.
2. Place hands along the ends of the grille, with your
thumbs along the top. Push in with your thumbs and
pull up on the bottom.
NOTE: Be sure to refasten the Tech Sheet behind the base
grille after cleaning.
Or you can go to link below and on page 9 will tell you.
http://www.managemylife.com/mmh/owner_manuals/4764/KENMORE-Side-by-Side-Refrigerator-L0311305?brand_name_search=106.57572791
Good Luck please accept the answer
Posted on Oct 24, 2010
SOURCE:
How to remove the instrument cluster cover 98 chevy cavalier
The cover-is that like a bezel? Older cars always used screws to hold the bezel in place. On lots of newer, the bezel or cover just has plastic clips that snap into holes or slots. If you see no visible screws, try pulling the cover off, starting at one end. Once the cover is off, you can see the screws that hold the cluster to the instrument panel.
Dec 06, 2016 | Cars & Trucks
How to replace the headlight switch assembly on a 1997 dodge grand caravan
The best I can offer is for a 1996 caravan:
REMOVAL
  1. Remove steering column cover.
  2. Remove over steering column bezel.
  3. Remove left end cover.
  4. Remove screw at left end of cluster bezel and headlamp switch.
  5. Remove screws holding cluster bezel to instrument panel from each side of steering column.
  6. Disconnect clip holding cluster bezel to instrument panel from above right vent louver.
  7. Separate cluster bezel from instrument panel.
Disconnect wire connectors from back of the bezel.
INSTALLATION
  1. Connect wire connectors into back of the bezel.
  2. Place cluster bezel in position on instrument panel. Use care not to place hands on louvers.
  3. Connect clips to hold cluster bezel to instrument panel. Use care not to add pressure on the A/C louvers to seat the cluster bezel clips.
  4. Install screws to hold cluster bezel to instrument panel on each side of steering column.
  5. Install screw at left end of cluster bezel and headlamp switch.
  6. Install left end cover.
  7. Install over steering column bezel.
  8. Install lower steering column cover.
May 02, 2015 | 1997 Dodge Grand Caravan
How do you remove the ice dispenser bezel on the freezer door?
Usually a putty knife under the buttom of the bezel and carefully prying it out will do it. repairclinic.com has a good video on this.
Jul 28, 2014 | Refrigerators
I need to replce the drivers side mirror. Just seeking instructions on how to.
Remove front door handle bezel screw cover Remove inside handle bezel screw Remove inside handle bezel Lift upward on the rear of the front door inside handle bezel Disconnect electrical connector Remove handle screw cover
Remove handle screw Remove door trim panel upper screw Remove door trim panel lower screw Remove door trim panel (pull the door trim panel outward to release the pin-type retainers)Remove front door sail panel
Disconnect mirror electrical connector Remove 3 exterior mirror nuts and exterior mirror
Mar 07, 2011 | 2009 Ford Fusion
HP DV9000 My laptop screen is loose i would
When the laptop is flipped over, remove the battery. Under the battery there are 6 screws placed in pairs, these have to be removed. Once these are removed, the speaker and power strip can be pryed up, start with your finger nails on the right side and pop it off. Be careful with the flat cable in the middle of the strip. Tighten the screws for the display there and I think there are some that tighten from the bottom. Also, remove the rubber pads from the screen bezel and remove the screws from the screen bezel, then pry the bezel off at a corner and work your way around the bezel until it is removed. It will somply snap back on when you are finished. Tighten all the screws you see that connect to the hinges, this is wher the screen loosens alot. Just pay attention to the wires that feed through the bezel from the screen to the motherboard. Take your time, nothing to it.
Aug 22, 2009 | Frigidaire FRT17G4B Top Freezer...
Replace Refrigerator Handle
should have screw covers to remove. then remove screws. cover are at top and bottom of handle. push up at top one and down at bottom.
Jun 21, 2009 | Kenmore Refrigerators
Not dispensing water
more likely the switch braket has broken. this unit has a bracket that holds the micro switches on small plastic pins and they break easily. you didnt list a model number but you an secure the part thru partsdirect.com and here are the steps for repairing the unit:
  • first unplug unit
  • remove disp cover, look on bottom edge of the cover and you will see 2 slots for a flat tip srew driver carefully pry the cover off
  • you will expose the switch bracket and most likely will see the broken pins.
  • just change the switches and light socket over to the new bracket (dont forget to install the switch spacers)
some models have 2 screws under the drip tray as opposed to having to pry the cover off.
If this doesnt sound like your refrig post a complete model number and I will get you the proper instructions. thanks peyton
Mar 16, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Dashboard Gauge
  1. Disconnect and isolate the battery negative cable.
  2. Remove Over Steering Column Bezel Replacement.
  3. Remove over steering column bezel.
  4. Remove left end cover.
  5. Remove screw at left end of cluster bezel and headlamp switch.
  6. Remove screws holding cluster bezel to instrument panel from each side of steering column.
  7. Disconnect clip holding cluster bezel to instrument panel from above right vent louver.
    1. Separate cluster bezel from instrument panel.
    2. Disconnect wire connectors from back of the bezel.
    INSTALLATION
    I wouldnt Recomend This Procedure To Anyone juse for Cleaning Purposes Unless Your VIEW OF IT IS "SERIOUSYL IMPARED IF it Moisture Has Accumilated Behind Face of it Then Find Out WHY and Resolve THAT PROBLEM FIRST Onherwise Here you Are. Have A Great DAY !! And Please Dont forget to RATE Me Thank You !
Jan 15, 2009 | 1999 Dodge Caravan
Scratch on stainless steel vertical doorright side
take off the top hing cover and remove it then lift up on the door
Dec 11, 2008 | Kenmore 53642 / 53644 Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
214 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Bruce Denton
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
