Question about Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop
Start up repair utility taking forever
My 3000 N100 goes into the start up repair utility an it takes over two hours, Help!
    Problem Solver:
  • 29 Answers
Better to reinstall a new copy..
Posted on Jun 08, 2008
I want to format my lenovo 3000 n100 laptop,but in boot screen it is asking for password and I forgot my password. My laptop is also not startin.Please help.
If you are able to open your laptop, take out the little battery for an hour or longer. This clears your bios, perhaps there is a jumper nearby to speed this up. All bios passwords are gone then.
Next you open your bios and make your cd/dvd the first bootdevice.
Insert your windows and follow instructions. When asked where to install windows you delete all drives and then create a new drive to format and install windows on.
Feb 24, 2014 | Lenovo 3000 N100 0768 - Pentium Dual Core...
I get a spinning wheel forever when i boot up and everything is very slow now and I have plenty of disk space. I recently deleted things to free up space and i think i deleted something I should not have....
In your applications folder is a utilities folder, in this select disk utility, open it and select your hard drive and then select repair disk, if this is ok then select repair permissions, this can take a while, then try again. Also start up with the right hand shift key held down, this does some system housekeeping and goes in to safe boot.
Oct 25, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
My lenovo N100 running Windows XP, has started going incredibly slow. It takes about 20 minutes to boot up, and it won't go into standby mode and usually won't turn off properly. When I get to internet...
The System Registery are corupted...
download Tuneup Utilities or Registry fixer
it should fix ur issues and speedup ur machine
use all the availble options in Tuneup Utilities...
u can backup ur data and wipe ur HD with KILLDISK or WIPEDISK....DOS utilitis....copy these to a CD and u also may need a boot disk to boot and use these applications....a they are DOS based...
then u can format and load OS fresh
Dec 14, 2009 | Lenovo 3000 N100 Notebook PC
Lenovo 3000 n100 0768 laptop plugged in not
If you go to and download the power management apps for your laptop you will be able to test the health of the battery and get your battery stats.
It sounds like your battery needs to be replaced, but that utility will tell you for sure before you spend the money on a replacement.
Aug 25, 2009 | IBM Computers & Internet
I find myself unable to use integrated camera in lenovo 3000 N100
Well, there are many things one can do. The most efficient way is to upgrade the CPU to a faster one and installing more RAM.
If that isn't a viable solution, you can also disable unused services that you may not require. More info on that here:
Also, be sure to do a scan for spyware with something like Spybot.
Lots of users report that by using Firefox instead of Internet Explorer increases their systems security.
Remove any unneeded Start Up items in your system tray. If you click on Start, then Run... and type in msconfig and then press OK, it will bring you to the System Configuration Utility. Click on the Startup tab and disable anything you don't need. It's easy enough to simply google a startup item listed to find out what the program does and then you can make a decision from there.
Mar 03, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
My lenovo 3000 N100 model takes too much time to start.How can I overcome this problem?
U NEED to check two basic factores .,
ur system not be infected by an virus. so check it with a good antivirus.
and second is uninstall useless programes from add and remove program place because it waste alot of processing power.
Lenove 3000 n100 batteries
the battery casing itself is heat sealed....
You Need to Pry it open..
No Really easy way to do it and you must take your time and do it slowly, start at a corner edge using a guitar pick or similar... then work your way around and around till you can pry it open..
Not an easy task.. But Do-able..
Nov 17, 2008 | Lenovo 3000 N100 T2350 1.83G 1GB (0768EFU)...
Beeping sound
take out the RAM then put it again, then check
Nov 02, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Phoenix bios setup utility page,
do one thing go for the othr key board and try if working fine then you key board problem after that is not working then go for the install the new o/s.
May 10, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop Logo
44 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
