Question about Panasonic KX-TG2357 Cordless Phone
Answering system enabled, phone keeps ringing, call isn't picked up by answering system at the end of approximately 10 rings there is a prolonged beep
SOURCE:
  • 944 Answers
SOURCE: setting the number of rings before answering machine kicks in
Here is the link to the user manual; http://service.us.panasonic.com/OPERMANPDF/KXTC1501B.PDF Check page 19 - you can set the answer rings from 2 to 7 Hope this helps :)
Posted on Jun 19, 2007
SOURCE: GE Telephone answering machine will not work
298976e2-a owners manual,
i have same problem,
sorry if my english not the best.
i "paste and copy"
We have the answering machine set to 4 rings. When people call, the machine picks up on the 4th ring, it beeps, then cuts off. No recorded message. No message is recorded, the call is disconnected. What do we do?
send me email.
[email protected]>>>Canada
Posted on Jul 03, 2008
  • 31 Answers
SOURCE: number of rings
two rings means it has message, erase the message to increase the number of rings to like four
Posted on Oct 19, 2008
mumma_1
  • 903 Answers
SOURCE: number of rings on answering machine Panasonic KX TCM 506 BX
http://service.us.panasonic.com/OPERMANPDF/KXTG5631.PDF
this link will take you straight to the operating manual in pdf format
hope this helps you out
Posted on Oct 28, 2008
rockitman187
  • 2559 Answers
SOURCE: How do I retrieve messages on the Panasonic KX-T7030 phone?
  • Call into your mailbox (usually by dialing intercom 165)
  • Press 4, and 4 again (for "Incomplete call handling")
    By default, three options are enabled:
    option #1: leave a message
    options #5: call the operator
    option #6: return to top menu
  • Follow the audible prompts to disable options 5 and 6
Here are some other features you may need
  • Make sure your Auto Answer button is lit up, so you can receive intercom announcements, and respond hands-free.
  • Use the Call Forwarding (FWD) to send un-answered calls to another phone or to voicemail
  • Press BGM (or 1 on the touch-tone pad) for background music, if your system is equipped.
  • Use Absent Messages to show text messages on other people's phones when you are away.
  • Use System Call Waiting so your phone will ring even when you're on the phone. Press Intercom and dial 7311 to set it up, or 7310 to cancel.
  • Use Do Not Disturb (DND) when you don't want to receive calls. Press Intercom, press FWD/DND and dial 1 to activate, or 0 to cancel.
  • Press MESSAGE when you call a busy intercom number. This will turn on the MESSAGE light on the other phone, and the other person can tap that button to automatically call you back.
  • If you get a busy signal when you call an intercom number, you can signal the other person by dialing 1 (if that phone is programmed for System Call Waiting (above).
  • Dial 330 to make an announcement to all phones.
  • If you want your phone to automatically select an outside line when you pick up the handset, press PROGRAM, dial 99, dial 12, press STORE, press PROGRAM
  • Posted on Feb 12, 2009
    How do you change the amount of rings on the uniden dect1363 6.0 GHz
    The Uniden DECT 1363 isn't an answering machine. It will continue to ring until someone picks up, a separate answering machine or voicemail system picks up, or the caller hangs up. You need to refer to the documentation for your answering machine or voicemail system.
    If you require further assistance, please repost your question specifying the make and model of your answering machine or voicemail system.
    Sep 18, 2012 | Uniden 5.8GHz Expandable Cordless Phone...
    Want to change from a 3 ring answer to a 5 ring answer
    The CS6119 isn't an answering machine. It will continue to ring until someone or something picks up or the caller hangs up.
    If you have an answering machine connected, please refer to its documentation or else repost your question and specify the make and model of the answering machine.
    Sep 03, 2012 | Lands Phones
    Change from 3 ring answer to a 5 ring answer
    Need more rings before going to voicemail
    The D1660 isn't an answering machine. It will continue to ring until someone or something picks up or the caller hangs up. Please refer to the documentation for whatever answering machine or voicemail system you have connected to your phone line.
    If you need further assistance, please repost your question but be sure to specify the make and model of your answering machine.
    Sep 02, 2012 | Uniden D1660 Cordless Phone
    Setting the number of rings
    The CS5113 isn't an answering machine. It will continue to ring until some other answering system picks up or the caller hangs up.
    Jul 01, 2012 | Vtech CS5113 Phone
    Hi How ldo I set the # of rings on my phone Model# EXP4240
    The EXP4240 isn't an answering machine. It will continue to ring until the caller hangs up or some other answering machine, fax, or voicemail system picks up.
    Mar 17, 2011 | Uniden Cordless Phone
    Phone is plugged in to a fax machine and the phone rings too many times before answering machine picks up so the fax machine takes over. How can I reduce the number of rings so that the answering machine...
    Change the answer machine rings to answer number to less than the fax number of rings to answer or increase the number of rings to answer on the fax machine. Would need exact model number of phone system to give more detail on programming steps. Info should be in manuals of phone system and fax machine.
    Dec 07, 2010 | AT&T DECT 6.0 Cordless Phone System with...
    Would like to increase number of rings before answering machine comes on.
    Setting the Number of Rings (Excerpt from the Uniden Dect 1580 Phone manual
    The ring time setting allows you to set the number of rings the caller hears before your answering system plays the outgoing message. You can set the ring time to answer after two, four, or six rings. If you enable the Toll Saver (TS) setting, the answering system picks up after two rings if you have new messages, and after four rings if there are
    none. This way, if you make a long distance call to check your messages, you can hang up after the third ring to avoid long distance billing charges.
    1. Press Menu/Select.
    2. Select the Ans. Setup menu, and then the Ring Time submenu.
    3. Move the cursor to select a ring time (Toll Saver, 2 Times, 4 Times, or 6 Times).
    4. Press Menu/Select. You will hear a confirmation tone.
    Feb 02, 2010 | Uniden DECT 6.0 Cordless Phone ID
    Number of rings
    Looks like 6 is the Max, according to the Manual.
    Setting the Ring Time
    Ring Time allows you to set the number of rings the caller hears before your
    after two, four, or six rings. If you enable the Toll Saver (TS), the answering system
    picks up after two rings if you have new messages and after four rings if there are
    none.
    1) Enter the Answ. Setup menu, and then the Ring Time
    submenu (see "Entering the Menu Option" on
    page 16).
    2) Press volume up/down to select a Ring Time (Toll
    3) Press the OK soft key. You will hear a confirmation tone.
    Toll saver is a feature where you can call the phone yourself, if there are messages it wil answer in 2 rings, if not it'll answer in 4 rings. The idea is to hang up on the 3rd ring and save the LD changes.
    Hope that fixed Ya...
    Geno
    Mar 27, 2008 | Uniden TRU8885 Digital Answering Machine
    Answering machine doesn't pick-up reliably
    I found in the manual that if the machine doesn't answer after the correct number of rings, then it may be the ringing system used by the phone company. But I have also heard of people with VOIP (such as Vonage) having problems with this as well.
    http://telephones.att.com/docMgt/public/art/21714/1738_english_manualpart2.pdf
    Dec 05, 2007 | AT&T 1738 Digital Answering Machine
    Panasonic KX-TG2357 Cordless Phone Logo
    108 people viewed this question
    Top Panasonic Lands Phones Experts
    Ekse
    martin hogg
    guyvstewart
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
