Question about Brother MFC-5890cn Color Flatbed All-In-one Printer
MFC 5890CN is new, won't print black. at first it wouldn't print any colors thought the cartridges were empty so I went out and bought new ones...black still wont print..and of course brother help is only avaliable when I am at work! not weekends or evenings! I'm ready to throw this out the window!
SOURCE:
SOURCE: MFC-440CN printing problem
i cannot print anything
Posted on Jun 03, 2008
papa_sanjay
  • 67 Answers
SOURCE: Fuzzy printing brother MFC 5890cn
check interface cable and load proper printer emulation language
Posted on May 01, 2009
  • 68 Answers
SOURCE: black print won't work on Brother MFC-845CW
Open the case,i don't sure were the cartridge is located but i think is easy to you to find it.When you found it, wipe the botton part of your cartridge use soft clothe for cleaning.Look at mannual to locate the cartridge.
Posted on May 20, 2009
  • 37 Answers
SOURCE: have the brother mfc-5890cn having fax issues
Can you hear the receiving fax pick up the line? If so, you may need to slow the speed of your fax modem to allow for poor line conditions. You can find the instructions on page 12 of the Users Guide. If you don't have one, you can download a PDF file of the guide on the Brother web site.
Posted on Oct 09, 2009
Rossiman46
  • 50 Answers
SOURCE: I have a brother MFC 5890CN printer and the yellow
It may be worth changing them again, you can on the odd occasion get a couple of duffers.
i would start afresh & do a head clean then a print test with a brand new set in.
If you get a perfect set of squares as the screen shows then its done if not repeat the head cleaning process untill you do, once you got those squares right your done.
Posted on Nov 09, 2009
I have a all in one color LC61 printer, do all colors have to be filled to print blk only?
Greyscale is color not black only.
You can print in black and it will look grayscale only darker, printers are a pain to work with after a year has gone by, I can expect almost a half hour to print something with my $400 epson because one of the colors is out even though I never printed in the last year a colored page. I take the color cartirges out and they are empty, but I only print a page 2-3 times a year. I use the scanner all the time. Brother and epson have their print heads in the printer not the cartridge so make sure your inks are always have something in it or it will be miricle for the printer to last more than a year. Check colors every other week. One Epson printer only lasted 3 months because I never used it(print head dried up). Never use the set up with tubes running outside printer to small tanks of ink if you only use it occationally.
May 11, 2014 | Unknown 10pk 4B,2C,2M,2Y Compatible LC61...
Im only getting balck and yellow i have a mfc 5890cn printer
Try to print a test page, if this comes out in black in yellow take out the cartridges and make sure the plastic is taken off the bottom and pop them back in. Do a test page again. Does it now print in colour and are there any errors on the machine or pc? i.e. out of ink?
Aug 17, 2011 | Brother MFC-5890cn Color Flatbed...
I have a brother mfc 5890cn and I am not able to print anything in black. The cartridge is brand new and I have cleaned the head several times. The other colors print out just fine.
You could clean the black ink cartridge. For this you need to remove the black ink cartridge which is present in the printer. In order to clean the laser or scanner block you could use a cotton swab as it would fully clean the dirt. You need to clean the grime and the dried ink present in the printer. This would remove all the hindrances which prevent the ink from flowing. Cleaning the printer heads would also help to solve the problem.
Dec 01, 2010 | Brother MFC-5890CN All-In-One InkJet...
Brother- MFC 90CW black ink just replaced, but not printing, even the test print didnt print propaerly, it came out very light in other colours but not in black? what to do? is it a toner problem?
Thoughout my experience of fixing computers, I have seen this happen twice. Once was because the "new" ink cartridge was empty (which should cause the LCD display to say "cannot print"). the other was because the end user did not remove the protective yellow cap before installing the ink cartridge (yes, they made it fit). If neither of these are the cause you should try cleaning the print head. You can do so by pressing "ink", then scroll down to "cleaning", then scroll to black and press "ok".
Nov 06, 2010 | Brother MFC-5890CN All-In-One InkJet...
Changed black ink cartridge and still will not print black....colors do print except black
If you are using a refilled cartridge the contacts may no longer be good. They do wear out and every so often buy a new one and refill a few times before replacing again.
Sep 14, 2010 | Brother MFC-5890CN All-In-One InkJet...
Printer will not print dut to other color cartige. being empty.
The color cartridges print text that appears black by mixing the three primary colors (cyan, magenta, and yellow) to make composite black. To achieve a realistic black, large quantities of colored ink are used. Because black cartridges use much less ink to create a similar shade of black, they print more pages in black than the color cartridge.
If the color cartridges on the printer are next to empty, you will not be able to get perfect prints at all.
Please have the cartridges replaced to do the printing jobs again.
Sep 10, 2009 | Brother Multi-Function Center MFC-240C...
Black Won't Print On MFC 420 CN
Use another new genuine (original brother) BK cart. Do the cleaning twice only for BK. Wait some time (4 hours). If the ink has dryed up, the cleaning ink will break up the dryed one. Do the cleaning again. If it doesnt work, please write again.
Sep 18, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-5890cn Color Flatbed All-In-one Printer Logo
209 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
