Question about Roper RGX4634KQ Gas Dryer
I have a roper dryer that was working fine than all of a sudden just stopped turning. I've checked everything I know circuit breaker. Does the roper dryer have a reset button???
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 113 Answers
No, reset button on these. It may be the lid switch or the thermal fuse. This is what I find most of the time. Check out the diagram on apwagner.com and you'll see the parts locations. Oh, if it's not the thermal fuse of the lid switch it may be the timer. I've seen this a couple of times.
Posted on Oct 24, 2010
SOURCE:
Our dryer just suddenly stopped! We have no light and it seems no power. We checked out fuse box and everything is fine there. Does this dryer have a fuse that would cause all electricity to stop?
Hello
No .Double check your cicuit breakers.If your dryer is electric there are two breakers.Switch all the way off then all the way on to reset.
I if ok then suspect door switch .It kills everything and if stuck ,the light too.
Happy hunting
Jul 28, 2011 | Kenmore 600 7962 Dryer
Roper elec dryer starts and runs for 10 sec then stops runnning
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps...
Daniel
Sep 14, 2010 | Roper RES7646KQ Electric Dryer
My dryer stop heating and will not dyr bt the tub turns and still but out air
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, If one is blown, the dryer may still operate but not heat. Alternatively, the dryer may heat, but it may not heat up as hot as it should. Replace the Fuses or reset the circuit breaker.
Another common cause of a dryer failing to heat is a faulty Heating Element. You will need to replace it.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jul 03, 2010 | Roper REX4634KQ Electric Dryer
My Roper dryer Model #RGS7648E will not start
Here is a tip that I wrote that will give you a list of things to check...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 05, 2010 | Roper RGS7648E Dryer
Will not heat
Check your house fuse/circuit breaker panel. The dryer runs off 2 circuits -one for heat and one for the motor.
Mar 14, 2010 | Dryers
My dryer all of a sudden will not come on. Is there a reset button on these dryers?
Your problem could be a result of several possible issues:
* voltage coming to the dryer (110 V for gas & 220 V for electric); Check circuit breaker, voltage at wall outlet, etc.
* thermal fuse (non-resettable) that has blown and shuts off the dryer typically due to overheating (may be caused by clogged exhaust system)
* timer
* motor
* Start button or door switch
You should contact an appliance service company if you have checked the circuit breaker for proper voltage.
Jan 20, 2010 | Roper REX4634KQ Electric Dryer
Old Frigidaire apartment size (24'0 top dryer stopped working.
check the breaker i know the washer works so how come the dryer works on 220volts if one side is out the washer will work but not the dryer if that is not it check the door switch the unit also has a thermal fuse that could be out there is no reset button
Nov 30, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Roper Dryer
You may have tried this but every time mine has ever stopped and refused to restart was because I forgot to clean out the lint in dryer screen.
Jun 29, 2008 | Roper REX4634KQ Electric Dryer
Roper RGX4634KQ Gas Dryer Logo
416 people viewed this question
Top Roper Dryers Experts
Marvin
Marvin
Dennis Boxerman
Colin Stickland
Colin Stickland
Are you a Roper Dryer Expert? Answer questions, earn points and help others
