Question about Kodak EasyShare C653 Digital Camera
I turn it on it and every time you try to take a pic it says memory card needs reformatting? I reformat it as the camera says to but, it says memory card not use able? I have also put a new card in too? Lisa
    Brigadier General:
  • 11,967 Answers
Are you formatting in the camera as you're supposed to?
Posted on Oct 25, 2010
SOURCE:
MEMORY CARD SHOWING FULL BUT WHEN CAMERA CONNECTED TO DOWNLOAD TO LAPTOP OR DESKTOP ITS SHOWING FREE SPACE AND USED SPACE BUT NOT SHOWING ANY PICTURES AND VIDEOS,
Save the pictures and videos on the card. Try reformatting the card in the computer, and then again using the camera. The first reformat will ensure the card is empty, and then the camera reformat will ensure that it is recognized by the camera. If the camera reformat will not work, try a new card.
Apr 09, 2015 | Samsung ES30 Digital Camera
My camera says frame no. Full
Not really familiar with that camera, but if it uses an SD or other memory card you might try reformatting the card. There should be an option for reformatting in your menu. (Reformatting will erase all pics).If that doesn't work you might try another memory card.
Also, try removing the battery for a few minutes to reboot the microprocessor.
Sep 26, 2014 | Fuji FinePix S8500 16MP Digital Camera...
My flip camera says its empty but when I try to record it says its full??
Your memory card may think it's full if you've been deleting pics from it when it's in your PC and not in the camera.
If you've offloaded all the pics you want to from your memory card, put it back in your camera and "reformat" the card - there should be instructions how to do this in your camera manual. (If you've misplaced your manual you can likely find an online version on the website of your camera manufacturer). Hopefully this will fix your problem.
From now on, (even if you have to buy a new memory card), don't do any editing or deleting of pics directly on the memory media while it is in your PC (or Mac). Offload your pics to a file of their own on the PC (you can edit pics from that file). Then put the memory card back into the camera, verify that you did indeed successfully offload the pics to the PC (with the media card out of the PC), then delete the pics from the card while it's in the camera.
Reformat the memory card periodically (in the camera) after you've offloaded your pics (reformatting will erase all pics so you've gotta be sure you captured them elsewhere) to maintain the 'health' & full functionality of your memory card.
thanks.
Apr 15, 2011 | Pure Digital Flip Video Ultra Camcorder
8GB CENTON SDHC memory card - class 4 - worked okay first day. Removed card to transfer pics to computer. Did fine. When inserted card back in camera JVC-PICSIO GC-FM2BU, got "Memory Card Error"...
Sounds like you forgot to use the "safely remove hardware" when you removed the card from the computer. Also, never format a card in a computer and then expect it to work in a camera. You can try to format it a few more times in the camera but if not successful, then you should think about getting an new card.
Feb 19, 2011 | Cameras
Memory card need to reformat but pics still not save
In that case, there is a possibility that your memory card was damage already.why?
because when the memory card was reformatted all the saved files will be deleted.
since, you already tried to reformat it and still pic is not saved then the problem must be your memory card. I think you should buy for a new one, but try to reformat it again.
Nov 10, 2010 | Computers & Internet
My camera and memory card aren't holding very many pics
need more info but usually ir means the memory is full . or the memory card is corrupt. i suggest saving all the pics to your computer then try reformatting the memory card. you can usually do this from the camera itself. you will have to go thru the cameras menu and pick delete all pics and format card.
also check what pixel setting you are using. the higer the pixel setting the lass pics the memory will hold.
however lowering the pixel rating also reduce the quality of the pictures. hope this helps .
Jan 04, 2010 | Sanyo VPC-S880 Digital Camera
Memory card only holds 5 pics
First make sure that the camera is able to recognise the card and is not defaulting to the internal memory only. Power off the Camera, then remove the additional card. Power on the camera, then power off the camera. Put the memory card back in the camera and then reformat it before using it. Fuji, Canon and other digital cameras do not like being used with memory expansions if they are not reformatted every time the pictures have filled the memory card or you choose to download them. Its like the memory is still allocated to something even though you cant see it. So a good practice is to reformat after every download. If the problem persists then try another card and if this still gives an error then you will have to get the camera serviced.
Oct 14, 2009 | Samsung L200 Digital Camera
Can't download pics to computer
no u can recover ur pic from memory card
call 9890274954 international user add 00
Jun 18, 2009 | Pentax Optio 60 Digital Camera
I have a san Disk memory card & when I put it in my screen locks on the greeting screen. Help?
Do you reformat your cards every time you download your pics? The card may be corrupted. You may be able to clear it and reformat it through a card reader on a PC. If this isn't possible scrap the card and buy another one - and ALWAYS reformat it.
Jun 12, 2009 | Vivitar ViviCam 5100 Digital Camera
Downloading pictures from memory card
Not sure if this will help, but after I used a reader/writer, I could no longer see the pics that were on my memory card unless I had it in the camera. A reader/writer reformats, so you will need to reformat the memory card to upload to your pc.
Oct 22, 2007 | Kodak EasyShare Z710 Digital Camera
Kodak EasyShare C653 Digital Camera Logo
29 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
