Question about Panasonic Lumix DMC-LS70 Digital Camera
Hi, when i put in my memory card for my camera (DMC-LS70) it says "memory card is locked" how do i unlock it this never happend before.
  • Panasonic Master
  • 4,738 Answers
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Posted on Oct 24, 2010
SOURCE:
My memory card is definatly unlocked however any pictures I take will still only save to in built memory. Nor can I view any photos on the memory card.Had the camera for 3 years and it has never done this....
Try this....with no card in the camera, go into the menu and find "format"..follow the on-screen instructions to erase the internal memory. Then, insert your card and it should work properly.
Jul 14, 2011 | Panasonic Lumix DMC-LS70 Digital Camera
Windows 7 compatible driver for panasonic lumix camera dmc-ls70
You need to go to the lumix website and follow links to support and/or downloads for drivers.
May 02, 2010 | Panasonic Lumix DMC-LS70 Digital Camera
My Memory card is locked how do I unlock it? Its a Panasonic DMC LS70
On the side of the SD memory card you will find a small sliding switch. It sounds like the switch is in the "lock" position. This is used to prevent accidental erasing of pictures, but it doesn't allow to shoot any either. Remove the card and move the switch away from the lock position and you should be good to go. If this solves the problem, please rate the answer favorably. Thanks
Nov 07, 2009 | Panasonic Lumix DMC-LS70 Digital Camera
Memory card locked
There is a switch on the SD memory card, slide the switch to unlock position before you insert the card into your camera.
More detail, see here How to fix a ‘card locked’ problem
Jul 02, 2009 | Panasonic Lumix DMC-FX12 Digital Camera
Important photos are stuck in the internal memory of my camera.
Select the Display mode with the top dial. Press the Set button to bring up the menus. Press the Rev key to scroll down through the menus. On the second page of menus, select the Copy menu. Then press the Lightning Bolt key to scroll right. Select the top of the 2 menu items. This will copy the internal pics to the memory card, assuming you have a memory card inserted.
May 27, 2009 | Panasonic Lumix DMC-LS70 Digital Camera
Use of digital camera Lumix DMC-LS70 as a web cam.
It will not work through USB like a standard webcam. Ls-70 only lets you access camera memory card/onboard memory when connected via USB.
However you could connect the camera video-out socket to a PC with graphics card with video capture function. Some cards with video capture work with skype (check this URL:
http://forum.skype.com/index.php?showtopic=41101 )
There are also various software solutions which can fool your webchat client into thinking that video capture stream is actually an output of a usb webcam. (Try google for "video capture into skype".
At the moment this seems to be the only easy way to use LS-70 as webcam.
Good luck,
Raf
Mar 12, 2009 | Panasonic Lumix DMC-LS70 Digital Camera
My memory card is locked. How do I unlock it?
What exactly is you problem with your camera?
Regards
Andrea
Nov 02, 2008 | Panasonic Lumix DMC-LS70 Digital Camera
my memory card is locked and i dont know how to unlock it
Aug 21, 2008 | Panasonic Lumix DMC-LS70 Digital Camera
Panasonic Lumix DMC-LS70 Digital Camera Logo
116 people viewed this question
Top Panasonic Cameras Experts
Ekse
skyblue007
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
