Question about Mitsubishi WT-46809 46" Rear Projection Television
Tv wont turn on
I was using my dvd player to play a cd. The tv just shut off out of no where and it will not turn on by remote or manually. Any suggestion as to what it may be?
Thanks
Melissa
    Problem Solver:
  • 7 Answers
First reset the TV set by unplugging the AC cord for like 5 minutes. then plug it back on again, try turning on the TV, if it still dont turn on then I suspect a blown fuse or worse.
Posted on Jul 19, 2008
The player will read dvd but will not play cd
Richard: This is what EHow.com said: "
  • Turn on the DVD player. It generally takes a few seconds to get going. Take out the DVD if there's one in the drive already.
  • 2 Make sure the disc isn't scratched or dirty. Use a soft rag to clean the disc if you see any smudges. Insert the CD into the DVD player's disc drive and close it.
  • 3 Press the "Play" button on the DVD player or remote control. Some DVD players will begin reading the disc automatically. Pushing the button works just as well.
  • 4 Use the "Scene Selection" buttons on your remote to select a track. Some DVD players have odd ways of ordering the buttons on the remote. You might have to play around a bit before you find all the right buttons to work the CD playing function of your machine.
  • 5 Crank it up and enjoy your music. The DVD player will act just like a CD player and play the tracks of the CD through the TV.
  • Read more : http://www.ehow.com/how_2036285_use-dvd-cd.html
    May 28, 2015 | Televison & Video
    Sponge bob DVD player will work on a regular TV but will not show up on the sponge bob tv anymore. Also tried a different DVD player and only get a blue screen. Shows AV then AV then tv or something. It is...
    Hello
    Your Emerson Sponge Bob's model will be SB350. It is a TV/DVD combo, with two AV inputs too. You ahve to see only DVD player with it as you says. You can change its mode to eiter TV/AV or DVD/TV by its remote control buttons. Press the DVD/TV mode button on the remote control to chage the modes to TV or DVD. On DVD mode, you can play DVDs with it. I thinks that you have its user manual with you now. Go to its pate [23] where there is illustrations for which button on the remote control handset should be pressed to select this. If you haven't its user manual with you, send your email address to me by FixYa comment box. I'll send a copy you the user manual to you by return mail. OK.
    Jun 27, 2011 | Emerson SpongeBob SquarePants TV
    How do i program my remote
    Hello;
    Without knowing the codes for the specific brand names and models of your devices, this is how you program the Zenith MBR3447 for your TV, VCR, DVD Player, CD Player or Audio Receiver:
    TV
    1. Push the "Power" button on the TV to turn it on.
    2. Press and hold the "PRG" button in the upper left corner of the remote. Release when the indicator light, located in the top center of the remote control, comes on.
    3. Push the "TV" mode key located at the top of the remote.
    4. Enter 0 -- 0 -- 0 on the remote's number pad, then press the "Enter" button.
    5. Aim the remote control in the direction of the TV's IR sensor and push the "Power" button. Pause a second. If the TV fails to shut off, push the "Power" button again. Repeat until the TV does shut off. Each time the "Power" button is pressed the Zenith MBR3447 tries using a different TV device code from its code library to turn the TV off. Therefore, when the TV finally does shut off it's an indication that the remote is temporarily programmed with the correct device code to control the brand of TV you're using.
    6. Press "Enter" to save the current code.
    VCR
    1. Push the "Power" button on the VCR to turn it on.
    3. Push the "VCR" mode key located at the top of the remote.
    5. Aim the remote control in the direction of the VCR's IR sensor and push the "Power" button. Pause a second. If the VCR fails to shut off, push the "Power" button again. Repeat until the VCR does shut off. Then press "Enter."
    1. Push the "Power" button on the device your programming the remote to control to manually turn it on.
    3. Push the "AUX" mode key located at the top of the remote.
    5. Aim the remote control in the direction of the device's IR sensor and push the "Power" button. Pause a second. If the device fails to shut off, push the "Power" button again. Repeat until the device does shut off. Then press "Enter."
    Mar 11, 2011 | Zenith MBR3447 Remote Control
    I need to know how to hook up DVD player with Cable TV I have the cable with the white yellow and red. I hook one end into the TV and one into the DVD player. I don't get a pic or sound. I do not havethe...
    The key is having at least a Universal Remote ($10.00 or less) that will operate your brand of TV. Your TV is only looking at "stations". You need to make it see Aux-1, Aux-2, or Line In mode. BUT, another trick is to run the DVD into your VCR (if capable). Select the VCR proper "input mode" (Aux-1, Aux-2, or Line In mode) then the DVD will play through the VCR and it will play through the TV on either channel 3 or 4. Problem solved!
    Jun 27, 2009 | Sony DVP-NS501P Progressive-Scan DVD/CD...
    Jvc dvd player not playing
    Even you don"t have a remote you can play it manually and DVD player play it automatically.Just try this open the tray put the DVD disc on the tray and close it then turn it off for 30 seconds then turns it on then it play automatically if not then there's something wrong to the player.
    Hope it may help you:
    Regards:
    VOTIT
    Mar 23, 2009 | Audio Players & Recorders
    Samsung HT-A100 Home Cinema system plays cd only with tv on!
    You need to put away the remote for your TV and use only the remote for your HT system. Your HT remote should work on your TV by default. Your Samsung HT remote should have a TV button and a DVD/Receiver button (or HT button). When using only the TV, press the TV button and then use it for just the TV and when using the HT system, press the DVD/Receiver button and then you can use the HT system.
    If for some reason your TV is not set on the Samsung HT remote by default, your HT users manual should have a list of codes that you can use to program your HT remote. Hope that helps you. Gary
    Mar 18, 2009 | Samsung HT-A100T Theater System
    Technically challenged...need DVD to show on TV screen
    hey 1st of all you gotta make sure that your son made tha right connections with the av cable (this is the cable with three different coloured pins) from your DVD to your tv. if this doesnt solve your problem then make sure you are using the correct av channel on your tv set that will allow you 2 play your DVD player because sometimes you cant play your DVD on thhe same av cannel you watch normal tv
    Jan 01, 2009 | Pioneer DVR-520H DVD Recorder
    LG REMOTE WONT SWITCH FROM AM/FM TO DVD
    HI THERE, I FIXED THE PROBLEM MYSELF BY KEEPING THE FUNCTION BUTTON ON THE DVD PLAYER PRESSED UNTIL IT FLASHED ""MODE"". THEN I PRESSED IT IN SEQUENCE TILL IT CAME UP WITH DVD/TV THEN IT AUTOMATICALLY SWITCHED OVER TO THE DVD FUNCTION MODE. ALL DONE. BUT THE TV/DVD BUTTON ON REMOTE STILL ISNT FUNCTIONING OR CROSSING OVER CHANNELL. HAVE TO DO IT MANUALLY VIA DVD PLAYER. EVERYTHING ELSE WORKING EXCELLENT. THANKS ANYWAY. HOPE THIS INFORMATION WILL BE OF USE TO YOU IN THE FUTURE. I CUD CHARGE YOU FOR THIS INFORMATION BUT I WONT THIS TIME.... LOL. MERRY CHRISTMAS AND GUDBYE...
    Dec 13, 2008 | LG Televison & Video
    Prima HDTV has a black screen on TV, but works fine while Playing DVD
    try turning the channel up or down with the tv remote to input 1 or 2 depending on which one is being used for the dvd player. tv should use input 1. dvd should be on input 2.
    when turning the channel set it to show the dvd screen, then go up 1. if it doesn't show, return and go down 1.
    Oct 22, 2008 | Prima C2012 TV
    Using remote to play video DVD
    You need to bypass your A/V tuner for your video connections (if possible). Plug your video directly into the TV and audio into the tuner. This will also give you a cleaner signal/picture as it does not have to processed by your tuner BEFORE it goes to your tv. Think of it as cutting out the middle man. Your tuner is best left for powering your speaker and not controlling your video despite all of the available connections in the back of it.
    I would also get rid of your VHS and cassette players as they are dead technology. Clean up your system and remove the clutter. This will lessen your chance of getting interference. Good luck!!
    Oct 01, 2008 | Toshiba 32D46 32" TV
    Mitsubishi WT-46809 46" Rear Projection Television Logo
    53 people viewed this question
    Top Mitsubishi Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
