Manual for Akai reverse cycle airconditioner remote control
I have infrared remote control model GZ-1002B-E3 for reverse cycle airconditioner.could you please explain the different modes of operation particularly the Dehumidification function
Re: manual for Akai reverse cycle airconditioner remote...
I have a Akai AC-GP10HRCI model portable air conditioner. We have lost the manual. It shows F8 on the display panel board and is not working at all. Please help. Thank you!!
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/
This might be a couple things M's Jackie. 1 the reversing valve is stuck or bad,2 the swtch is broken , Is this a heat pump. Meaning you use it to both heat and cool the home? There is not gas connected to this unit?
This is a new unit and you must make a complaint to the dealer immediately to replace your unit. Make sure that the battery is good , the position of the battery is correct and the remote is aimed at the unit.
If not ask for replacement, file a complaint as a new unit has a warranty.
take your chellphone and open the camera,then take the control and push any button in front of the chellphone.if the remote is ok you see a light blinking.if you didnt see the light the eye of the small plate have the problem.
I had the same problem. Check the remote control section of the manual. When you change batteries the screen flashes the hot and cold icons alternating. press a utton when the hot one is on and it will activate the heat+cool mode.
Is it a multi-device remote at all?
This set is probably a rebranded Samsung so you might try their codes or check Samsung's website for a code listing for that model.
