Question about Kenmore 16.7 cu. ft. / 473 liter Upright Freezer 23725
I have a Kenmore Upright freezer 22138, does this have a reset button? single mom and don't know much about these things_but it stopped working because i think door was left slightly open and alot of frost formed. Now it wont start up again...
SOURCE:
fridgetech
  • 473 Answers
SOURCE: Frigidaire Frost Free Commercial Freezer
The drain has most likely frozen over. It is at the bottom behind the back panel inside the freezer. You will need to remove all of the ice and run hot water down the drain until it is clear.
Posted on Nov 16, 2007
  • 10 Answers
SOURCE: My woods upright freezer keeps
check your door seal, by closing the door on a strip of newspaper all round the seal. this fault is usually air getting inside the freezer, it rises to the top making thick ice or snow.
Posted on Feb 07, 2009
jumptrout51
  • 3361 Answers
SOURCE: Upright freezer door inside developing ice
The door seal is at fault. Regardless of the small tear it is not sealing well.
Take a dollar bill and close it in the door. Then pull on the bill to feel resistance.
You will find it pulls easily in some place. That is where your air leak is that is causing the condensation.
Do this about every 6 inches all the way around the seal.
Posted on Mar 27, 2009
  • 358 Answers
SOURCE: fan is squeaking all the time Kenmore frost free upright freezer
Yes you need to replace it,if dont will have bigger problems.
Posted on Apr 03, 2009
aasc
  • 1606 Answers
SOURCE: frost free freezer is frosting up
Your door seal is not sealing properly . Check and use a hairdryer to soften the seal and the magnetic portion should seal itself against the cabinet .
Posted on Jul 07, 2009
Need wire schematics for a old Kenmore upright freezer Model #22138
need the entire model number from the tag on the unit
Mar 08, 2015 | Kenmore Freezers
I can't turn my Kenmore upright freezer on.
Try disconnecting power for about 30 seconds, and then restore power. This will reboot the control and maybe restart.
Jul 09, 2017 | Kenmore Freezers
I need to install a 9v battery in my Kenmore Elite upright freezer and I don't know where the battery compartment is.
Please expalin to me what this battery powers, i have been a appliance repair technician for over 30 years and have NEVER seen a battery used to power any component, i know manufactures come out with new stuff all the time so i would like to know what this battery does
Jul 23, 2011 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Stop beeping freezer after power faiilure? The reset button only lasts half a day?
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Apr 10, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
ALARM WENT OFF ON OUR KENMORE UPRIGHT FREEZER. HOW DO WE GET IT RESET. WE HAVE PUSHED THE BUTTONS BUT RED LIGHT IS STILL ON AND FREEZER NOT RUNNING. THE PROBLEM STARTED BECAUSE WE DID NOT GET THE DOOR SHUT...
The light and alarm will remain active until the temp in the freezer is "normal" or satisfied. You should be able to push & hold the button (if electronic) until it stops. If it is a manual switch, they are usually located at the bottom of the cabinet below the door.(some are located inside the unit on the wall as well) It may be a "rocker" switch or part of the actual indicator light. Good luck
Sep 26, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
FREEZER ALARM WILL NOT SHUT OFF
You can try 2 things. Unplug it for about 2-3 minutes and then replug it. It should reset itself. You can silence the alarm or muffle it. Silencing it should be hard. Disconnect it from its source. You may want to find out why it is alarming constantly. Have you called Sears and asked them?
Feb 09, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
14.1 upright Kenmore freezer was unplugged to clean after hurricane. We moved freezer to new location, never turning it on its side...plugged in and light works but freezer is not cooling. There are no...
Check to see if there is a reset on the compressor or close to it. Turn your control knobs up and down and see if you hear a "click". You might cause it to engage at that point. Let me know how this does.
Feb 01, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore Freezer 20.3 cu.ft. won't kick on
Poor mom..:) You need a technician for that problem. But much better if you buy new one because your unit is already 14 yrs old the labor and parts are expensive. For this problem I think the compressor is already burned or stuck up.
Jan 04, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore freezer
tell us what the problem is and why you want to reset. freezers dont have a reset button
Jun 23, 2007 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore 16.7 cu. ft. / 473 liter Upright Freezer 23725 Logo
246 people viewed this question
Top Kenmore Freezers Experts
John Tripp
John Tripp
Felizardo Erilla
Felizardo Erilla
PNiss
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
