Question about Proview Computers & Internet
My monitor has stopped. it did this once before but i tinkered with the computor settings and it started working again. two weeks later it has done it again. i found that if i turn the power button off and then on again the monitor will come on about 10 to 20 seconds and then go out again. this is a repeatable occurance. once it stayed on a little longer. during this occurance the screen had a notable red hue about it.
  • 732 Answers
Sirrichard, The first thing you should have typed out is the model number and then the "date of manufacture", all of which could be found the rear of the unit!! Next thing is PROVE that your pc not causing "black screen of death" symptom. Connect "known good" monitor to your pc. Next prove the monitor will do same thing at another pc if possible. Do a reply with more info so we can be of some help to you and your lcd monitor's "black screen of death" symptom. 12fixlouie
Posted on Oct 25, 2010
  • gigipompa Jan 09, 2012
    I have a Princeton LCD17D flat screen monitor and i am having the same problem. I already hooked it up to a different tower and the same thing keeps happening. I also connected a different power supply and nothing changed. The screen turns on at start up and then goes black after 20 seconds. But it is still powered on.
SOURCE:
Coolant level on 2006 Toyota Avensis Tourer 2.2 T180, Very Low within two weeks of being topped up?
have a pressure test done on the cooling system and find the leak
it could be in the radiator tanks , timing cover behind the water pump, water pump seal, head gasket, cracked head or welsh plug rusted out
check the sump oil condition and if it is grey that is where the water is going
Nov 14, 2015 | 2006 Toyota Avensis 2.2
Washer will start and then stop 5 seconds later. It will start again 2min later and stop 5 sec after that?
I have a front loading frigidaire washer which works fine. It starts and stops throughout the whole wash but gets the wash done. That is how it works.
Does your machine simply stop and not finish the wash? Or are you concerned about the length of time it takes to get the wash done?
Aug 12, 2011 | Frigidaire Washing Machines
New Invicta Men's Diving Watch--stops working after I set it the first time. I set it again,it works for awhile then stops again.Help
The problem you are describing is in the electronic timing module and there is nothing you can do but return it to the place of purchase for exchange.
Jan 13, 2011 | Invicta Watches
Just hooked up my pc yesterday worked fine. I shut down by going to start & turn off computor. Came back later to start back up. Monitor tells me in power safe mode. Tower doesn't seem to be starting...
You can try removing external devices like (ex. usb printer, external Hard drive) and try to start the computer again. And see if there are lights on the tower
Hope this helps
Jan 03, 2010 | Dell E173FP 17" LCD Monitor
Smoke from monitor LG Flatron EZ T710BH
Hello pepito,
If it's working fine now, that's great! For the while, it'd be best to leave it as is it, in a well-ventilated place (not too close to walls or heater or fridges) where it can't get overheated. See if anything else happens over the next week or so. If it does again, you'd probably be able to guess what it is now, if not overheating (maybe voltage fluctuations...or maybe there were some tinkerings on with the monitor?). Either way, get it checked soon. Better to do that while it's still running.
Jan 03, 2010 | Computers & Internet
2000 grand am se blower
It could be the actual switch maybe???
May 05, 2017 | 2000 Pontiac Grand Am GT
Component Video Problem--Again
Had to get my chassis replaced for similar reasons. it was still under warranty so i lucked out. however i was out of a tv for 3 months off and on because of all the troubleshooting that had to be done before Mitsu said replace the chassis
Apr 12, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Computers & Internet Logo
316 people viewed this question
Top Proview Computers & Internet Experts
 Mike M
Mike M
Siul Oyaratgam
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
