Question about GE DVL223EBWW Electric Dryer
Electric dryer does not heat up (brand new first time use)
    New Friend:
  • 85 Answers
Check breaker in electric box
Posted on Oct 25, 2010
SOURCE:
Dryer turns, but why doesn't it heat?
The dryer may have been installed incorrectly or the heating element may have suffered early failure. If the dryer is new, it should be covered under warranty.
Jan 26, 2016 | Whirlpool LER4634J Electric Dryer
Electric dryer..have heat on auto heat cycle, but no heat on timed cycle why?
If you have normal heat on Auto cycle, I have seen a few times that these new dryers channel the heat circuit separately through the timer for auto and timed cycle's. This isn't normal but you have a bad timer. But for any other readers this isn't a common problem generally the timer use's the same heat contact for auto and timed cycles, this is the exception.
Mar 26, 2015 | Whirlpool Dryer. 3.8 cu. ft. Electric...
Dryer not heating. Originally worked for 10 minutes then stopped. Cleaned inside - spotless. Installed brand new ignitor (glow type) old one was fine - didn't need changed. Worked for 10 minutes...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 07, 2011 | Kenmore Dryers
Brand new dryer won't heat. Tumbles fine - but no heat. Maytag 2000 series. I already checked the breaker - no problem
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 27, 2011 | Dryers
Electric maytag dryer brand new won't heat
could be the thermal fuse, but if it is new then call the warranted service man!
May 02, 2010 | Maytag Centennial 7.0 Cu. Ft. Super...
Brand new Maytag Centennial electric dryer does not dry clothes!
It may have shipping damage, such as a loose or broken connection or heating element.
But if it's brand new, it's under warranty, and they will fix it free.
You can find your nearest Maytag-authorized servicer here.
Jan 09, 2010 | Maytag Appliances Over-the-Range Microwave...
Dryer wont heat
the thermostats will go bad from time to time. these can be ohm out to see if they are faulty. research your model/name brand dryers troubleshooting guide, model/name dryer not heating, test to preform. this should help you isolate the problem.
Oct 22, 2009 | Fisher and Paykel DEGX1 Electric Dryer
NEW Electric Whirlpool Cabrio Steam Dryer; NO HEAT
Check temperature sensor.  Check to see if heating element is OK.
May 29, 2009 | Whirlpool GEW9250 Electric Dryer
Kenmore dryer will not dry completelt in even heat cycle
This video will help you to determined what you need,
copy n paste
http://www.youtube.com/watch?v=HRKIU4LiS20&feature=related
for parts n prices
http://www.partselect.com/AppliancePartList.aspx?Brand=Kenmore&Appliance=Dryer&ModelNum=&Type=Electrical%20Parts,%20%20No%20Heating%20Elements&MinSize=U&MaxSize=U&Electrical=Y&Metal=U&Plastic=U&OneColor=U&PageSize=15&FirstPart=1
Was this helpful?
Apr 29, 2009 | Kenmore 63942 Dryer
GE DVL223EBWW Electric Dryer Logo
65 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
vince
gbob59
Are you a GE Dryer Expert? Answer questions, earn points and help others
