Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Install mower belt - Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
  • 110 Answers
Lift the front of the tractor about 3 feet off the ground& remove the right side rear mower hanger to give you clearance to do the job. Make sure you get the belt on the pulleys and not rubbing a blade brake arm or an idler pulley keeper or the new belt will burn off in about 10 minutes.
Posted on Oct 24, 2010
SOURCE:
Why would a reasonably new mower belt be slipping
could be a few things, (1) is the belt designed for use on mower, car fan belts are not the same material (2) was new belt installed to tight to begin with if so it will stretch out and slip ( 3) is mover over used to it's designed purpose , I once new a guy that used his craftsman mower to move his 22 foot boat/trailer around he went thru lots of drive belts
and last but not least that cheaper belt might not be the best deal when getting replacement parts , all mine have 30 dollar kevlar belts (yes the bulletproof stuff) installed on them and i've no problems with belts
May 16, 2014 | Garden
How to install deck belt 46" riding mower mtd
most mowers have a diagram located on either the deck itself or on the mower could be located on the bottom of the step where the brake pedal is
Oct 22, 2012 | Mtd Garden
How to replace a belt on my 52
Put the lawn mower on blocks, look for a pulley or guard that retains the belt, remove it, remove the old belt, install the new belt, install the part you removed to get the belt off, done.
Apr 21, 2012 | Garden
How to install Mower blade drive belt on 19.5 HP Craftsman 42" Lawn Tractor-Model # 917.270810, without removing mower from tractor.
Hi donsig245,
What I do is to drop the mower assembly to the ground, then I have enough room to install the drive belt without having to remove the mower assembly. You could put the tractor on blocks to lift it up higher so the mower might go a little lower, but it is the same procedure to install the belt. That is the only way I know to install the belt without removing the mower assembly. I know this is not what you wanted to hear, maybe somebody might have another idea that would help you. Regards and good luck.
Mar 12, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How do I get the lever to shift to lift the mower so that I can replace the belt? 19hp, 42", year unknown craftsman turbo
If it is the drive belt do the following place your mower on a level surface set parking brake, remove mower deck, remove belt from stationary idler and clutch idler, pull belt slack towards the rear of tractor , then remove belt upwards from transaxle pulley by deflecting the belt keepers, then pull the belt towards the front of mower and remove downwards from engine pulley Install new belt in reverse procedure
Jan 22, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How to change the v-belt on a craftsman walkbehind lawn mower,
Remove the belt cover, Remove the blade and blade adaptor. Remove belt guard and slip off old belt. Install new belt just like it was removed. Install parts and you should be good to go. Hope this helps
Nov 20, 2009 | Craftsman Garden
Broken belt
This is actually pretty simple:
Remove Pto guard on mower deck
Stand mower up on back stands
Pull the friction disc away from the drive disc
slip new belt in between the friction disc and drive disc pushing all the way through
release friction disc allowing to come back in contact with drive disc
loop belt around engine pulley
let mower back down
route belt around mower pulley
loosen guides on idler pulley
route belt through idler pulley
with engine off move pto lever to tighten mower belt
adjust guides on idler pulley allowing 1/8" from belt
tighten bolt on idler pulley
release pto tension
install mower pto guard
and you should be ready to mow
Aug 14, 2009 | Garden
Need instructions how to install belt on self propelled craftsman push mower
raise the front of your mower up and support it with something safe like a jack stand
take the blade off
when your blade is off locate the plastic cover covering the belt and remove
now remove the belt but first remove the plastic cover on top of the mower to uncover the gearbox that turns the wheels your belt goes from the engine pulley to the gearbox pulley
you will have to work the belt off the pulley while turning the motor by hand or the same when installing the belt.
to install belt reverse the procedure.
hope this helps some
Jun 06, 2009 | Mtd 22" White Outdoor Self Propelled High...
Can't figure out how to install main drive belt on riding mower.
Usally if you look on the bottom of of your mower deck it will show you the route you need to go
May 31, 2009 | Garden
Drive belt
I don't have an answer for you, but Do you have a diagram of the Drive Belt?
Mar 14, 2009 | Husqvarna 22 Hp 46" Deck Yard Tractor
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
103 people viewed this question
Top Craftsman Garden Experts
john h
lnbn1975
Sheldon Dedek
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
