Question about Brother HL4040CN Laser Printer
Mon imprimante Brother HL 4040CN se met en erreur E1 sur ecran rouge je l'arrête et la redémarre mais plus moyen d'imprimer?
SOURCE:
redhaze89
  • 854 Answers
SOURCE: Brother HL-4040CN Fuser Cover
Click this link below;
http://www.uninetimaging.com/newsletter/Brother_HL_4040_TN_115_Reman_eng.pdf
Posted on Sep 08, 2009
bschilz
  • 2049 Answers
SOURCE: Brother HL-4040CN successfully installed but shows offline
I assume it's turned on and connected to the router.
Sometimes with DHCP, the IP address on the printer will change. I end up going into the router table to see what IP addresses are assigned where. Invariably I'll find my network printer has changed. Find the printer and write it down.
In Windows, Go into Printers> choose the Brother and right click to check Properties. Look for Ports and change the IP address as needed. It will come back online.
Posted on Sep 17, 2009
  • 4 Answers
SOURCE: Difference between Brother HL-4040CN and HL-4050CDN printer
HL-4040CDN supports BR--Script (like Postscript) and
HL-4040CN does not.
So, there is a "postscript" diver for the 4040CDN, but not for the 4040CN.
Posted on Nov 11, 2009
  • 73 Answers
SOURCE: I have on my Brother HL-4040cn, drum end soon.
Here is a photo of the drum unit and a link to the Brother website for you printer.
http://www.brother-usa.com/support/default.aspx?PGID=1&R3ModelID=HL4040CNaefb82c.gif
Posted on Mar 11, 2010
mariolands
  • 2296 Answers
SOURCE: MON IMPRIMANTE LEXMARK T640N AFFICHE UN CODE D
Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model T640n, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
If the printer is out of warranty, your next option is to change the fuser which costs around $350, so I think you would be better off getting a new printer unless you find a second hand one on Ebay.
Posted on Feb 18, 2011
Error code 0xb814728e
Bon je fais mon feedback aussi pour ceux qui ne comprennent pas l'anglais. J'ai ouvert par inadvertance ma HP photosmart a fond, je parle pas du petit couvercle de scan, mais de la grosse ouverture la ou on met les cartouches... et MERDE ! elle voulait plus se refermer ! Surtout ne pas forcer, mais bon en general ca donne l'impression de quelque chose qui bloque, donc une personne normale ne va pas forcer. La solution (que j'ai trouvee sur ce site, merci) c'est de se procurer du WD40, ce lubrifiant bien connu, et d'en arroser les charnieres. En manipulant doucement votre imprimante, vous allez voir, elle va se refermer gentiment au bout de dix minutes. Quel soulagement !
Aug 29, 2013 | HP Photosmart 3310 Printer
Slt est ce quon peut avoir des fractions sur la calculatrice je suis nouvelle sur son utilisation en plus jy conai riien pour le moment et en octobre jdoi faire la 1ere jsuis du senegal jveux que vous...
Bien que je n'appr?cie pas de lire un texte en charabia, je vais essayer de r?pondre ? ta question.
Si tu as une touche MATH, appuie dessus. Tu devrais voir alors une liste de commandes parmi lesquelles figure une t?te de fl?che ?paisse devant FRAC. Saisis ta fraction, appuie sur MATH puis s?lectionne la commande >Frac. Appuie sur ENTER. Le r?sultat sera LA fraction r?duite ?quivalente.
Si tu veux convertir une fraction en sa repr?sentation d?cimale fais la m?me chose que ci-dessus mais s?lectionne >DEC.
Sep 15, 2011 | Texas Instruments TI-82 Calculator
Bonjour je viens d aquerir une imprimante ricoh gx 3000sf sur une vente aux enchere et le probleme que j ai actuellement c que quand j allume mon imprimante elle se met en securite et m indique sur l ecran...
Bonjour , latasca09
L' imprimante est sans doute bloqu?e par un objet ( morceau de papier ) coinc? dans les rouleaux . Je ne suis pas familiaris? avec ce mod?le mais il faudrait enlever le couvercle pour acc?der aux rouleaux et voir ce qui se passe . Un simple bout de papier ( souvent du collant ) suffit ? provoquer la panne .
La m?canique doit ?tre impeccablement propre .
Il faut aussi v?rifier si le pilote correct a ?t? valablement install? , notamment en fonction du syst?me d'exploitation .
Je d?brancherais l' imprimante pour commencer et desinstallerais le logiciel/pilote . Faire ensuite un red?marrage de l' ordi . R?installer le logiciel / pilote et rebrancher l' imprimante apr?s installation .
Attendre confirmation que le pilote a ?t? install? correctement .
Verifier aussi dans le gestionnaire des p?riph?riques s' il n' y pas un probl?me de pilote .
J' esp?re que ceci pourra t' aider .
Cordialement ,
fanaudi .
Mar 20, 2011 | Ricoh GX3000sf InkJet Printer
Lorsqu on veut jouer a la wii sport sur mon ecran ca indique ceci et je comprends rien et je nest plus mon manuel : the game disc could not be read please read the wii operations manual for more...
La prise AV Multi Out qui est inclus avec la Wiivous permettra de connecter la console ? la plupart des t?l?viseurs ou CRV. Tout d'abord,regardez ? l'arri?re de votre t?l?viseur et votre magn?toscope et de voir si vous avez des trous de couleur label "Entr?e". Bien que la plupart dest?l?viseurs ont, presque tous les magn?toscopesfaire aussi bien. Si vous ne parvenez pas ? trouverun ensemble d'entr?es AV jaune, rouge et blanc ? l'arri?re de votre t?l?viseur, essayez de regardersur les c?t?s, en haut et en bas du t?l?viseur.Recherchez les panneaux cach?s ou des portesainsi. Connexion ? un audio T?l?vision / Vid?o(AV) entr?es sont g?n?ralement situ?s ? l'arri?redu t?l?viseur, mais parfois sont sur les c?t?s, en haut ou en bas. Rechercher des entr?es marqu?esAudio et Vid?o IN. Ne pas connecter votre syst?me ? tout trac?. Vous ne voyez
Jan 21, 2011 | Nintendo Wii Console
J'ai un code erreur 5200 .... quoi faire ?
Ce code d'erreur vous dit que l'unit? de purge n'a pas compl?t? un bon pouvoir sur le cycle et la came n'est pas dans la position correcte. Typiquement ceci signifie que l'unit? de purge est enfonc?e prolong? en raison de l'accumulation de beaucoup d'a s?ch? de l'encre.
Ouvrir la couverture et quand la t?te vient au centre, tirer le cordon d'alimentation. Une fois ce pouvoir est de peut vous transf?rer maintenant la cal?che ? l'extr?me gauche si c'est ? un endroit o? il ne vous g?nera pas. Maintenant utiliser une serviette en papier et tacher doucement toute l'encre suppl?mentaire de des Coussins d'encre et les appuie en bas. Si la lame d'Essuie-glace est ?tendue, le nettoie et il devrait claquer de retour en place. S'il est toujours enfonc?, essaie vaporisant le secteur avec Windex mais n'importe ne lequel obtient pas sur n'importe quoi sauf les coussins.
Nouvel An heureux !
Si je pourrais ?tre de plus ample assistance, me permettre de savoir. Si ceci aide ou r?sout le probl?me, s'il vous pla?t l'?valuer et donner un t?moignage pour ma r?ponse.
Merci, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 01, 2011 | Canon Pixma MP500 All-In-One InkJet...
Bonjour, j'ai un problème avec ma MP600. Elle n'imprime plus en noir. Pourtant lorsque je lance une impression noir et blanc elle fonctionne comme si elle imprimait, mais à la sortie, la feuille...
English to French translation bonjour il se pourrait que votre t?te sur votre imprimante est bloqu? aller ? la maintenance de votre imprimante et faire le nettoyage de vos t?tes dans la partie maintenance de votre imprimante, il vous dira everthing comment le faire
Oct 08, 2010 | Canon PIXMA MP600 all-In-One InkJet...
SOLENOIDS RESTE EN CONTACT
please translate to english-I can help
Jun 18, 2010 | 1979 Harley Davidson XLH 1000 Sportster
Bonjour ou se trouve le reste sur ce modele?? j'ai DEG de programme dessus et je ne suis pas capable de l'enlever. merci
écoute, ne te fâche pas : je ne comprends pas le sens de ta question et je devrais m'abstenir de te venir en aide, craignant d'interpréter incorrectement ton problème (et ce n'est pas ma maîtrise de la langue de Molière qui est en faute!!) Mais je vais quand même essayer de t'aider.
L'indicateur DEG que tu sembles vouloir éradiquer est parfaitement inoffensif. It est affiché sur l'écran pour te rappeler que l'unité d'angle est le degré. Cela signifie que tout argument que tu fournis à une fonction trigonométrique (sinus, cosinus, tangente, cotangente) est interprété comme une valeur en degrés. Donc si tu calcules sin(Pi) ne t'attends pas à obtenir 0 mais le sinus de 3,14.. degrés.
De même, toute valeur retournée par une fonction trigonométrique inverse ( arc sinus, arc cosinus, arc tangente, arc cotangente) sera en degrés.
Si tu changes l'unité d'angle de degré à radian, l'indicateur RAD sera affiché quelque part sur l'écran. Donc je te suggère de ne pas t'acharner à faire disparaître cet indicateur: Il ne fait que te monter quell unité d'angle tes calculs utilisent. C'est plutôt commode, ne trouves-tu pas?
Maintenant, si tu veux préciser ce qu'est ce reste que tu cherches, peut-être pourrais-je t'aider? Tu n'as qu'à faire un commentaire et je verrai ce que je peux faire.
Jan 17, 2010 | Casio FX-250HC Calculator
Pourquoi code erreur 52030
Bonjour,
Mon nom est Brandonmxb. Je veux essayer de vous aider du mieux que je peux. Je ne parle pas anglais, mais puisque vous parlez français, j'ai appris la belle langue, ou bien je viens d'utiliser Google Translate. Bref, voilà votre solution.
Certains utilisateurs ont un problème de reconnexion à la fonction WiiConnect après la mise à jour il ya des systèmes.
Si vous avez trouvé soit un 32002 ou une erreur 52030 essayez de changer votre canal sur le routeur à 11 ou 1. Si votre déjà sur l'une de ces chaînes aller de l'avant et mettez-le à tout le reste, laissez le cycle de routeur, au moyen (redémarrera après le changement), puis changez-le sur le canal 11 ou un. Aussi, si vous avez un téléphone sans fil aller de l'avant et de l'éteindre juste pour s'assurer qu'il n'y ait aucune interférence. Si rien de tout cela fonctionne aller de l'avant et appeler Nintendo sur l'organisation d'une unité de remplacement ou de dépannage mai ils vous fasse.
Pour les "routeurs Linksys WRT54G" Entrez l'adresse IP du routeur (par défaut est 192.168.1.1) le mot de passe et nom d'utilisateur (par défaut admin / admin) puis cliquez sur l'onglet sans fil, maintenant sélectionner un autre canal sans fil dans le menu déroulant. Ce correctif mai ne fonctionnera pas pour vous, mais il vaut la peine d'essayer, et à nouveau ce correctif n'est pas garanti de fonctionner pour toutes les consoles.
Si cela a permis, s'il vous plaît taux de moi.
Besoin d'aide?
Aller à: http://www.nintendo.com/consumer/
Appelez: 1-800-255-3700 *
Dec 12, 2009 | Nintendo Wii Console
Brother HL4040CN Laser Printer Logo
353 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
