Question about LG LMVM2055 Convection/Microwave Oven
Condensation from boiling water microwave keypad want respond
Remove the keypad and use a multimeter to test it for continuity. If the keypad is not getting power then it has shorted out because of the excess condensation. Replace the keypad, it will cost around $30 for the part. Click on the link link below to order the part you will need:
http://www.repairclinic.com/PartDetail/Touchpad/1304975
Posted on Oct 24, 2010
SOURCE:
Samsung Microwave Oven Model smh918713 beeping
You may need to replace the keypad. I found there was moisture causing the problem when we boiled water on the right side of our stove which is under the keypad. I let the microwave dry out for several days and now only use the left side of stove when we boil water and have not had the problem.
Oct 19, 2012 | Samsung Microwave Ovens
Panasonic microwave NN-S698WC- power is on, light is on, keypad does not work
No! the keyboard was already failing, But I'am more concerned the keypad control board is the issue and one of the most expensive pieces.
Jul 11, 2012 | Microwave Ovens
Glass in over the range microwave fogged up after boiling vegtables on range top
It will do. The glass is cooler than the water vapour and will condense, causing fogging.
Mar 28, 2011 | Samsung 1.8 Cu. Ft. Over-the-Range...
What does the F3 alert indicate for a GE JES1238WH001?
F3 is a shorted keypad. Unfortunately you need to replace your touch pad to correct the issue. This can happen sometimes from moisture getting into the keypad from boiling water, or it can happen for no reason at all.
Sorry there is no parts available for the microwave.
Good Luck please rate 4 thumbs up and please leave a testimonial
Oct 30, 2010 | GE Microwave Ovens
Keypad not working after boiling water below
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls.
I always recommend that you spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
And I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
If it does not dry out over time, it may need to be manually dried or blown out.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts here.
I'd recommend that your bookmark this link to your favorites.
Otherwise, the keypad may be damaged or worn out, or control unit may be damaged.
Feel free to contact me directly (and please include your full model number from the tag in or on the unit) for a free estimate and free tips & do-it-yourself advice.
Your full model number would be one of these: JVM1540DM1BB JVM1540DM1CC JVM1540DM1WW JVM1540LM1CS JVM1540SM1SS
William E. Miller
[email protected]
http://www.microwavedisplay.com
Feb 09, 2010 | GE JVM1540DM Microwave Oven
Boiled water and it exploded, now the microwave is broken
wow, from the looks of it you need to unplug wait 60 seconds plug in to restart, ot buy a new microwave. Perhaps if in the microwave terms it didn't say not to do that call the manufacturer and the will replace it for free
Jul 03, 2009 | Maytag MMV5000 Microwave Oven
LG Microwave oven LMVM2055ST
Same issue here. LMVM1935 about 2 months past warranty keypad stopped working. Apparently they need to add something in the manual about not boiling water on the range over which the microwave is installed (gee who would have thought that there would be steam over the cooktop and we should seal the membrane?).
The silver traces on the keypad got corroded and no longer conduct. After complaining to Sears (NO HELP) and LG (EVEN MORE INEPT) and running on 30sec button for about 6 months, I found a replacement keypad $30 w/ shipping and didn't break anything taking the door apart, thanks to the parts list link above. Thanks Rickzilla!
Life's Good, Their Keypad SUCKS, or apparently we are the only people that boil water anymore.
Sep 05, 2008 | LG LMVM1935 Convection/Microwave Oven
Condensation betwejn the front door glass
This would require disassembly of the door panels, which is not recommended unless really required.
You can download the installation guide to help you troubleshoot and correct your venting issues. That should be priority one.
It may be a clogged filter, a bird's nest in the outlet, etc. etc. Failure to vent can cause control panel and keypad trouble if it continues.
The manual / guide is found here: http://www.geappliances.com/service_and_support/literature/
Nov 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
At times some butons don't work
You may have a bad keypad, which in many cases can be replaced.
A bad keypad may be worn out due to age, damaged, or it may have gotten wet or otherwise contaminated.
Moisture and contamination can be caused by not using the fan when boiling on the stove top (for over the range models), direct spraying of cleaners, by storing the microwave in an unheated garage or shed, or infestation.
I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller.
You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Aug 10, 2007 | Hotpoint RVM1425 Microwave Oven
LG LMVM2055 Convection/Microwave Oven Logo
158 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
