Question about Pioneer SD-P50A3-K TV
Tv turning off automatically
You will turn tv on and it will click and turn itself off instantly
  • yangbouy Oct 18, 2008
    Yes, I guest it's the main problem for the Pioneer SD-P50AK TV, It will shut off by itself after a few moment of viewing.
  • Ben_10 Feb 21, 2009
    I got mine fixed about a year ago by a local repair guy (Toronto) who came to my house, replaced 2 of the power chips and re-soldered a bunch of the connections and it has been working great ever since. I could track down the guys contact information if anyone is in the area and interested.
I have the exact same problem. did you get a fix?
Posted on Sep 06, 2008
How do I reset the volume on my tv?
your controlles on the tv set itself goes faulty simply spray some switch cleaner in buttons should sort you out
Sep 15, 2014 | Toshiba 40RV525U 40 in. LCD TV
TV switches off automatically.
if you take the cover off, then take a look at the capacitors.
check if any have bump ..
Jan 13, 2014 | LG Televison & Video
TV will not turn on, it just clicks.
Check the output voltages (usually marked on power board) to see if at the moment of turn on they come up and or instantly go to zero--a way to see if something down stream is pulling voltages down.
If power board did not cure it could be main board or another board--I have seen some where the display panel itself was bad and causes this problem--that is fatal.
May 30, 2012 | Televison & Video
My tv turns off automatically
I think your TV was set to turn off by itself automatically. Try to reread the manual about it.
Jun 18, 2011 | Vizio Televison & Video
TV worked fine for 12 years till this evening. When I push the power button there is an electronic clicking sound inside but the set will not turn on. The speaker still makes the quiet popping sound it...
The tv has a high voltage problem, sets that last ten years or more have come to the point where a new tv should be considered, because even if you fix it there is good chance something else will go wrong, remember the parts are twelve years old.
Jan 05, 2011 | RCA F25216BC 25" TV
TV will not turn on
There is a problem with your power ic..U need to replace it...
Dont forget to rate
Sep 07, 2009 | RCA 36V430T 36" TV
Lg tv automatically turn on and off. Power surge
the software in the main control is damaged. call your lg servicer in your area. he might get you a software update
Jul 06, 2009 | LG 47LC7DF 47 in. LCD HDTV
Philips Magnavox TV turns itself off and on
I had a problem that has not been fixed that i had put glass cleaner on my tv and every time i turn it off it comes back on sooo i do not have a solution so i need more and cheap ways to fix my tv.
p.s. i am 9
May 19, 2009 | Philips Magnavox 32PS55S 32" TV
I don't want AIM or Instant Messenger to automatically go on when I turn my machine on. What can I do? Also, can I use the video chat with simply AIM?
Normal 0 Go into the messenger and go CLICK on GENERAL and then CLICK on PREFERENCE.
Then under “When I Start My Computer” and remove the check from “Automatically Start Yahoo Messenger”. Then click OK.
It should be similar in other messengers to keep it from starting when Windows starts.
Hope this helps. Bud
Dec 29, 2008 | AOL Instant Messenger
RE: Sharp Aquos LCD TV, MODEL LC-37D40U Tried to switch the TV on via remote, and I hear the TV turning on, but then it automatically turns itself off again. Tried it several different ways using...
A component is shorting out, and the TV is auto turning itself off for protection. Usually it is a shorted out horizontal output transistor. Only a tech can fix this.
Nov 13, 2008 | Sharp Televison & Video
Open Questions:
Pioneer SD-P50A3-K TV Logo
329 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
