Question about Sharp R-9H84B Microwave Oven
I have a Sharp convection over model R-9H84B and the turntable piece is broken. One of it's three tabs is broken off so it will no longer turn the table. Do you know where I could get one of these? Thanks!
    New Friend:
They aren't cheap, but I found them here:
http://www.repairclinic.com/PartDetail/Glass-Tray-Drive-Coupling/1266724
I was looking because after 15 years, my drive coupling cracked out where it connects to the turn table motor. Getting it out isn't that difficult - just remember to unplug the oven before you work on it. If the old coupler won't come out with gentle and even prying, flip the oven upside down - there is a small door on the bottom help shut with a single philips (+) screw which will give you access to the motor. Remove the two philips screws and lift the motor out and then use your screw driver to gently encourage the coupler out. I found removing the motor was the easiest way to install the new coupler - install the coupler then the motor while holding the coupler in upside down. I have the model with the door opening like a conventional oven door and it will not want to stay open for you while the oven is upside down. Either have some one hold it open while you have an arm in there or be prepared to have your arm squeezed a bit.
Cheers,
David
Posted on Jan 10, 2011
  • fallingMan Jan 10, 2011
    Poked around a bit more and found the following information:
    The SHARP part number is NCPL-A058WRFZ. Encompasshttp://www.encompassparts.com will sell you one for $24.65 or you may be able to find them cheaper via google.
    I just discovered Sears PartsDirect. Here is the link and they only want $5:http://www.searspartsdirect.com/partsdir...
SOURCE:
Sharp carousel ii microwave
Turn table does not turn , sharp convection microwave R-9H84B
Can I fix this myself? or do I need to have it serviced?
Dec 06, 2013 | Sharp Microwave Ovens
What is the wattage of model R-9H84B
That model had 900 watts of microwave power output, and the convection outpout was 1450 watts.
Jun 18, 2011 | Sharp R-9H84B Microwave Oven
Sharp Microwave/Convection vintage 1994, model # 9H84B turntable has suddenly stopped turning. When functioning, table could start rotation in either direction.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Nov 07, 2010 | Sharp Microwave Ovens
We have a sharp r-9h84b convection microwave and the carosel has stopped working when the tray is in place. Any thoughts the carrosel seems to rotate very slowly when there is nothing on it.
It's almost certainly a bad turntable motor.
The part number was RMOTDA079WRE0 but it is listed as no longer available.
In some cases, older microwaves are available locally at repair shops or on Craig's List.
If you want to keep your eyes open, this same motor was used in the following Sharp models:
R9A20
R9A50
R9H11
R9H60
R9H66
R9H71
R9H73
R9H76
R9H80
R9H81
R9H81B
R9H83
R9H84
R9H84B
R9H91
R9H91B
R9H93
R9H94
R9H94B
Good luck.
May 23, 2010 | Sharp R-9H84B Microwave Oven
I have a Sharp 930 Convection Microwave that is no longer rotating. Any help?
This problerm is commonly attributed to a turntable motor that is no longer working. If the model number you posted this question under is correct, the part number for a replacement turntable motor is 46-841666-3. You may also consider replacing the turntable coupler (also called the turntable shaft). The part number is NCPL-A021WRFO. If your existing coupler is still in good shape, there is no need to replace it.
Replacement parts can be purchased on line at searspartsdirect.com. There is a complete list of helpful exploded view parts illustrations to assist you with parts identification/location.
If you need instructions on how to replace a turntable motor, the following link explains:
http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
If you have any questions, please post back and let me know. I hope this helps you.
Jan 29, 2010 | Sharp R-930AK Convection/Microwave Oven
R9H84B Sharp Microwave Convection from 6-6-1997, power stopped and turntable stopped. Light works and sounds like the power is working but nothing gets hot.
Is this the unit with the door that swings down like a conventional oven?? I think it is. This sounds like a door switch but could be a magnetron or cook relay on the control PCB.
Sep 11, 2009 | Sharp R-9H84B Microwave Oven
Convection microwave turntable does not turn. Makes a clicking noise.
Try removing the turntable plate, and then lift up on the roller assembly that the plate sits on. These roller assemblies are usually made of plastic, and often times the center "axle" (the part that goes down into the hole in the bottom of the microwave) breaks or cracks. If it looks like this piece is cracked or broken, just take it down to an appliance repair store (or just write down the model # of your microwave and bring it with you). Replace the roller assembly, and you're good to go.
You can also find these roller assemblies online pretty easily as well, and they're usually under $10 USD.
Good Luck.
Aug 25, 2009 | Sharp Microwave Ovens
Microwave turntable won't turn
Most likely the turntable motor itself is bad - not an uncommon problem for that model.
Check with www.martinmicrowave.com (toll free 1-877-894-0035)
unfortunately, the particular motor used in your model is rather expensive - + - $50
Dec 23, 2008 | Sharp R-930AK Convection/Microwave Oven
Sharp Microwave Model R-9H84B Timer problem
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour and try again.
If it still doesn't work, it would probably be a failed circuit board, and the oven would have to be retired since these are no longer available.
Oct 30, 2008 | Microwave Ovens
Sharp Carousel Model R-9H56
Check that the plastic connector from your motor to the turn table is not broken , mine broke and it took weeks to solve the problem. Try rotating the part that protrude into the oven. If you can turn it by hand it is broken, lucky cheap to replace
Nov 21, 2007 | Sharp R-510HW Microwave Oven
Microwave Ovens Logo
137 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Ekse
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
