Question about RCA F35731MB 35" TV
My RCA F35731MB will not turn on. there was no other problems before this. its not the power button as I can hear the click when button pushed. I work on computers and laserjet printers and have worked on monitors so I know how to avoid being shocked and feel confident about replacing any part in tv. I just need to know where to look for power supply info and how to replace it.
    Top Expert:
  • RCA Master
  • 76,140 Answers
Hello
It is very give you advice as you are aware of it. So do one thing. As far as the device is not turns on its power, the fault should be somewhere around the power supply system. Begin from AC mains chord itself. Check it for any break. If it is Ok, check whether supply is comming inside to your TV. Normally TVs have DPST type [Double Pole Single Throw] switches used for power switching. If any one of its poles not get correct contact inside, either phase or neutral will be cut. The click sound is not considered for its correct function. Check it also. It can be ckecked by measuring the voltage comes at rectifier points of your TVs power supply regulator section. If there is voltage, check the DC voltage across main filter capacitor. It must be some more than of your supply votage. I don't know the exact voltage you have as mains supply. Here in Idia, we have 220VAC 50Hz. At this supply voltage, DC voltage said above will measure more than 340VDC. Get a comparison with this when you check the voltage at the point mentioned above.
If it is also ok, there may be some fault in the oscillator section of the SMPS [Switched Mode Power Supply] section. There may be transistors or an Ic may be used to make oscillation to drive the switching transistor, which in turn drives the swiching transformer to get proper secondary low DC voltages needed to the circuit board. Check all the transitors. Of optocoupler is used check it also. Check its DC side control drive transistors.
Check all the zener diodes "off circut". ie take it out desoderd and check it with multimeter [preferably analogue type], set to 100K range. There should not be any leak at all. It is best to replace them.
Check all the resistors for its value marked, and all the transistors either for short or open.
Ok.
Posted on Oct 25, 2010
SOURCE:
How do I turn off the language setting screen
unplug it from the wall for 30 seconds
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Oct 04, 2014 | RCA F35731MB 35" TV
Rca D52130
Power supply or high voltage supply problem---set well known for bad solder connections in and around the high voltage transformer---also known in early models for the high voltage splitter to be bad.
typical high voltage transformer:
Nov 05, 2012 | RCA Televison & Video
I have a 36
Use the VGA cables red/white/yellow
Or if your TV supports it use Svideo or component
Oct 12, 2009 | RCA F35731MB 35" TV
RCA D52w20 TV WON'T POWER UP
I had the same problem and it was the cp150. It cost me $2. Easy to change. I would look in the back and see if any of the capacitors are popped or bulging out on the top.
Jan 30, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA TV
THE SOUND ON THIS MODEL WILL NOT WORK ( F35731MB )
ITS NOT THE MUTE ON THE REMOTE, ITS IN THE TV ITSELF.
Aug 31, 2008 | RCA Televison & Video
RCA Projection TV P52960
The clicking repeatedly is the relay clicking on and off due to the power button being pushed in. You are having problems with the start up circuit. Probably minor but you would need a service manual to actually diagnose the problem . Let me know if you would like me to post a link where you can get the service manual
Nov 19, 2007 | RCA P52960 52" Rear Projection Television
Tv PROBLEM
More than likely you have loose connections on the power supply board. Fixing the connections should take care of the problem.
Oct 03, 2007 | RCA F35731MB 35" TV
T.V. DO NOT TURN
There could be a problem in the main power supply or perhaps the standby power supply. To me at a guess i would say there is most likely a bad capacitor in the standby power supply or there is a problem in the switch mode power supply. if you have no electronic troubleshooting skills, play it safe and take the set into a repair shop or replace it. Now a days, a 32" TV set can be had for under 200bucks. Good Luck
Jun 13, 2007 | RCA F35731MB 35" TV
Flickering Picture?
Your set might have a high voltage leak and that is the noise you hear when is showing the screen problem or even maybe an arking too ,either one is related to the high voltage and it can be dangerous,if you are familiar with tv service you can try to see where is arking and replace the part with an exact replacement but if the set has a leak you will not see it and is not safe to be close to it,if you are not too familiar be safe and call for assistance from a servicer.
Oct 27, 2006 | RCA F35731MB 35" TV
Televison & Video Logo
110 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
