Question about Kirby Ultimate G Bagged Upright Vacuum
How do I attach and use the carpet cleaner with my new kirby sentria?
Please respond; I received no directions.
Sandra Rader srader39@yahoo.com
  • Anonymous Dec 06, 2008
    same as above
  • JP Butts
    JP Butts Nov 04, 2015
    Go to youtube.com and type in your Kirby name and model #. Find a set of videos that explain the total use of your machine.
I have a Sentria and I typed my question about the carpet shampooer into my Google "bar" and got directions from someone called "Bosslady"......The job is done. From FixYA I got the number of Kirby and they returned my call this AM and I will get a Manual.
Thanks for you help, Sandra
Posted on Jun 10, 2008
I am shampooing a berber carpet with my Kirby Ultimate G and no excess water or suds accumulate in tray. Either while suds dial is on or off. Why do suds come out under tray in straight line no matte
SYSTEM:
Will work with:
  • Kirby G3 vacuum cleaner
  • Kirby G4 vacuum cleaner
  • Kirby G5 vacuum cleaner
  • Kirby Gsix vacuum cleaner
  • Kirby Ultimate G vacuum cleaner
  • Kirby Ultimate G Diamond vacuum cleaner
  • Kirby Sentria vacuum cleaner
  • Sentria II (Sentria2)
This is unused shampoo attachment. We buy new parts and assemble this shampoo attachment so you will be the first one to use it.
Set includes:
  1. Tray with shield
  2. Nozzle
  3. Brush roll
  4. Belt
  5. Container with cap
  6. Hose
  7. 12 oz. shampoo
NOTE - pictured Kirby Sentria shampooer box may not be included.
If you have never used this shampoo, we highly recommend reading our ONLINE MANUAL. This is a simple but very effective unit but you have to learn how to use it and "common sense" will not be enough! HOW TO - V I D E O S
Tank with soapy solution is attached in place of the bag. It utilizes the air coming out of the exhaust to blow soapy water on a small screen that turns it into thick foam. The foam is simply laid over the carpet (you must vacuum before you shampoo). Foam allows the spread of a small amount of water over the area so carpet is not soaked all the way through. Foam is left on the carpet for a few minutes so it has just enough time to moisten the fibers of the carpet and loosen the dirt (not too long otherwise foam may dry). Then foam maker is set to "OFF" and you slowly pull Kirby vacuum over the area where you laid the foam. The rotating brush in the shampooer nozzle rubs the moisture off carpet fibers and and throws it into the tray in front of the unit. You will not see gallons of dirty water but that is because you did not put it on the rug in the first place. Carpet should dry within 1-4 hours (depends how many times you laid the foam and what is humidity in the room). After it dries it has to be vacuumed. Solution that did not get picked up with the shampooer brush dries and shampoo additives do not let the dirt stick back to the fibers of the carpet. It is loose when it dries so in order to pick up what is left, you must vacuum again.
Shampoo:
You can use any carpet shampoo sold in your local store but make sure that this is carpet shampoo that makes foam and pay attention how much you have to dilute it with water as various shampoo products come in different concentration. Avoid using "just anything" that makes foam. Some household chemicals (such as dishwasher fluid) will do great job but it will leave carpet unprotected so dirt will stick to it so well that you will have a filthy rug in no time. Kirby Vacuum Shampooer
800-775-6586
GoodVac com
Feb 14, 2015 | Kirby Ultimate G Bagged Upright Vacuum
Tip
How To Attach The Carpet Shampooer To A Kirby Generation 5 (G5) Vacuum Cleaner
The Kirby carpet shampooer is an attachment that is used with the Kirby upright vacuum cleaners. It converts the Kirby from being used as a dry pickup vacuum, into a carpet shampooer and extractor. Unlike other carpet shampooers and carpet extractors, the Kirby shampoo system does not saturate the carpet with a lot of water when cleaning. Kirby shampoo systems use a special dry foam formula that gently cleans the carpet without saturation.
Installation
The link below is to an excellent, easy to follow and understand video that will explain step by step how to convert the Kirby Generation 5 (G5) from a vacuum cleaner into a carpet shampooer. Please note that the vacuum in the video is actually a newer Sentria model, however the repair procedure is identical on the G5 as it is on the Sentria.
Video Demonstration of Converting Kirby Generation 5 From Vacuum Into Carpet Shampooer:
http://kirbywhq.powweb.com/videos/Carpet_Shampoo.mov
If you have any questions about the procedure of converting the Kirby G5 into a carpet cleaner, please feel free to request clarfication on this video right here on the Tip page. I hope that this video was helpful. If you did find the video helpful, please kindly rate this Tip as helpful by clicking on the Thumbs Up Icon in the lower right hand corner of the page.
Thank you very much for watching,
Chris J.
on Mar 21, 2010 | Kirby G5 Bagged Upright Vacuum
Tip
How To Attach Carpet Shampooer To Your Kirby Generation 4 (G4) Upright.
This is an excellent, easy to follow video presentation of attaching the carpet cleaner to your Kirby Generation 3 Upright Vacuum Cleaner. Please note that the model being used in the video is a newer model named the Sentria, but the process of attaching the carpet extractor attachment is identical on the Kirby Sentria and the Kirby Generation 4. The only major difference is that the Generation 4 does not have the lever that extends out to turn the belt to off. On the Generation 4 this is dont by turning the entire white square with the Kirby logo on it in the front of the vacuum cleaner.
Please feel free to ask for a repair clarification if you have a question on how to attach the carpet shampooer. I'm always, more then happy to answer any follow up questions there may be.
Instructional Video On How To Attachment Carpet Shampooer To Kirby Generation 4 (g4) Vacuum Cleaner:
I hope that this helped you change your Kirby into a carpet shampooer. I you found this video helpful, please rate this Tip as helpful by clicking the Thumbs Up Icon. I really do appreciate it, thank you.
Chris J.
on Mar 21, 2010 | Kirby G4 Bagged Upright Vacuum
I am trying to assemble the shampooer part of my kirby sentria
Hi There,
Here's a link to a very helpful video that will walk you through step by step on how to attach the carpet shampoo attachment to your Kirby Sentria.
If you ever need to purchase some Kirby Carpet Shampoo, please visit the link below to our website. You may use coupon code GVC5 to save $5:
Kirby Cleaning Supplies, Including Shampoo, Stain Removers, and more.
Here's the link to the video instructions on how to convert into a carpet shampooer:
Video Instructions On How To Convert the Kirby Sentria Into a Carpet Shampooer
If you have any further questions or concerns please feel free to use the comment field to ask, I'm always happy to answer any and all follow up questions.
If this was helpful to you, please be so kind and rate my repair helpful, or leave some feedback for me, this is greatly appreciated by the Fixya Community Experts when they're able to help you solve your problems.
Thanks again,
Chris Jones
GoVacuum.com
Jun 11, 2010 | Kirby Ultimate G Bagged Upright Vacuum
Not sure about the parts and what they do
Hi There,
First for your Shampoo attachment, all Kirby generation models came with this carpet shampoo attachment. It really does do a nice job at cleaning carpeting and rugs. In terms of how you use it, here's two links for you, the first is written instructions on how to use it, and the second is a video that shows you how to attach it to your Kirby and use it. In the video it's actually the Kirby Sentria that they use, but the procedure on converting it from a vacuum into a carpet cleaner are the exact same for the Sentria as they are for your G5.
Written Instruction Manual For Kirby Carpet Shampooer
Video Instructions On How To Install & Use Kirby Carpet Shampooer Attachment.
Now in terms of the other part that you were asking about. I believe the part your asking about is called the Intake Guard. I think this is the part that you're asking about, here's a picture of the Intake Guard:
The Intake Guard is connected to the front of the machine only when you want to convert your Kirby from a vacuum cleaner into a blower. This protects anything from going into the fan while it's being run, as well as pushing the safety switch that allows the machine to turn on.
I really hope that this information was helpful to you. If you have any follow up questions, or need further help with your new Kirby G5, please don't hesitate to add a comment here on the Fixya repair page, and I'll be more then happy to answer any and all of your follow up questions.
If you found my repair helpful to you, please be so kind and rate my repair helpful, or leave feedback. This is greatly appreciated by the Fixya community.
Thanks again,
Chris Jones
GoVacuum.com
May 11, 2010 | Kirby G5 Bagged Upright Vacuum
Tip
How To Attach The Carpet Shampooer Cleaning Attachment Kirby Generation 3 (G3).
This is an excellent, easy to follow video presentation of attaching the carpet cleaner to your Kirby Generation 3 Upright Vacuum Cleaner. Please note that the model being used in the video is a newer model named the Sentria, but the process of attaching the carpet extractor attachment is identical on the Kirby Sentria and the Kirby Generation 3. The only major difference is that the Generation 3 does not have the lever that extends out to turn the belt to off. On the Generation 3 this is dont by turning the entire white square with the Kirby logo on it in the front of the vacuum cleaner.
Instructional Video On How To Attachment Carpet Shampooer To Kirby Generation 3 Vacuum Cleaner:
Chris J.
on Mar 21, 2010 | Kirby Generation 3 Bagged Upright Vacuum
I need to know if the round brush with flip lid is a carpet clean
Greetings from GoVacuum,
Here's an easy to understand and follow video review on how to attach the carpet shampooer to the Kirby Generation vacuum cleaners. The model that's being used in this video is a little newer model, the Sentria, but the procedure to attach the carpet cleaning attachment is the same exact repair on the Sentria as it is on your Kirby Ultimate G.
I hope this helps!
If that helped, please be kind and rate the video as helpful by clicking on the Thumbs Up Icon below. If you have any questions about how to install it, please just request a repair clarification and I'll be more then happy to help you.
Thanks for watching! Feel free to check out our website for all your Kirby vacuuming needs;
http://www.govacuum.com
Chris Jones
GoVacuum.com
May 06, 2010 | Kirby Ultimate G Bagged Upright Vacuum
Setting up to shampoo carpets with a Kirby
Here's an easy to understand and follow video review on how to attach the carpet shampooer to the Kirby Generation 6 (G6). The model that's being used in this video is a little newer model, the Sentria, but the procedure to attach the carpet cleaning attachment is the same exact repair on the Sentria as it is on your Kirby G6 vacuum2_bing.gif.
I hope this helps!
Chris
Mar 21, 2010 | Kirby Ultimate G Bagged Upright Vacuum
I need instructions on how to attach the Carpet Cleaner attachments to a Kirby Ultimate ( about 7 or 8 years old )
Greetings,
If you click the link below it will take you to a video demonstration that explains step by step what you need to do to convert your Kirby into a carpet shampooer. The vacuum in the video is the Kirby Sentria, but the procedure is the EXACT same as it is on your Kirby Ultimate G, just as it is with Kirby Generation 3, G4, G5, G6, etc. All Generation models have the same process of converting the vacuum into a carpet shampooer.
Instructional Video On How To Attach The Kirby Generation Series Carpet Shampoo Attachment:
I hope that this video was helpful to you. Please feel free to request a clarification if you have any further questions about the installation, I'm always more then happy to answer any question, seriously.
If you did find this video helpful, please kindly rate my soltuion as Helpful by clicking the Thumbs Up Icon at the the bottom right hand corner of this page.
Chris
Feb 27, 2010 | Kirby G5 Bagged Upright Vacuum
How to use shampooer on Kirby Sentria Upright
Kirby shampoo manual with plenty of pictures HERE
Good Luck
Rocky
Mar 23, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
188 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
