Question about RTO 1:1.2 Mower Gearbox Brush Hog Rotary Cutter Shredder
I have a Modern Super Sunshine Brushhog. What are the specs for the torque on the clutch pressure bolts?
    Top Expert:
  • RTO Master
  • 8,939 Answers
Some fixya user told me a website reliablestore it is very good.. I used it to repair my shredder it had some spark issue which wasn't easily fixed. you can go there and try
Posted on Jan 19, 2019
6ya staff
SOURCE:
Flywheel torque spec's for 1983 Ford F-100
Could it be a F-150 instead?
Ford Engine Bolt Torque Chart Bolt Torque Spec Chart for Ford Engines
These specs are for stock-type bolts with light engine oil applied to the threads and the underside of the bolt head. Moly and other lubes offer reduced friction and increased bolt tension, which will affect the torque figure. If you use after-market performance bolts like ARP's, you should follow the recommended torque specifications.
260, 289, 302 Torque Spec.
Fastener Type Torque Spec Main cap bolts 60-70 ft-lbs Outer main cap bolts 35-40 ft-lbs. Connecting rod bolts (40-45 ft-lbs. for 289 HP & Boss 302) Cylinder head bolts 65-72 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs Oil pump bolt 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolts 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351W Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 90-100 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs. Oil pump bolts 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351C, 351M Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (45-50 ft-lbs. For Boss 351C) Cylinder head bolts 105 ft-lbs. (125 ft-lbs. For Boss 351C) Rocker arms (non-adjustable) Rocker arms (non-adjustable) 5/16in. intake manifold bolts 21-25 ft-lbs. 3/8in. intake manifold bolts 28-23 ft-lbs Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 9-12 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs. 360, 390, 406, 427, 428FE Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Crossbolts for 406-427 40 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (53-58 ft-lbs. For 406 and 427) Cylinder head bolts 80-90 ft-lbs. (100-110 ft-lbs. For 1963-67 427) Rocker arm shaft bolts 40-45 ft-lbs. Intake manifold bolts 32-35 ft-lbs. Oil pump bolt 12-15 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 429-460 Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 140 ft-lbs. Rocker arms (non-adjustable) 18-22 ft-lbs. Intake manifold bolts 25-30 ft-lbs. Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs.
Dec 18, 2015 | Ford Cars & Trucks
? looking the bolt tension specs for flywheel and clutch pressure plate for 4hf1 thank you
Torque Specification - National Truck Spares ' Parts
www.nationaltruckspares.com.au/Parts.aspx?ProductTypeID=8...
1073, 4BC2 tq, Isuzu, Torque Specification, KT26 TLD57 NKR57 NPR57 ... 1075, 4HF1Tq, Isuzu, Torque Specification, NKR66 NPR66, 92 - 03, 4HF1, 4334
Small Block Chevrolet V8 Engine Specs ' Torque Specs ...
boxwrench.net/specs/chevy_sb.htm
Flywheel (Clutch). Thread Locker, 60 ft-lbs. Clutch Pressure Plate, Thread Locker, 35 ft-lbs. Centerbolt. (Harmonic Damper). Engine Oil, 60 ft-lbs. Bellhousin
Nov 07, 2015 | Cars & Trucks
Cannot find torque specs for 92 tercel. Clutch
clutch cover(pressure plate) 14lbs
flywheel 65lbs
Sep 01, 2014 | 1992 Toyota Tercel
What are the torque specs for the 4 pressure plate bolts for the clutch?
What year is it??
I am only familiar with newer models as per touring/six speed:
Install six bolts (5) (metric) to secure diaphragm spring
retainer to clutch hub. Alternately tighten bolts to 90-110
in-lbs (10.2-12.4 Nm).
May 09, 2014 | Harley Davidson FLHTC - FLHTCI Electra...
Looking for the torque specs for a 83 ford F 700 370 V8 rear main cap
v8_15426378.gifCylinder NumberingDistributor Rotationford_cyln_1234.gifv8_dist_ro_ccw.gifRotor Under Cap Spins:
Counter
Clockwise
Torque Specs
These specs may not be correct for your application.
Verify your engine specs with a service manual for your year and model.
always torque bolts in three equal increments
Bolts or PartsLube or SealerTorque to:Main CapsEngine Oil105 ft-lbs.Warning!!! If you are using ARP bolts, you MUST use
their specs. Click Here!Connecting Rod Bolts
Engine Oil45 ft-lbs.
Cylinder Heads
Engine oil
(blind hole)
Sealer
(water jacket)
140 ft-lbs.
Rocker Arms (non-adjustable)Engine Oil20 ft-lbs.Oil PumpEngine Oil25 ft-lbs.Oil PanEngine Oil15 ft-lbs.Cam Bolt (upper gear)Thread Locker45 ft-lbs.Front CoverEngine Oil20 ft-lbs.Intake Manifold
(Cast Iron Heads)
Non- Hardening Sealer30 ft-lbs.
Valve CoverEngine Oil10 ft-lbs.Flexplate (Automatic)
Flywheel (Clutch)
Thread Locker85 ft-lbs.Clutch Pressure PlateThread Locker35 ft-lbs.Centerbolt
(Harmonic Damper)
Thread Locker90 ft-lbs.Bellhousing
(Transmission to Block)
Oct 23, 2013 | Cars & Trucks
1999 Kawasaki KX 125 clutch basket nut & clutch bolt/springs torque specs
Hi, Anonymous for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Clutch spring bolt torque spec Kawasaki Forums
clutch spring torque setting
Kawasaki KX125 Service Manual
OEM Parts for Kawasaki
1999 Kawasaki KX125 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 12, 2012 | kawasaki KX 125 Motorcycles
We are in the process of putting in the a new clutch kit on our 1999 toyota corolla 5 sp and we need to know what the torque specs are for the clutch bolts, can you help
Clutch disc and pressure plate. The bolts should be tightened in 2 or 3 steps, gradually and evenly. Final bolt torque is 14 ft. lbs. (19 Nm).
Nov 03, 2010 | 1998 Toyota Corolla
2002 Honda CR 125 R clutch bolts torque specs
Hi, Www_crazyulf for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
01 cr125 Torque Specs Please
2002 Honda CR 125 clutch bolts torque specs Google Search
Honda CR 125R 2002 Sevice Manual
http://www.partsfish.com/page/oem-parts-for-honda
http://owners.honda.com/assets/OWNERLINK/model/own_man/powersports/2007/2007_CR125r.pdf
Apr 05, 2010 | 2002 Honda CR 125 R
87 samurai bolt torque specs for engine
The haynes book is not recommended since there are numerous mistakes and they still will not update. One of the biggest is the firing order.
The factory service manual is the only way to go.
Head bolts - 46 - 50.5 lbs (there is an order sequence for the bolts)
Intake & exhuast manifolds- 13.5 - 20 lbs
Flywheel - 41.5 - 47 lbs
Clutch cover - 13.5 - 20 lbs
Jan 09, 2009 | 1988 Suzuki Samurai
I need the bolt torque specs
go to the local auto parts store and purchase a Chiltons Repair Manual on your car, it has all the torque specs listed for this. Or you could try the library and see if there is one there for your car and just look it up for free..... just write it all down.
Sep 08, 2008 | 2000 Mitsubishi Mirage
RTO 1:1.2 Mower Gearbox Brush Hog Rotary Cutter Shredder Logo
292 people viewed this question
Top RTO Heavy Machinery Experts
STEVE
ray gallant
ray gallant
Are you a RTO Heavy Machinery Expert? Answer questions, earn points and help others
