Question about Universal Remote Control Heating & Cooling
I have a Flamerite Odyssey Suite Electric Fire approx 5 yrs old. The thermostat no longer works and I cannot find anyone that sells a replacement. The thermostat only has the number 143211 256-C displayed on it.
    New Friend:
I have just tried to obtain a stat for this same fire Flamerite was no use at all.I have put a link in where the sta was to override, it's on full now, but theres heat now. Terry Risley Electrical Services 0788 4061406
Posted on Jan 20, 2011
    New Friend:
I have the same problem, have you solved this yet??
Posted on Nov 16, 2010
SOURCE:
I have a flamerite milan fire suite lights not coming on checked bulbs they are OK heating working also
No power to the fire: Check the wall socket, plug and fuse. No illumination: Make sure the fire is turned on. Check heater is working, if so change lamps. Illumination but no heat: The safety cut has operated see note on operating the Fire. Noise when illuminated: Due to moving parts, the electric fire will make a noise. Noise from the heater when in use: The sound of rushing air is normal. Logo
Jan 21, 2017 | Heating & Cooling
I have a flame rite fire model number 172/180 will not work do you still have these fires
Maybe your circuit board is fried too? Circuit boards come up as issues more than a few.
Kind Regards,
Scott
Need circuit board flamerite 172 180 elect fire
How to fix flamerite fire
Feb 10, 2015 | Home
Flamerite fire spare parts
This is an issue to be resolved with Flamerite.
Oct 22, 2013 | Grilling
I have a flamerite mercia electric suite, just over 2 years old. The remote control does not now operate the heat function. I have replaced the battery but it still does not work. Any help for a...
I have the same problem phoned the makers Flamerite and they sent me some instructions that may solve the problem. Phone them on 01543251122 I did speak to the shop where I purchased the fire and they told me that this was a common problem with these fires. This did not fix my problem. I will be contacting them again tomorrow. Good luck
Oct 04, 2011 | Heating & Cooling
Our flamerite odyssey fire has stopped blowing out heat and we have changed the thermostat which seemed to be the obvious solution, but it just now blows the fuse.
I may of had the same problem, when i turned on the fire with the remote it would turn off straight away or not turn on at all. However i have just got it working again. Open the the door so you can turn the switch on and off. If you look in the opening where the two bulbs are, there is a small gap on the left. Make sure the mains is turned off, if you have small enough hands put your arm through the gap and push in the connector that is on the back of the on/off switch. My fire has not been working for ages, now that i have done this, it is working fine again. Good luck.
Nov 20, 2010 | Heating & Cooling
My flamerite atlanta fire will not switch on. When i do turn the heat on the fire cuts out
Similar thing happened to mine at weekend after fitting a new hearth and fire surround (sods law) think its the heater unit £57.50 from flamerite
Sep 04, 2008 | Heating & Cooling
Self cleaning cycle
Between 3 and 5 hours. Most likely 3 hours unless yours has the adjustable setting for cleaning, then you can clean longer.
Jan 01, 2008 | GE JBP25 Electric Kitchen Range
Heating & Cooling Logo
1,485 people viewed this question
Top Universal Remote Control Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
Are you an Universal Remote Control Heating and Cooling Expert? Answer questions, earn points and help others
