Question about LG 37LG30 37 in. LCD HDTV
My 37" LG LCD TV will not turn on and it has a flashing red light on the front at the bottom. I cannot get onto LG's website and there is nothing in the manual that addresses this problem. Any suggestions??
  • Paul Bade Oct 24, 2010
    After checking the second paragraph below, pull the plug, wait at least 15 seconds, then plug it in and see if it will turn on. Sometimes this clears out a "soft error" and the set works again. Other times the set will work for a while, then the problem will show up again.
    The flashing light indicates something has failed in the set. Many models incorporate an error code in the light, like the "Check Engine" code in ODB I automobiles. Does it blink several times, pause and blink again? If so, how may flashes between pauses before the pattern repeats itself?
    Post back with the results and we'll try it from there.
  • mlblklcl Oct 24, 2010
    It still will not turn on after being unplugged. The red flashing light is continuous as long as the set is plugged in. When I unplugged it, it continued to flash for a few seconds and then stopped. Does this help??
  • LG Master
  • 1,662 Answers
Two possibilities: the better one is that some joker put the set in demo mode (which includes a flashing power light), then turned on the Key Lock feature and turned off the set.
To check for this (quoted from page 118 of the manual):
Posted on Oct 25, 2010
SOURCE:
The power will not turn on, manually nor with remote. i use to be able to hit power a thousand times and it would tern on. or the red light would come on then off so then i would keep hitting power till it...
check you batteries in the remote. on the tv front panel button right lower run your hand long the bottom of tv it should turn on, then go to settings sync devices , than turn off tv try remote again should work.
if you need more help contact me
Mar 23, 2015 | LG 37LG30 37 inch LCD 720p HDTV w...
Red light & green light alternate but TV does not come on
My tv acted the same way. Easy answer........buy a capacitor kit!
it was my first try on desoldering and soldering and I have been watching the tube with no problem for months now!
Jul 12, 2014 | LG 37LC7D 37 in. LCD HDTV
My LG 37LG50 TV wont turn on ?
Are you certain the replacement power supply is good? A defective main board or power supply can cause this problem.
May 04, 2013 | LG 37LG50 37 in. LCD HDTV
When i turn on the tv the red light flashes 6 times repeatedly, what dose this mean?
Mean ur tv have a power supply board problems,tv is not getting correct power voltages from the power supply board anymore.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Feb 28, 2011 | Philips 37" LCD-TV 37PF7411/12 37 in. LCD...
Bottom left lights. when i turn on tv red light flashes what does mean
bottom left lights. when i turn on tv red light flashes what does mean
Jan 02, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
LG 37LF65 LCD TV BLINKS 3 GREEN THEN 1 RED THEN TURNS OFF.
Here's a link to the service manual for a slightly larger LG LCD TV. Perhaps it may be of some help? The troubleshooting section appears to be the same for many models of LG TVs...
http://www.observations.biz/MANUALS/LG_LCDTV/42LF66.pdf
Mar 12, 2009 | LG 37LC7D 37 in. LCD HDTV
LG LCD 37'' standby problem
if you want i will buy the tv from you
Nov 17, 2008 | LG 37LC7D 37 in. LCD HDTV
LG 37LG30 37 in. LCD HDTV Logo
1,113 people viewed this question
Ekse
