Question about Acer Computers & Internet
I have a acer laptop will not power on you can hear fan kick on 4 5 secs power light comes on its pluged in to outlet but will not turn on
  • 609 Answers
Well you two choises with the information bringing for you: Screem out or Memory. Recomendation: Buy new memory and install it.
Posted on Oct 24, 2010
  • Anonymous Oct 24, 2010
    Change the memory
SOURCE:
I have an Aspire 4520 laptop. When I turn it on, the green light around the power button lights up, but nothing on the screen. There is power to the system, because the DVD tray opens and closes like it's...
most likely a motherbaord problem.
unplug power cord, take out the battery.
hold power button for approx 90 secs.
try to power up the laptop again.
if this fails then try a new power cord, that could be also faulty and not regulating the correct power output
Oct 10, 2010 | Acer Aspire 4520-5582 Notebook
Wont power back on. only yellow light flashes
I have an aspire one AOD250 notebook and I have had to unplug and plug the power cord to the outlet on the side and it always gets my charger light to come on, try it
Apr 03, 2010 | Acer Aspire 5610-4648 Notebook
Acer Aspire one notebook wont work! Help!
First off, does it power on....does the power on light show on the laptop when it is plugged into the wall outlet. If it does power on, do you hear the fan running and the hard drive clicking? Can you see if the hard drive indicator lights are active, they will be next to the power activity light. If you cannot see any lights at all, try another charger, the one you have may be faulty. If you can see a power light, but the laptop wont power on, then you very well have a motherboard issue...or your ac adapter is not putting out enough volts to actually power the system completely. Check power first, then think motherboard issue. You don't have to have a good battery in it if you are plugged into the wall outlet.
Aug 30, 2009 | Acer Aspire One PC Notebook
Acer 3100 laptop lights on fan on slow but no screen
Remove the battery and disconnect the Ac adapter from the laptop. Press the power button and hold it for 10 seconds.Reconnect only the Ac adapter and power on the laptop.
Post back if the above solution doesnot work , it could be bad video card driver.
Thanks for using fixya
proton
Aug 12, 2009 | Acer Aspire 3100-1405 Notebook
Acer Aspire 5315 Notebook will not power on
disconnect the battery from the laptop and only hook up the ac adaptor. Turn the laptop on and if it still cuts off after 5 seconds then reseat the memory back into its slots. Also make sure your air vents are not clogged with dirt or dust as lack or air flow can cause the laptop to shut off. If that doesn't do it then take out the hard drive and dvd drive and turn on the laptop. If the laptop still cuts off then it has to be a faulty motherboard at that point which means to much voltage is going thru and the components on the motherboard are not regulating it properly.
Jun 04, 2009 | Acer Aspire 5315 Notebook
Acer 4520 Power up for 1 second and turns off
Can you hear the system fan running? If the fan fails, the PC shuts down itself to protect the processor from FRYING.
Apr 14, 2009 | Acer Aspire 4520-5582 Notebook
Acer aspire 5050 can't turn it on
If you dont see any green lights and you dont hear any boot up sounds ( hd, fans, etc) try to take out battery and just plug in the AC adapter to a known good power outlet. Make sure your power plug is good too. If you hear boot-up sounds, see green lights but no display then toggle on the "fn" key and or try on an external monitor.
Dec 13, 2008 | Acer Aspire 5050-3242 Notebook
Computers & Internet Logo
Ekse
Alun Cox
