Question about Maytag HYG3657AW Gas Dryer
No power to unit. Just stopped. Inside light doesn't work. Outlet is OK.
    New Friend:
  • 85 Answers
Check start switch
Posted on Oct 25, 2010
SOURCE:
GE Spacemaker (LVM1750) Microwave Oven
If the source voltage, the fuse inside the unit are good someone has to follow the voltage in to see where it stops.
Dec 23, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
My is73 system will not power up . the 2 fast blow fuses are ok
Hello, welcome to Fixya!
Your receiver is having a power fault because it is not switching on. The receiver might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
First, remove the unit's power cord from the wall, wait for about 30mins, then plug it back in. If it doesn't power on, plug it into another outlet, to make sure there electric current entering into the receiver.
If plugging into another power outlet doesn't power it on then it confirms that the receiver is having a power fault.
When electric current comes from the power outlet into the receiver, it goes straight into the power supply board which then circulates the current into the unit. So if the receiver doesn't power on, the first thing is to make sure there is power entering into the receiver.
So check the power cord, if it is a 3-pin plug, it must have a fuse in it. check the fuse if it is not blown. if fuse is intact, then power supply board should be checked.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter and continuity tester in order to read the components on the power board. Once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect and solve the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Regards.
Jan 05, 2012 | Audio Players & Recorders
No power. outlet is good, microwave plugged in. no lights, no power, nothing. does this unit have a power supply that might have gone bad?
the problem of this unit is power related.
First, remove the unit's power cord from the wall, wait for about 30mins, then plug it back in. It may cool by then and might power on. If it doesn't power on, plug it into another outlet, to make sure there electricity entering into the unit.
If plugging into another power outlet doesn't power it on then the unit is most likely having a power problem.
When electric current comes from the power outlet into the cooker, it goes straight into the power supply board which then circulates the current into the unit. So if the cooker doesn't power on, the first thing is to make sure there is power entering into the machine.
If any machine or electronics device doesn't power on, it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter and continuity tester in order to read the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Regards.
Nov 06, 2011 | Hotpoint RVM1435 Microwave Oven
We have an Surveyor house trailer 3 years old, lightly used. The last time we tried to use the fridge it didn't work. Mod#DM2652 Ser#81708076. Checked the outlet that it is plugged into, it works,...
Since your unit is an AC and Gas unit, you need to find out if it works on gas in order to make a good diagnosis.
But from your description, it sounds like your DC power is not at the unit.
http://www.gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
Jul 12, 2011 | Dometic RM2652 Refrigerator
Everstar mpm2-10cr-bb6 will not reset on power cord. light on reset doesn't light. seems like no power is getting to the unit.
Check the outlet that the unit is plugged into, to be sure that it is in fact, working. The circuit breaker in your home's circuit breaker panel for that outlet, may have tripped. Also, the outlet may have interior damage or a loose wire connection. If the unit seems not to be getting power, one of the above is the problem. Try plugging the unit into another outlet in a different room.
Hope this helps you troubleshoot and solve the problem.
Jun 02, 2011 | Danby DPAC8020 Air Conditioner
Dehumidifier has stopped working...it appears to be electrical..no switches are working and no lights are on.
Check the outlet that the unit is plugged into, to be sure that it's still has power. If it doesn't, a circuit breaker for that outlet may have tripped. Or the outlet receptacle may have a loose wire. Try plugging the unit into another outlet that is not on the same circuit, as the one it's currently plugged into.
May 23, 2011 | Dehumidifiers
Has power to unit but nothing works, ie. oven, clock, timers, etc
If you don't see any light in the display or from the light bulb inside it you probably need to replace the fuse inside the microwave, it should be by the place where the cord goes in the microwave.
Apr 08, 2009 | General Electric Microwave Oven
Microwave stopped working
Generally, you get something unless the fuse inside is blown. There is generally a fuse inside the unit when you remove the button package. First, make sure that the outlet you have is good. Plug something else into it and see that it works.
Dec 16, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Maytag HYG3657AW Gas Dryer Logo
43 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
