Front loader washing machine won't unlock door
  • 4 more comments
  • KDJSBJ Sep 26, 2008
    Front door will not unlock. The machine says the door is unlocked but it remains locked. How do I unlock it manually? Have tried unplugging, even tricking it to start so that I may unlock the door to stop the cycle. The locking mechanism is stuck in the locked position. HELP
  • kelsieleigh Oct 19, 2008
    I loaded the washer and started it and it started to beep and the panel reads DO then it will fill the water and then it will beep and flash FL. I have unplugged it and tryed to stop and start it and still the door stays locked can you help me?
  • Anonymous Oct 29, 2008
    same deal- door will not unlock and i have plugged it, unplugged it, and am ready to use a crowbar
  • Anonymous Feb 20, 2009
    the door remains locked even when the cycle is done. Forever. I have turned off the power to the unit and then tried to open the door. no go. i then turned the power back on and moved the knob to the off position in another cycle( from heavy wash to delicate wash) eventually the light went off and the door unlocked. It still stays locked way after the cycle is done. I keep experimenting.
  • Anonymous Mar 12, 2009
    The door locked light is not on, however, the door is locked and will not open. I have turned to power off via the breaker box and it did not help. I got the F22 door locked error, duh, and went through all the suggested fixes in the manual. No luck. It will not work on any cycle.
  • mikyul Mar 31, 2009
    Washer door stays locked when it's done, sometimes won't lock when I'm trying to start a wash. Lots of door slamming and swearing seem to sometimes help.
Remove three screw at bottom of washer, pull of lower panel, reach up on right side just under the locking mechanism and bull ring down. door should unlock.
Posted on Mar 15, 2009
My samsung door lock wouldn't let me open the door no matter what we tried. We unplugged it, turned off the power, ran the spin cycle again. The LO symbol came on and wouldn't allow the door to unlock. We took off the top panel and noticed by the front of the interior cavity by the door lock, a plug had come unplugged. We plugged it in and bingo, problem solved!! Thanks for being *** samsung.
Posted on Aug 28, 2009
  • 124 Answers
SOURCE: washing machine creda front loader
Some washing machines have a mechanical/cable release hanging down underneath, perhaps behind the kick tray thing. the cable is attaches to the pulley at the back and it needs to push against the belt squarely to enable the door to open, otherwise, (after making sure it is unplugged) put you hand down behind the front fascia and lift the moveable part of the doorlock. This will not fix the problem but it will open the door.
Posted on Mar 20, 2006
  • 41 Answers
SOURCE: Washing machine rubber door seal replacement
Go to www.Searspartsdirect.com You should be able to find an exploded view and parts list
Posted on Feb 29, 2008
SOURCE: FRONT LOADER DOOR LOCK WONT OPEN OR JAMMED
On a Bosch wfmc3200uc there is a green plastic string, similar to fishing line, located behind the round panel on the front of the machine. It is attached to the top right of the round black piece. Just give a slight tug this will release the lock.
Posted on Oct 21, 2008
GodBlessU
  • 3513 Answers
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Posted on Sep 30, 2009
  • 177 Answers
SOURCE: miele front loader washing machine W3275- error co...
hi,
this is a tachogenerator fault or the drive motor brushes are faulty. you will need a Miele service tech or a Miele service agent to look at this.
Posted on May 24, 2010
The door on LG front loader washing machine won’t unlock
hi Margaret.
If the washing machine malfunctions or you need to stop the cycle and retrieve the clothing, you can force the door to unlock.
  • Open the door after the "Door Lock" indicator turns off. ...
  • Press the "On/Off" button, if the washer is not already on.
  • Select the "Spin Speed" button to turn on the Drain & Speed cycle.
  • or go to this link and have a read up.
LG front loader washing machine wont unlock Google Search
Dec 12, 2017 | LG Washing Machines
Light flashing won start
Common error with front loaders is the door interlock. Make sure the door is positively closed. A gentle open hand push at the erea of the door lock often gets a machine started.
Regards
John
Jan 30, 2014 | Kenmore Elite 45986 Front Load Washer
My whirlpool amw8121 front loader won't spin. It
There should be a door-actuated limit switch which detects that the door is closed, which is probably defective. Look for the plunger, listen for the click. It is the most likely component to fail, and is inexpensive to replace if you're handy. Be sure to have your machine unplugged during repairs.
Sep 04, 2012 | Washing Machines
Door won't unlock whirlpool wFs1073dd front loader
If it has water in the the machine, it has a safety feature that will not allow the door to unlock. There is a manual release but you have to take the bottom kick plate off. Unplug the washer. Then reach up on the right side of the washer and you will feel a plastic lever about the size and shape of a nickel pull down on this lever to release the door. If it full of water i would clean the pump first to get rid of the water. you can clean the pump by taking off the kick plate and you will see a pump with a lid with a handle on it. you can unscrew this and it will have a trap attached to the back of the lid. pull the trap out and clean any debris out then screw it back in. make sure to have buckets and towels handy once you unscrew the lid any water in the machine will fly out at you. the easiest way to avoid this is to clamp the hoses that go to the pump.
Aug 24, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Front loader washing machine door won't open
try unplugging the machine to reset it.
Feb 27, 2012 | Samsung Washing Machines
My front load washer has the door lock stuck and the door is open
When this happened to our front loader washing machine, we had to unplug the appliance, wait, then replug it to reset and unlock the door.
Feb 10, 2010 | Electrolux EW1000i Front Load Washer
This is normal, the unit usually goes into a SD or slow down mode. To stop this press the start pause button and the door will unlock.
Sgt 48
Jun 04, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Front loader washing machine will not go through spin cycle. door locked shut. cant get clothes out
most frount loaders have and unlock pull ring on the door latch switch, it will mean removing the bottom access panel to reach up inside the machine and pull the release ring down to unlock the door
Apr 21, 2008 | Washing Machines
Unlock the control panel to a kenmore elite front loader
to unlock the controls
select and hold drain/spin for 3 seconds until the control locked status lights turn off.
Nov 22, 2007 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washing Machines Logo
3,995 people viewed this question
Top Washing Machines Experts
