My problem is that the laptop can find the wireless network for the company and i have the password but when i press connect the computer refuse and a dignous message appears and say turn the wireless on and opens the help of the windows so please help me finding a solution to this problem thanks mohamed sahim
  • Osogama
    Osogama Oct 24, 2010
    this can be fixed. I need the make and model of the laptop and the Operating system involved.
    New Friend:
    Problem Solver:
  • 5 Answers
Is your wireless switch set to the off position? Newer laptops have a WiFi on/off switch on the side. Look for the switch and set it to the on position to see if that is the problem.
Posted on Oct 24, 2010
SOURCE:
I have a Belkin wireless g router. 2 computers hard wired and one laptop wireless. I get slow internet speeds a lot of the time. I press the reset button and it will speed up for a bit then back to slow...
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
7. Once your done on the internet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
if you have any query pls feel free to get in touch.. good luck
Nov 22, 2009 | Belkin (F5D7633UK4A) Wireless Router
What is the password for this router
Hi! I will be glad to assist you in this issue. the password for the router like linksys, the username is admin and the password just leave it blank or 1234. if this password dont work, this iswhat your going to do..
1. click on start
2. run
3. type cmd
Nov 08, 2009 | Linksys Wireless-G Broadband Router
Dlink help!
1. click on start
2. run
3. type cmd
Oct 20, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Had an extra router, brought it to my folks to hook up wireless for new laptop...connected through Comcast modem, all wired correctly...problem because laptop is an HP and modem is being run through Mac???...
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do: 1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok 2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer.. 3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank 4. it will show the setup page of the router. u can set the router on the specific internet setup that u have. a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet. b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security.. 5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe 6. If ur isp gives u a static ip address settings, u need to set the router to isp setup. a. how to check the isp of the isp given to u.. 1. click on start 2. run 3. type cmd 4. it will show a dos prompt 5. from the dos prompt type ipconfig/all 6. it will list the ip address, subnet, default gateway, dns server this settings should be type in to the settings on the router for static ip addressing.. 7. Once your done on the internet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2. 8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access.. 9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon.. if you have any query pls feel free to get in touch.. good luck
Oct 05, 2009 | Linksys Wireless-G WRT54G Router
I have been trying to get conected to my network with my ITOUCH but it wont accept my password how do I change the password for logging on with my ITOUCH
1. click on start
2. run
3. type cmd
Oct 03, 2009 | Linksys WRT160N Wireless Router
How do i find the pin number for the wrt54g V 8
HI! i will be glad to assist you, if you are referring to the wireless security password in order for you to access the wireless connection, from the url type http://192.168.1.1 then it will ask the username and password, for the username, type admin and the password just leave it blank or 1234, then the setup page will pop up, go to the wireless connection setting , from there it will show the type of wireless security that you have it could be one of the ff: wep, wpa, wpa2 then it will show also the password or the pin that your referring. if you cant access the setup page of the router then you have to do this steps in order to setup again your router, here are the steps u need to do: 1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
1. click on start
2. run
3. type cmd
Oct 02, 2009 | Linksys Wireless-G WRT54G Router
Can this router get a connection without being plug directly to a modem my wireless card can see the connection but they ask me for a password
1. click on start
2. run
3. type cmd
Sep 30, 2009 | D-Link DI 514 Wireless Router (DI-514)
My laptop connects to it but not the internet
1. click on start
2. run
3. type cmd
Sep 28, 2009 | D-Link AirPlus DI-524 Wireless Router
Routerlogin doesn't accept my user name and password for netgear wirelss router
Read the manual -- there is a "factory reset" procedure, which wipes-out all user-specified settings, including passwords.
Sep 18, 2009 | NetGear WGR614 Wireless Router
How do you hook up a Netopia 2247NWG-VGx Wireless Router? I need it for my desk top and laptop.
1. click on start
2. run
3. type cmd
7. Once your done on the innternet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
if you have any querry pls feel free to get in touch.. good luck
Sep 02, 2009 | Netopia 2247NWG-VGx Wireless Router...
Open Questions:
Computers & Internet Logo
76 people viewed this question
Ekse
Alun Cox
