Question about Acer Aspire 3680 Laptop
Acer Aspire 3680
The computer problem first started showing that the battery was not charging when it was plugged. Now, the laptop won't even power up with the power cord.
  • 3 more comments
  • blueyedakmom Jun 27, 2008
    Having a similiar problem with the Acer aspire..it won't power up. Does this brand need a battery in it to power it on?? I have a Sony Viao and it works even if the battery is not in it...Does Acer work that way or do you have to have the battery in for it to power on..and if the battery is dead...will it not power up??
  • catskillnick Oct 08, 2008
    yes I have this problem now when I go to plug it in, it want take a charge This seems to be a problem with alot of your acer computers. Please let us know how to fix this also I have another problem When I turn on my computer about 10 minutes later the screen starts to go blury and cant read it. Thank you. Ginger
  • Anonymous Oct 22, 2008
    Seems to be a chronic problem with this laptop. I have the same issues.
    I HAVE THE SAME PROBLEM MY BATTERY WILL ONLY STAY CHARGED FOR 15 MINUTES AND THE COMPUTER SHUTS COMPLETLY DOWN I DONT KNOW IF IT IS THE CHARGER OR BATTERY
  • Marywanna Mar 19, 2009
    When you guys try to power it on, does the charging indicator blink a few times yellow? Mine's doing that..
    Problem Solver:
  • 31 Answers
Hi Friends,
Problem with
Acer Aspire Notebook Or Laptops? Just visit the sites..
For any Software problem you can visit a link by just Click Here .
For any Hardware problem with this Notebook you can Click Here
Posted on Jul 20, 2010
    Problem Solver:
  • 13 Answers
I cannot tell you the exact reason why but I can tell you what I did to fix it. It was not any of the above. I deal with laptops all the time and I knew this one had a good charger. I even tried several. I happened to notice that sometimes it would charge with one brand charger and sometimes another but I finally found one that always worked. The reason it worked was that it put out a constant 20VDC @ 6.0A instead of the normal 19VDC @ 2.0A that is supplied by most chargers. I am not going to "advise" anyone else to try this but if you buy a new charger you will most likely see that instead of the normal 19VDC it will have a "spread" of 19V to 23V or so. Any of these chargers will probably work not because yours was "bad". I tested several with voltmeters that all said 19V but they all worked erratically sometimes yes, sometimes no. In my opinion, there is either a design flaw or bad component in the on-board charging circuit. It will ONLY allow power to come in when certain conditions are met and apparently when it gets a bit "off" it will only work with an input that is greater than what is normally needed. Bottom line, if you get a replacement charger, I advise you get one that will; supply more than the minimum of 19VDC as required by the original. It would be interesting to know if anyone else has checked their old power supply to see if it was actually good.
Posted on Jul 15, 2009
  • 34 Answers
This has happened to my laptop too. It turned out to be the AC adapter/power cord. If you have a computer repair store near you you can take the cord and they might repair it for you. Also to make sure that it is power cord the computer repair shop can test it to make sure it is working correctly. It costs me less than $20 to get it fixed. If not you may have to order a new power cord.
Posted on Mar 22, 2009
My daughters laptop was doing the same thing. No power indicator light or battery wasnt charging, but the charger was putting out ok. Found on the laptop were the power adapter plugs in the center
plug pin was broke off in the plug of the adapter making it look like a new syle special plug, Had to change the female recept. on the back of the computer.
Posted on Oct 07, 2008
  • 62 Answers
Check to make sure that the adapter (where it plugs into the back of your computer) is not loose. I know that I just had to replace mine due to the saudering coming loose. If when you plut it in and you can move it around and there is play to it, then you need to have the "charging port" replaced with a new one. Usally this means taking it into a computer service to have them take apart the lap top and fit a new one.
Posted on Jun 08, 2008
It goes dark, shuts off constantly. Battery meter isn't showing charging.
Unplug the battery and plug in the AC power plug into the laptop;
Does the laptop start up and stay on?
If yes,
Then put the battery in WHILE IT IS ON; See if it starts charging.
If it does not; You have a bad battery and need to replace it.
If it does start charging here's what happend;
Some laptop batteries if they are fully depleted on charge will not let you power up the laptop EVEN IF the power cable is plugged in. In some cases the PC won't turn on at all.
The reason for this is because the battery must have a certain % of charge in order for you to start the PC even IF the power cable is plugged in.
By removing the battery we eliminated the battery as being a cause for this issue; Once the PC is up and running in windows.. LET THE BATTERY CHARGE! You'll want at least 10% charge minimum for the PC to start up.
If however the battery replaced still doesn't hold a charge it's going to be the AC Adapter power cable that's causing the issue.
Best advice start off with the power cable replacement first; This is the cheapest to fix; Otherwise the battery can cost in excess of $50-$150 or more. But universal AC power adapters can be cheap $70 or less which varies depending on laptop.
Sep 30, 2013 | Toshiba Satellite L655-S5101 Laptop
My hp pavillion laptop will not charge my battery . It won't even work without the battery but plugged in with power supply even though i know battery and power supply are sound.
It won't ever be a 'software' issue....it will be either a :
Adapter/Charger issue (Have it tested by local PC repair shop.)
if it is good, then it is the other prob. If it is not good, then buy a new one.
OR
Laptop power connector issue. (expensive repair.)
Sep 06, 2012 | Toshiba Satelitte M300 St3401 Core 2 Duo...
Sony pcg-81114L power supply not detected
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Aug 04, 2012 | Sony VAIO PCG-K33 Notebook
Computer just shuts off when i unplug even though shows full battery
POWER SUPPLY & BATTERY PROBLEM
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Jul 07, 2012 | Sony VAIO VPCF134FX/B F Series Notebook
Hp 6715s laptop battery charging bat battery backup not starting problem solyution
If I understand you correctly, you are saying the computer will run with the AC adapter plugged in, but will not start on battery power even though the battery appears to be charged. Most likely the battery is defective. If it won't run on battery power with a known good battery, then there is a problem in the power control circuit on the main logic board inside the computer.
May 25, 2012 | Computers & Internet
My laptop won't charge even it is plugged in.
Hello, I am the technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya, Loue Benison.
The solution to your problem lies in one of the following three areas:
1.) Your charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think senerio 2 is the most likely, although you will have to test senerio 3 by removing the battery and pluging in your charger and seeing if the laptop powers on.
If it does power on then that rules out senerio 1 and 2 leaving a faulty battery.
Take care!
Dec 14, 2011 | Lenovo G460 Laptop Computer 06774CU Intel...
My laptop won't charge. I have an acer aspire 5315 that won't charge, I had problems with the charging adapter before so I thought that was the problem and replaced it, the replacement worked for...
For a test -Remove the battery from the laptop. (leave it out) -Plug in the adapter and turn the laptop on. -Gently wiggle the adapter plugged in
If the computer powers off the solder and/or pins have broken loose from the DC jack. This is very common. Average repair bill is around $150, if your in the Denver Colorado Area I can do the repair for about $50
If it won't turn on while you wiggle the adapter and hit the power button then the adapter is bad again sadly
Jul 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
Inspiron mini 10 Running on battery even when a/c is plugged in restart computer and plug in a/c again and charges up but then drains battery again
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jul 07, 2011 | Dell Inspiron Mini 10 Notebook
Medion E1210 notebook. Battery has suddenly stopped charging. Didn't get a fall. Laptop works fine when power supply connected, but if plugged out laptop shuts down immediately. When power plugged in...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 21, 2011 | Computers & Internet
The toshiba laptop a505 S6980 will not charge the battery when the AC is plugged in and dies immediately if unplugged . Meters shows 0% available (plugged in), charging. But it is not really charging.
Apr 20, 2011 | Toshiba Satellite L500-ST2521 Laptop AC...
Acer Aspire 3680 Laptop Logo
762 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
