Question about Intel Tablets & eReaders
Lost my vye s37 bios password - Intel Tablets & eReaders
2 Suggested Answers
SOURCE:
  • 6 Answers
SOURCE: how to open the case of vye S37/kohjinsha SH6
Help here: 1. http://pc.usy.jp/wiki/index.php?%B9%A9%BF%CD%BC%CB%20SH%A5%B7%A5%EA%A1%BC%A5%BA2. http://pc.usy.jp/wiki/index.php?plugin=attach&refer=%B9%A9%BF%CD%BC%CB%20SH%A5%B7%A5%EA%A1%BC%A5%BA&openfile=SH06HDD%B4%B9%C1%F5%BC%EA%BD%E7.pdf
Posted on Dec 11, 2009
Bios password
Find the quarter-sized battery on the motherboard and remove it for a few minutes. There might be two pins nearby that read CMOS reset or BIOS reset. Shorting them together with all power removed, including the small battery, can also reset the BIOS.
Jan 26, 2014 | Fujitsu Stylistic 3500 Tablet PC
Tengo una toshiba r15 s822 que tiene password en el bios y no se como quitarlo ayuda por favor
If you forgot Windows password, you can create a Windows password reset bootable CD/DVD or USB flash drive to reset your lost or forgotten Windows password, i have created a bootable CD with the tool Windows Password Breaker and reset my administrator password successfully.
Dec 28, 2010 | Toshiba Satellite R15-S822 Tablet PC
Bios password
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Jul 21, 2010 | Toshiba Portege R100 Tablet PC
M4-s435 bios password removal
Feb 16, 2010 | Toshiba Tecra M4-S435 Tablet PC
How to reset bios password , i forgot d password
Remove the battery on the mother board, wait 5 minutes.
Oct 15, 2009 | Fujitsu LifeBook P1120 Tablet PC
Password problems on a Toshiba Protege m200 laptop
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password.
  1. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard. If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
  2. On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password.
  3. If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper.
  4. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
Many RTC's require an external battery. If your RTC is one of this type, you can clear the BIOS password just by unsocketing the RTC and reseating it.
Good luck and more power
nicole
Oct 03, 2009 | Toshiba Satellite R15 Tablet PC
How to open the case of vye S37/kohjinsha SH6
Sep 14, 2009 | Tablets & eReaders
I lost my admin password for bios setup
You can clear the bios password by removing the CMOS battery from the motherboard, make sure the PC is disconnected from any other power source, wait a good 3 - 5 minutes, hit the power button a few times to make sure all power is drained from the capacitors, and then replace the CMOS battery. You can then power on the PC and the bios password will be removed.
Jun 25, 2009 | IBM ThinkPad X61 Tablet PC
I lost my admin password for bios setup in lenovo x61 tablet
chk this link
http://www.tech-faq.com/reset-bios-password.shtml
or
most awesome answer is here
http://www.ja.olm.net/unlock/
Mar 30, 2009 | IBM ThinkPad X61 Tablet PC
Lenovo ThinkPad X41 Tablet security chip. lost bios boot password
I have had to retrieve the BIOS password from one of these before. It is not an easy thing to get to. You have to first
  • Build a special 9-pin Serial cable using parts you can find at Radio Shack
  • Dismantle the laptop
  • find the correct BIOS chip,
  • Solder a couple wires to the correct pins of the BIOS chip (without getting solder on the other pins, or damaging something)
  • Hook it up to another computer via serial port
  • Do a dump of the information stored on the BIOS chip
  • Use a hex-reader to decipher the information and display the password within.
Here is a link to a site that shows you in detail how to accomplish this. It does work, and I've successfully used the linked method to unlock a X41 of my own.
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
Mar 26, 2009 | Lenovo ThinkPad X41 Tablet PC
Tablets & eReaders Logo
102 people viewed this question
Top Intel Tablets & eReaders Experts
Marvin
Marvin
Are you an Intel Tablet and eReader Expert? Answer questions, earn points and help others
