Question about Toshiba 50H81 50" Rear Projection Television
How can I fix it
Red light is blinking but no picture or sound. Tried to unplug and plug back in, sounds like getting power but then starts blinking again.
  • 3 more comments
  • Anonymous Jun 13, 2008
    i have the exact thing on a 42
  • mostreaker Jun 21, 2008
    The same problem has just happened overnight on our 50H81 for no apparent reason. Set was shut off for evening. Next a.m. red led was flashing and set would not come on. Unplugged set for a period of time and reconnected. Turned on w/remote.........red light came on for power, set sounded like it was going to come on, then started flashing. Any help would be appreciated.
  • Anonymous Jul 29, 2008
    I have the same problem with my 50H81. Any solutions?
  • usguys4120 Sep 01, 2008
    npr,fl. we have bought a 2nd hand 50h81 2oo2 april model . we have had it for a year now. it just started last week. it would work after unplugging at first , and now it just clicks3 times and has a shallow thump. i kind of which i live on the third floor of a apartment complex. need i say more.
  • Anonymous Oct 26, 2008
    I have the same problem.
  • Toshiba Master
  • 8,617 Answers
Its definately a power supply issue. You may want to get a service manual for your model as it will have the info to trouble shoot the standby and start up voltages. You can get a manual emailed to you at the following link and they will help you trouble shoot the set. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Jun 08, 2008
Mom's Sharp Aquos TV no sound or picture there is a green flashing light where the power light is I heled the volume up and channel down while the TV was unplugged. plugged it back in sound no picture
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 24, 2016 | Sharp Televison & Video
No picture or sound
Looks like a power supply issue the only solution to fix this up is to get it repaired.
Goodluck..
May 03, 2008 | Toshiba 32HFX72 32" TV
My sony trinitron is blinking red and won't turn on
THIS IS NORMALY CAPACITORS IN THE POWER SUPPLY THAT NEED REPLACING
Jun 25, 2013 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Red power light continuously blinking. no picture no sound.
It could be the lamp went out and needs replacement. The Toshiba website states when this happens to unplug the televison for 10 minutes then plug back in. If that does not work then try another power outlet. If that does not work then call for service
Sep 12, 2009 | Toshiba 57H81 57" Rear Projection...
Blinking red light, no picture or sound
You goingto need to replce the powersupply inside www.partstore.com should have it or preorder it for you from the manufacture i think there around $150 they could be cheaper. Another option is Ebay. thanks for using fixa.com please rate.
Aug 21, 2009 | Panasonic TH-50PX75U Plasma HDTV
Power light blinking RED after power outage. Tried leaving unplugged for a while. Continued to blink RED after plugging in again. No picture. No sound.
replace the power pcb,check the fuse on the
power pcb and see if that corrects your problem.if not replace the power pcb.go tp
shopjimmy.com to get the board.
Jul 29, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
I have a Philips Plasma tv 42pf5321d/37 with sound but no picture
Thats the great sound of Exploding capacitors on either the power supply board. or another one in there. Now the set is in fault protection. It tried to warn you with the RED blinking LED that there was something amiss by shutting itself down. When you unplugged you reset the error and allowed it to do it again.
Best Regards and Smper Fi
Jun 23, 2009 | Philips 42PF9630A 42 in. Plasma Television
Red Lights on the Power button blink and picture goes dark
60PL9200D/37 When I unplug it for a while and turn it back on, the picture starts to come on, but it turns dark. And the red lights on the left and right side of the power button blink. Sound but no picture.
Feb 02, 2009 | Philips 60PP9202 60" Rear Projection...
Blinking red light
I DO HAVE THE SAME PROBLEM , ONLY THE RED LIGHT BLINKING ,NO SOUND NO PICTURE '
PLEASE I DO NEED HELP TO FIX IT .THNKS
Nov 15, 2008 | Akai LCT2715 27 in. LCD Television
Need Help big screen turns on thens goes off
The unit is going in to shutdown. Sounds like you have a short in the high voltage section.
Feb 18, 2007 | Panasonic PT-53WX52 53" Rear Projection...
Toshiba 50H81 50" Rear Projection Television Logo
131 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
